MHB Why I Get X & Y Mixed Up When Plotting Graphs
Confusion arises when mixing up the x and y coordinates while plotting graphs, particularly in equations like y = 2/3x. The correct method involves substituting a chosen x value to find the corresponding y value, but errors occur when manipulating the equation incorrectly, such as misinterpreting the relationship between x and y. The discussion highlights the importance of understanding the roles of x and y in equations and emphasizes that operations must maintain the integrity of the original equation. Additionally, the participant struggles with consistently identifying which variable corresponds to which axis, leading to repeated mistakes in plotting. Clarifying these concepts can help improve accuracy in graphing relationships.
Ziggletooth
Ok so I don't know what is wrong with me, but when it comes to graphs I often get x and y mixed up and the whole thing becomes very confusing.
I had this question
plot a graph using y = 2/3x
The answer is:
if x = 3
y = (2/3 * 3) = 2
x = 3, y = 2
and these are integers which can be plotted very easily on the graph.
I got confused and did this
y = 2/3x
(y * 3) = (2/3x * 3)
3y = 2x
(3y / 2) = (2x / 2)
x = 1.5y
Obviously this is very wrong (if x = 3, y = 4.5 which is != 2 as above), but I'm not sure why. This is an equation isn't it? and those are the sort of balancing things you do to solve equations, so why has it gone so horribly wrong?
Mathematics news on Phys.org
I had this question
The answer is:
if x = 3
y = (2/3 * 3) = 2
x = 3, y = 2
y = 2/3x
3y = 2x
(3y / 2) = (2x / 2)
x = 1.5y
When you want to plot the graph of a line $y=ax$, you pick a value of $x$ that you want, say $x_1$, and you find the corresponding $y$, say $y_1=ax_1$ and since $(0,0)$ satisfies the equation of the line, you draw a line that passes through $(0,0)$ and $(x_1,y_1)$.
I'm sorry, I don't think I was clear. I understand that much but I want to know what was wrong with my method, did I do an operation wrong or can you not do it that way, and if so why not? Because it looks like an equation to me and that's how one would usually simplify an equation.
I don't wish to barrage this forum but in addition to that I do have another question. I said at the beginning I seem to get the coordinates x and y mixed up all the time and I can't reliably tell which is which. Here are two questions and both times I got the coordinates mixed up perhaps you can help me understand which is which.
So the first question is to plot
y = 1 2/3x
I do this
y = 5/3x
3y = 5x
and then I plot the coordinates 5,3 because I read it as 'for every 3y there is 5x' I go up 3 places on the y-axis and then along 5 places on the x axis.
The correct answer is 3,5
My brain doesn't seem to jump to this conclusion, so I figure I'll remember that (a * y = b * x) = (a * x = b * y ) that is to say, switch the coefficients because it seems like that works for some reason.
Anyway the next question
Graph the line that represents a proportional relationship between d and t with the property that an increase of 5 units in t corresponds to an increase of 2 units in d.
What is the unit rate of change of d with respect to t? (That is, a change of 1 unit in t will correspond to a change of how many units in d?)
I figure it's 5t = 2d so d = 2/5
Now I go to graph it, but I remember the rule I came up with about switching the coefficients, so I move 2 places on the t axis and 5 places on the d axis... and what a surprise, I got it wrong again it's the other way. I just can't seem to win here.
Can someone help me clear the mist surrounding this concept so I can place the coordinates correctly.
Ziggletooth said:
y = 2/3x
3y = 2x
(3y / 2) = (2x / 2)
x = 1.5y
When you say $$x=3$$, that means you put the 3 where the $$x$$ is!
$$3=1.5y$$.
Now try it.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
