blanxink
- 1
In an exercise with included solution I can't understand how integrating sin^2(ωt) gives T(period)/2
[itex]\int[/itex]sin^2(ωt)dt = Period/2
I posted the whole problem below, because I had more doubts, but understood them typing up the problem.
I appreciate any help.
YOU CAN SKIP THE PROBLEM
The probelm
A circular coil, r=10 and Ω=1.5Ω, rotates around its diameter with a constant ω0 in a uniform and constant magnetic field B that forms an angle of θ=∏/3 with the axis of rotation of the coil.
Knowing that the maximum current Imax=0.15A, and that the component of B parallel to the axis of rotation is Bparall=1.0T, find
1) intensity of B
2) angular velocity ω0 of the coil
3) energy needed per rotation to keep the angular velocity ω0
The solution included on teh book
my problem in in red
1) B=Bparallel/cosθ=2Bparallel=2.0T
I did the same, so no problem here.
Bperp(responsible for the current in the coil)=Bparallel*tanθ=Bparallel√3
2) fem=-dphi/dt=∏*r^2*ω*Bperp*sin(ωt), max fem when sin(ωt)=1,
ω0=R*I/(∏*r^2*Bperp)
3)To get the work, i integrate over one turn, so over the period T=2∏/ω
W= [itex]\int[/itex]R*I^2*dt = R*Imax^2[itex]\int[/itex]sin^2(ωt)dt = R*I^2*Period/2
I don't get how do you integrate sin^2(wt) and get T/2?
The probelm
1) intensity of B
