Why hasn't the Oort cloud converged to a disk shape?
In summary, the Oort cloud is often depicted as a sphere and its objects orbit the sun in circles or ellipses. Due to its shape, collisions are expected, but the cloud has not converged to a more stable, collision-free disk shape. This is because the total dynamic energy of the cloud is reduced by electromagnetic interactions, causing it to remain in a gaseous state for longer periods of time. Additionally, dynamical friction plays a role in redistributing orbital energy and preventing collisions. The Kuiper belt has already formed into a disk, but the Oort cloud is still in the process of joining it. High inclination orbits are being cleared out by Kozai resonance, but for long period comets, this process is slow
Jonathan212
198
The Oort cloud is often drawn as a sphere. Everything in it orbits the sun in circles or ellipses. Since the shape is not a disk, collisions are expected. Why hasn't the Oort cloud converged to the more stable, collision-free, disk shape?
Astronomy news on Phys.org
Hi @Jonathan212:
Since quite a few people have already looked at your thread and did not respond, I decided to make a try at answering your question. I confess that I am not an expert, and the answer I will make is based mostly on reading other threads at this site.
In general, a "cloud" configuration of stuff moving about a star is stable. What causes a spherically shaped collection of stuff to change its shape to an ellipsoidal shape, and an ellipsoidal shaped collection to flatten into a disk, is that the total dynamic energy of the stuff reduces. A disk of the same radius as a sphere has a lot less energy. The mechanism that causes energy to be lost is electromagnetic (EM). That is, energy in the form of photons carry energy away from the stuff. That will generally happen when the stuff is in the gaseous state. When the gas cools to a solid state the frequency of EM interactions reduces substantially. Stuff that is sufficiently close to the star (like the solar system) is heated by the star sufficiently to remain gaseous longer than stuff far away from the star (like to Oort cloud). When the stuff cools to a solid state, molecules hit molecules at a relatively low speed which results in attaching and making bigger molecules. Eventually, these attaching events produce dust. When the dust particles hit (slow enough) they attach into large dust, and so on until you get rocks and comets and asteroids, etc. These attaching interactions produce only a little dissipating heat photons which cause only a very little flattening of the overall shape.
To the extent that the above answer has errors, I hope someone will correct them.
Regards,
Buzz
Likes Klystron
What is called dynamical friction plays a role. Dynamical friction occurs when bodies interact gravitationally when passing through some medium (like a dust cloud). In the early solar system the density of dust and stuff in the inner system was much higher than in the far reaches, so it had a chance to extract a lot of KE from things moving there. Things out in the far reaches have far fewer gravitational encounters to redistribute orbital energy and dump it into a medium.
I'm trying to relate this to simulations of extremely large numbers of point masses. A dust cloud could be modeled as lots of point masses, if enough computing power and time is available. So it's all point masses colliding with each other, and they are all moving in elliptical segments between collisions, as per Newton's laws. What should happen when they collide? Are colliding dust particles or even molecules supposed to emit e/m waves and slow down as a result?
Buzz, a disk could have an average radius equal to that of the sphere so it could have the same gravitational energy. The same kinetic energy too. Bouncing could even eject objects with escape velocity so there is no limit to how far they can get.
Will point masses collide? Is it possible the sim needs to have non-zero masses in order to correctly predict the observed behavior?
An obvious answer is that Kuiper disc already has, but Oort cloud is in the process of joining Kuiper belt, and has not yet.
High inclination orbits are being cleared out by Kozai resonance. For long period comets, it is slow, and has not yet exhausted Oort cloud.
Likes Jonathan212
You mean non-zero radius and finite small mass. Dealing with collisions just means adding repulsive electromagnetic forces that only apply at small distance or something like that. This is not a practical simulation because too much computing power and time would be needed, but for the purposes of understanding what is going on with the Oort cloud it may be helpful.
I have a related question. If you launch 1000000 perfectly elastic balls in random directions and from random locations around the sun, would they still form a disk eventually? In other words, are plastic, not elastic collisions a necessary condition for disk formation?
I could suggest that those objects were late arrivals to the Solar System from a random set of directions and with random speeds and their orbits haven't had time to be influenced by the large planets? The formation and maintenance of Saturns rings is 'explained' in terms of a number of small moons that 'shepherd' the particles in the rings and keep them within those well known ring patterns. Perhaps it's the same sort of thing on a bigger scale?
Estimates have been made in the past of the total mass of Oort Cloud bodies. Here are a couple of estimates.
"If Halley's Comet's mass is typical for comets, then the Oort Cloud could have a total mass between 4 and 80 Earth masses" [1].
"Past estimates of the total mass of this Oort Cloud have ranged from about 40 times that of Earth to greater than that of Jupiter" (about 317 Earth masses) [2].
These estimates are largely based on the masses of comets and dwarf planets which have been detected because, during parts of their orbits, they have reached the Inner Solar System, or at least the Kuiper Belt. All these bodies have had highly elliptical orbits, if they hadn't they would never have come within range.
So such estimates do not take account of whatever bodies exist within the Cloud which do not have elliptical orbits, and so do not come into range. Taking these bodies into account might increase the estimated total mass of the Cloud. [1] Nick Stroebel. Comet Orbits---Oort Cloud and Kuiper Belt. http://www.astronomynotes.com/solfluf/s8.htm
[2] Oort Cloud & Sol b? http://www.solstation.com/stars/oort.htm
Oops. Yes. I meant non-zero size of course.
Well, no. That was my point. Particle don't just bounce off one another - they collide in non-elastic collisions and stick together. See posts 2 and 3.
I'm saying that that may well be important to the simulation in how it models the Oort cloud versus the Kuiper Belt.
Likes TEFLing
If the Oort cloud is getting added to the Kuiper belt why isn't there a continuity from one to the other?
Likes TEFLing
Unlike the galactic disk and the Kuiper belt, the Oort cloud has zero total angular momentum and thus no inclination to settle into a disk. The large radius of the Cloud guarantees little to no collisions, similar to the stability of the asteroid belt.
I find that an interesting statement. How is that determined? By observing a statistically significant number of Oort objects (too small and too distant, I suspect) or just by observing comets? Presumably the "zero angular momentum" is referenced to the Sun as centre and assumes that the objects arrive symmetrically 'on either side' as they approach the Sun. As part of the galaxy, they presumably have the same mean angular momentum around the Galactic Centre as the Solar System. I say that because there can be nothing particularly special about the individual Oort objects; they didn't arrive from outside the Galaxy (presumably??) and just turn up 'here'.
If there were more objects in the Oort cloud, would angular momentum arise from too many collisions?
Another factor may be that the Oort Cloud keeps getting 'churned' by passing stars...
IIRC, latest was Scholz's Star, about 70 kyear ago..
https://en.wikipedia.org/wiki/Scholz's_Star
quote:
Estimates indicate that the WISE 0720−0846 system passed about 52,000 astronomical units (0.25 parsecs; 0.82 light-years) from the Sun about 70,000 years ago.[2][5] [11] 98% of mathematical simulations of the star system's trajectory indicated it passed through the Solar System's Oort cloud, or within 120,000 AU (0.58 pc; 1.9 ly) of the Sun.[2] Comets perturbed from the Oort cloud would require roughly 2 million years to get to the inner Solar System.[2] At closest approach the system would have had an apparent magnitude of about 11.4, and would have been best viewed from high latitudes in the northern hemisphere, in the autumn mostly.[4] A star is expected to pass through the Oort Cloud every 100,000 years or so.[4] An approach as close or closer than 52,000 AU is expected to occur about every 9 million years.[2] In about 1.4 million years, Gliese 710 will pass somewhere between 8,800 and 13,700 AU from the Sun.
FWIW, reading of this pass by Scholz's Star inspired me to write a short story, 'Hunter's Night'...
https://www.physicsforums.com/threads/the-short-story-thread-post-yours-here.914630/
Likes stefan r
Without non-elastic collisions the total energy will remain constant and you will get a spheroid with a ratio between kinetic and potential energy according to the virial theorem. That means, yes, you need non-elastic collisions. But I'm not sure if the collisions between your test particles are sufficient, because the number and the size of the particles cannot be realistic. How about a combination of your particle method with a continuum method for the collisions?
Yes basically from the observation that comets have no preferential direction that they're coming from, they appear from all over they sky in a spherical distribution. Oort cloud objects are much too faint and distant to observe directly, and yes, I mean zero angular momentum with respect to the Sun.
The direction is not sufficient to conclude that the total angular momentum is zero. The angular momentum needs to be equally distributed too. Is there a value available for the average orbital angular momentum of all known long-period comets?
Certainly individual comets have some amount of orbital angular momentum, and the cumulative sum of their individual contributions might not add up to zero, but if there was a systematic trend in the angular momentum of the Oort cloud, it would show up as a preferential plane, or a zone of avoidance for the distribution of the comets' orbits.
Can you provide a reference for that? The papers of Marochnik (1988) and Weissman (1991) give a range of estimates, the smallest of which is a few times greater than the solar system and the largest is ~1000x that.
Can you provide a link to Marochnik and Weissman? I'd like to see how they arrived at their conclusions...
Yes, passing stars mix up the Oort cloud. Carl Sagan's book "comet" went into some detail.
When a star (or rogue planet) passes by the Sun it is effecting Earth for multiple years. The effect in the spring time cancels the effect in the fall. An Oort cloud object has an orbit measured in thousands to millions of years. The entire stellar flyby occurs while the object is in one side of its orbit. That changes the inclination.
An Oort cloud object's orbital velocity could be a few meters per second. A large change to inclination does not require very much delta-v. The entire planetary system's inclination is few degrees off of the Sun's equator. The momentum required to change an Earth orbit inclination by 1 degree is enough to reverse an Oort cloud object into a retrograde orbit.
The Oort cloud likely started out as a disk. That would be hard to prove. Regardless of how it started the objects will all be in random orbits now.
Likes TEFLing
The table in the link you provided shows that the inclinations of all the major planets except Mercury are within a few degrees of the ecliptic as well. If a passing star were to alter a planet's inclination, it would also by necessity alter it's eccentricity as well, which might be the case for Pluto, or that could just be Pluto's orbit from the beginning. What's more, if the planet's orbital inclination were to be altered, that means that it would also be torqued, so that there would be an unexplained precession of it's orbital plane. The mechanism by which a passing star would destabilize a comet's orbit, sending it plunging towards the Sun, is by gravitationally pulling the comet out of it's orbit, momentarily weakening the Sun's gravitational pull so that the Sun's gravity and the comet's centripetal acceleration are no longer in equilibrium. The comet is further out from it's equilibrium position. After the star has passed, the sun's gravity acts as a restorative force which pulls the comet in passed it's equilibrium position until it enters the inner solar system.
Google can.
Here is is one Marochnik link to an article in Science.
Science 28 Oct 1988:
  1. LEONID S. MAROCHNIK1,
  2. LEV M. MUKHIN1,
  3. ROALD Z. SAGDEEV1
Vol. 242, Issue 4878, pp. 547-550
DOI: 10.1126/science.242.4878.547
On the concept of estimating the angular momentum of the Oort cloud
from abstract:
The mass appears to be approximately 0.03 solar masses, with angular momentum of the order of 1052 to 1053 g-cm2/s. This mass is of the order of the total mass of the planetary system before the loss of volatiles. This leads to an estimate of a mass Mo ≃ 100 M⊕ (where M⊕ is the mass of Earth) concentrated in the Oort cloud (r > 2 x 104 AU) with an angular momentum that may exceed the present angular momentum of the whole planetary system by one order of magnitude.
Hopefully this will help other non-Physicist viewers of this thread (like me) to see @Vanadium 50 's point - the angular momentum of the Oort cloud is not small and definitely not zero.
Likes TEFLing
The thing about the Oort cloud is that it's really far away. Angular momentum is r x p. And since r is really, really big...
According to a discussion on Quora, the estimated current mass of the Kuiper belt is 1/25-1/10 ##M_{earth}##; that its original mass is estimated to have been 300x higher; and that the current mass of the Oort cloud is estimated to be 5 ##M_{earth}##.
The Kuiper belt mass discrepancy is similar to the Oort cloud mass. Perhaps the Oort cloud represents perturbed Kuiper belt objects? If so, the Oort cloud has been "puffing up" not flattening over the eons
  2. LEV M. MUKHIN1,
from abstract:
After reading Marochnik's 1988 paper, it appears that what he was primarily interested in doing was upgrading the estimate of the total mass of the Oort cloud. He accomplished this by revising the mass spectrum and albedo based on observations of Halley's comet two years before. With a much lower albedo, due to a "crust" of organic compounds created by cosmic rays acting on methane, his estimate of the number of comets that went unobserved, and hence the total mass of the cloud, skyrocketed. This gave a total mass of about a hundred Earth masses, but due to a revision of his mass spectrum others determined it to be more like five Earth masses.The amount of total angular momentum does sound large; but when distributed among all bodies, their mean velocity at the distance of the Oort cloud is about half a kilometer per second. Now this amount is a scalar sum over all bodies without regard for their orientation, while angular momentum is a vector; since this is based on an extrapolation, not observations, we have no way of knowing their orbits' orientations...An excerpt from a 1991 paper entitled "Dynamical History of the Oort Cloud" in the book "Comets in the Post-Halley Era" with Weissman as one of the authors - "...stellar perturbations eventually cause the comets to attain a nearly isotropic velocity distribution, with a median inclination to the ecliptic of 90 degrees..." So, so far there doesn't seem to be any preferential direction for cometary orbits which would be expected if the Oort cloud had a global net angular momentum. As an aside, it seems that lately it's been determined that comets are perturbed towards the inner solar system by tides induced by the galactic disk, and not by stellar encounters as previously thought.
  • #31
Marochnik has several papers dealing with the Oort cloud. I had seen references to them. Thanks for the clarification. But. It remains that the Oort cloud has non zero angular momentum. IMO.
  • #32
https://www.sciencedirect.com/science/article/pii/001910359190097D
abstract:
Marochnik et al. (1988, Science 242, 547–550) estimated that the angular momentum of the Oort cloud is between 5 × 1052 and 2 × 1053 g cm2 sec-1, two to three orders of magnitude greater than the total angular momentum of the planetary system. However, most of the angular momentum in the present-day Oort cloud is the result of the action of external perturbers over the history of the solar system. In addition, some Oort cloud parameters used by Marochnik et al. tend to be higher than current best estimates. It is shown that the total angular momentum of the current Oort cloud is likely between 6.0 × 1050 and 1.1 × 1051 g cm2 sec-1, and the original angular momentum was likely a factor of 5 less than that.
Another non-zero estimate. Simply assuming zero angular momentum because the estimates are, well, fuzzy, is not logically justified. Why? All of the other objects [in however to define the limits of the solar system] have angular momentum. You could place an object like Deimos at 50,000 AU (one conservative estimate of the outer limits of the Oort Cloud.), then accelerate it. It would have a LOT of angular momentum. Move it out to 100K AU (another different estimate)
and even more angular momentum. I do not think that current technology would be able to "perceive" something like that. You may know. Which is why we get estimates that vary.
https://theplanets.org/deimos/
  • #33
Yes, that lower estimate is from Weissman, but again, that's just a sum of individual values. No one's arguing that individual objects don't have non-zero angular momenta, or that the estimates are fuzzy and therefore don't exist; current observations don't seem to find any preferential direction for cometary orbits - there are just as many prograde orbits as retrograde. Which is why the Oort cloud hasn't settled into a disk, which is the question that began this thread. You're right, we can't observe comets out to the distance of the Oort cloud; they're much too dim. Estimates for their brightness put them at magnitude 60, while the brightness of the background sky is magnitude 27...
Likes Jonathan212 and lomidrevo
  • #34
So speaking generally about formations like the Oort cloud, the Kuiper belt, others that may exist elsewhere, or even smaller-scale ones like the rings of Saturn, why don't they all have zero total angular momentum?
Related to Why hasn't the Oort cloud converged to a disk shape?
1. Why is the Oort cloud not a disk shape?
The Oort cloud is not a disk shape because it is located at the outer edges of our solar system, where the gravitational pull of the Sun is weaker. This allows for objects in the Oort cloud to have more eccentric orbits, meaning they are not confined to a single plane or disk shape.
2. Can the Oort cloud ever become a disk shape?
It is highly unlikely that the Oort cloud will ever become a disk shape. The objects in the Oort cloud are constantly influenced by the gravitational pull of other stars and passing objects, which can disrupt their orbits and prevent them from forming a disk shape.
3. How did the Oort cloud form if it is not a disk shape?
The Oort cloud is believed to have formed from the leftover debris and gas from the formation of our solar system. This debris was scattered in all directions, leading to the Oort cloud's spherical shape rather than a disk shape.
4. Are there any theories about the Oort cloud's lack of a disk shape?
There are several theories about why the Oort cloud is not a disk shape. One theory suggests that the Oort cloud may have originally been a disk, but was disrupted by the gravitational pull of passing stars or galactic tidal forces. Another theory proposes that the Oort cloud was never a disk shape to begin with, but rather formed as a sphere due to the chaotic nature of the early solar system.
5. How does the shape of the Oort cloud affect our understanding of the solar system?
The shape of the Oort cloud has important implications for our understanding of the solar system's formation and evolution. The spherical shape suggests that the early solar system was chaotic and influenced by external forces, rather than a neatly organized disk. It also provides evidence of the vastness of our solar system and the potential for other objects beyond the known planets and Kuiper belt.
  • Astronomy and Astrophysics
