Why have my emoticons disappeared
  • Thread starter edward
In summary, the conversation revolved around the placement and usage of smilies in the forum. Some users prefer typing in the codes, while others prefer clicking on the smilies from a drop-down menu. There was also a discussion about the length of the smilie codes and the reasoning behind it. Ultimately, it was revealed that the smilies were moved from their previous location next to the reply box to the drop-down menu, and the codes were chosen to avoid accidental conversions in equations or other text. Some users also joked about the placement of colons in the conversation.
edward
62
166
The only ones I have dispaly in the subject line.
Look in the pulldown menu next to the smiley face. Right above you. :bugeye:
:redface: OOPS, thanks Doc Al
A change this major should have had a full page ad.
they've moved there for good?
Seems to be an affordable housing issue. Nowawdays, you have 20+ smilies sharing one small space. We have the same problem in California.
...or perhaps for evil. :devil:
:smile:
You have really been on a roll lately, Doc!
Hmmm... thanks for the tip. I've just been typing in the codes, but I prefer clicking.
While we're on the subject, why is it that the 'surprised' smilie doesn't have a trailing colon while all of the others do? Isn't that the 'end smilie' symbol?
It was a typo when setting up the smilies (after the great smilie revolt when Greg attempted to toss out those smilies and move in younger, more voluptuous smilies, and was quickly forced to reinstate our old buddies).
Apparently, the smilies have always been up there in the drop down menu, so were redundant to have hanging out next to the reply box too...not that I had noticed them up in the drop-down menu until they disappeared from next to the reply box either.
I knew about the smilies in the post's toolbox/bar, but the smilies to the side were much more convenient. Fewer clicks. I prefer [click]'smiley' to list->smiley, list->smiley, list->scroll->smiley,... .
While we are on the topic of emoticons/smilies, here's a question to the powers that be: Why do smilies such as :smile:, :biggrin:, :wink:, etc. have such long codes instead of the simpler :), :D, ;)?
I think that's more to avoid errors in the main forums when someone might end up with those characters juxtaposed in an equation or something and wouldn't want them converted accidentally to a smilie. It saves you from having to select that "disable smilies in text" button with those types of posts.
So if I type something between two colons, will I get a randomly generated smilie or just stupid-looking text? :biggrin:
Depending on whose colon it is, you might get slapped. :-p
FAQ: Why have my emoticons disappeared
Why have my emoticons disappeared and how do I get them back?
There could be several reasons why your emoticons have disappeared. It could be due to a software update, a glitch in the system, or a setting change. To get them back, you can try restarting your device, checking your settings, or reinstalling the emoticon keyboard.
Why are some of my emoticons missing while others are still there?
This could be due to compatibility issues with the device or platform you are using. Some emoticons might not be supported on certain devices or operating systems. You can try updating your device or using a different keyboard or platform to see if that resolves the issue.
How can I prevent my emoticons from disappearing in the future?
If your emoticons are disappearing frequently, it could be due to a software glitch or outdated software. Make sure to regularly update your device and keyboard software to avoid any compatibility issues. You can also try using a different keyboard or platform to see if the issue persists.
Can I recover my old emoticons if they have disappeared?
If your emoticons have disappeared due to a software update or glitch, there is a chance that they may not be recoverable. However, if you have backed up your device or keyboard settings, you may be able to restore them from the backup. Otherwise, you may need to manually re-add your favorite emoticons.
Why have my emoticons disappeared only in certain apps or platforms?
Some apps or platforms may have their own set of emoticons and may not support the ones you are used to using. This could be the reason why your emoticons appear to be missing in those specific apps or platforms. You can try using a different keyboard or platform to access a wider range of emoticons.
