Why is 1^(1/6) equal to cis(n*pi/3)?
  • Thread starter dsanz
In summary: Hence the principle 6th root of 1 is 1.In summary, the problem is asking to find all the sixth roots of 1, which are complex numbers that satisfy z6 - 1 = 0. These roots are equally spaced around the unit circle and can be found using the Theorem of De Moivre. The principal sixth root of 1 is 1, but there are five other roots, one of which is -1, and the other four are complex numbers.
dsanz
42
Hi, I have a doubt concerning the following simple problem. This is actually a textbook problem, so the answer is correct. I just want to understand why this is.
1^(1/6) = exp ((1/6)(2n*[tex]\pi[/tex]i)) = cos (n*[tex]\pi[/tex]/3) + i sin (n*[tex]\pi[/tex]/3)
where n = 0,1,2,3,...
Ok, it is comprehensible that for n=0 we get cos(0) = 1, which is equal to 1^(1/6) = 1
However, I can't grasp why with n=1, for example, cis (n[tex]\pi[/tex]/3) is still equal to 1. In that case we would have cos([tex]\pi[/tex]/3) + i sin([tex]\pi[/tex]/3). How can that be equal to 1?! It has an imaginary part! Not even the real parts are equal.
The pi's appear as exponentials for some reason. Anyway, you get what I'm saying.
Mathematics news on Phys.org
Check out this http://en.wikipedia.org/wiki/Root_of_unity" while I look for the recent thread that discusses this...
It just happens that cos(0) = 1. More to the point here is that [cos(0)]^6 = 1
No, it's not equal to 1, but [cis (1[itex]\pi[/itex]/3)]^6 does equal 1.
You can minimize this by using [ itex] tags for inline LaTeX.
The numbers cis (n[itex]\pi[/itex]/3) for n = 0, 1, 2, 3, 4, and 5 are the 6th roots of 1. Most of them are complex, but if you raise any of the to the 6th power, you get 1.
Yeah I get it. It's just very weird... you can conclude that 1^(1/6) is not equal to 1... because cis (pi/3) is not 1, but cis ((pi/3))^6 is.
Another way to look at this is that you are solving z^6 - 1 = 0. There are 6 values of z that are solutions, two of which are 1 and - 1. The other four are complex.
Aren't we getting into the "principle" root thing again?
Which is why I'm trying to steer it in the direction of finding the solutions of z^6 - 1 = 0.
May I ask what the principle root thing is?
No, you have to have at least ten posts to ask 2 questions in one thread.
Juuuuust kiddin.
When we say "the square root of 9", there is an implied understanding that we mean the POSITIVE square root. It can be ambiguous because there are two numbers that equal 9 when squared.
Extend this to the SIXTH root (or n-th root). There are 6 (or n) roots of 1 , but when we say the "sixth root of 1" (or "the n-th root"), we mean the "principle"/positive/simplest one.
There has to be a better way to determine it in general, as I'm sure (and hoping!) Mark44 will point out.
OK, I'll give it a shot.
The problem as posed at the beginning of this thread is essentially "find all of the sixth roots of 1." That is equivalent to solving the equation z6 - 1 = 0 in the complex numbers. The principal sixth root of 1 is 1, but there are five others, one of which is -1. The other four are complex.
They can be found using the Theorem of De Moivre.
z6 - 1 = 0 ==> z6 = 1 = cos(0 + n*2pi) + isin(0 + n*2pi), n [itex]\in[/itex] I
==> z = (cos(n*2pi) + isin(n*2pi))1/6, n [itex]\in[/itex] I
==> z = cos(n*2pi/6) + isin(n*2pi/6), n [itex]\in[/itex] I
In the last equation, when n = 6, we have the same complex number as when n = 0, and when n = 7, we have the same complex number as when n = 1, so we keep repeating the same 6 complex numbers. For that reason, it suffices to say that n = 0, 1, 2, 3, 4, or 5.
So we have 6 distinct complex values, all equally spaced around the unit circle. Each of them is "a" sixth root of 1, but the principal sixth root of 1 corresponds to n = 0, and is cos(0) + isin(0) = 1 + i0 = 1.
FAQ: Why is 1^(1/6) equal to cis(n*pi/3)?
How is 1 raised to the power of 1/6 equal to cis(n*pi/3)?
This is because the expression 1^(1/6) represents the sixth root of 1, which can be written as e^(i*n*pi/3) in polar form. This is equivalent to cis(n*pi/3) which represents the complex number with a magnitude of 1 and an angle of n*pi/3.
What does the "cis" notation in the expression cis(n*pi/3) mean?
The term "cis" stands for "cosine + i sine" and is used to represent complex numbers in polar form. It is used to simplify expressions involving trigonometric functions and complex numbers.
Why is the angle in the expression cis(n*pi/3) always a multiple of pi/3?
This is because the expression 1^(1/6) represents the sixth root of 1, and there are six solutions to this equation, each separated by an angle of 2*pi/6 or pi/3. Therefore, the angle in the expression cis(n*pi/3) will always be a multiple of pi/3.
Can 1^(1/6) be written in any other form?
Yes, 1^(1/6) can also be written as e^(i*n*2*pi/6) or e^(i*n*4*pi/6), which are equivalent to cis(n*pi/3). However, the most commonly used form is cis(n*pi/3) due to its simplicity.
How is the expression cis(n*pi/3) useful in mathematics?
The expression cis(n*pi/3) is useful in mathematics because it allows us to easily represent complex numbers in polar form, which is often more convenient for calculations involving trigonometric functions. It also helps in simplifying complex expressions and solving equations involving complex numbers.
