Why ice freezes on the top of a pond
  • Thread starter bobsmith76
  • Tags
    Ice Pond
In summary: Celsius to 6°Celsius, say, the water at the surface of the pond also cools and consequently decreases in volume. This means the surface water is more dense than the water below it, which has not yet cooled nor decreased in volume. As a result, the surface water sinks and warmer water from below is forced to the surface to be cooled, a process called upwelling. When the atmospheric temperature is between 4°Celsius and 0°Celsius, however, the surface water expands as it cools, becoming less dense than the water below it. This causes the surface water to freeze instead
bobsmith76
336
I'm having a little trouble understanding why water freezes on the top. Take this passage:
We can use this unusual thermal expansion behavior of water to explain why a pond freezes slowly from the top down. When the atmospheric temperature drops from 7°Celsius to 6°Celsius, say, the water at the surface of the pond also cools and consequently decreases in volume. This means the surface water is more dense than the water below it, which has not yet cooled nor decreased in volume. As a result, the surface water sinks and warmer water from below is forced to the surface to be cooled, a process called upwelling. When the atmospheric temperature is between 4°Celsius and 0°Celsius, however, the surface water expands as it cools, becoming less dense than the water below it.
Why I don't understand is that the cold water should be on the bottom of the pond since it is more dense and the warm water on top. Given that I would think that ice would form at the bottom of the pond, then rise to top since ice is less dense than water, but that is clearly what does not happen. But why doesn't it happen? I'm guessing the surface water has to first reach 0 Celsius before it can freeze, but when the surface water reaches 0, the bottom water should be about -2 or so since the less dense warm water will be on top. So why isn't the colder water at the bottom freezing than moving to the top, like a backwards ice storm?
Water has lowest density at 4°C. As you cool water bellow 4°C, long before it begins to freeze, liquid water already starts getting less dense. As a result, if the water in the pond is all between 0°C and 4°C, the least dense water in the pond is at 0°C, just ready to freeze. And so it surfaces and freezes at the surface.
The reason water close to 0°C is less dense than water at 4°C has to do with how water molecules align. At 4°C, the alignment is more or less random, but as temperature drops, the hydrogen bonds start aligning water molecules into lattice they will form once the freezing process begins. So you end up with clusters of "almost ice" in the fluid, which are significantly less dense than liquid water. The average density begins to decrease.
This effect is present above 4°C as well, but isn't significant, allowing normal thermal expansion to dominate temperature-dependence of density. So at 4°C you end up with the maximum density.
good questions.. i also have trouble to understand
hi bobsmith76! :smile:
bobsmith76 said:
… When the atmospheric temperature is between 4°Celsius and 0°Celsius, however, the surface water expands as it cools, becoming less dense than the water below it.
no, when the water is below 4°, the cold water is less dense, and should be (and is) on the top
the bottom water stays at 4° until the ice reaches it!
thanks, i get it now.
Related to Why ice freezes on the top of a pond
1. Why does ice form on the top of a pond?
Ice forms on the top of a pond because water is less dense as a solid than as a liquid. When the temperature drops, the molecules in water slow down and move closer together, causing them to form a crystalline structure and expand. This expansion causes the ice to be less dense than the surrounding liquid water, causing it to float on the surface.
2. How does this phenomenon affect aquatic life?
The formation of ice on the top of a pond can have a significant impact on aquatic life. It acts as an insulating layer, helping to maintain a more stable water temperature and protecting the organisms living below from extreme cold. However, if the ice becomes too thick, it can limit the amount of sunlight and oxygen that can reach the water, potentially harming the plants and animals living in the pond.
3. Why does ice form on the top of a pond in layers?
Ice forms in layers on the top of a pond because as the temperature continues to drop, new layers of ice are formed on top of the previously formed layers. This occurs because the colder, denser water sinks to the bottom of the pond, while the warmer, less dense water rises to the surface and freezes.
4. How does the shape and depth of a pond affect the formation of ice?
The shape and depth of a pond can greatly affect the formation of ice on its surface. In shallow ponds, the water will freeze more quickly and uniformly due to the lack of depth. In deeper ponds, the water at the bottom may remain liquid for longer, allowing for more movement and preventing the formation of a thick layer of ice on the surface.
5. Can wind affect the formation of ice on a pond?
Yes, wind can have a significant impact on the formation of ice on a pond. Wind can cause the surface of the water to move and mix, preventing it from freezing in one solid layer. It can also break up existing ice and move it to other areas of the pond, creating open patches of water that can freeze at a later time.
  • Thermodynamics
  • Thermodynamics
  • Mechanical Engineering
  • Classical Physics
