Why is (1/2,1/2) the vector representation?
In summary, the conversation is about the difficulty of solving an exercise involving the Lorentz group representations in the book "Quantum Field Theory in a Nutshell" by Zee. The exercise asks to show, by explicit computation, that the Lorentz vector is represented by the (1/2,1/2) representation. This involves understanding the generators of the Lorentz group and their relation to the Pauli matrices. The conversation also touches upon the association of fields with abstract representations, which is a complicated mathematical problem.
Mesmerized
54
Hello,
I'm reading Zee's book 'Quantum Field Theory in a Nutshell', the chapter about Lorentz group representations at the moment. In the end of the chapter there is suggested an exercise - "Show by explicit computation that (1/2,1/2) is indeed the Lorentz vector". And I just can't figure it out.
Here' s a little background. Lorentz group has 6 generators - 3 rotations [itex]J_i[/itex] and 3 boosts [itex]K_i[/itex] with commutation relations
[itex][J_i,J_j]=i\epsilon_{ijk}J_k, [J_i,K_j]=i\epsilon_{ijk}K_k, [K_i,K_j]=-i\epsilon_{ijk}J_k,[/itex]. We define [itex]J_{+}=1/2(J_i+i K_i), J_{-}=1/2(J_i-i K_i)[/itex], which now satisfy the SU2 groups commutation relations [itex][J_{+i},J_{+j}]=i\epsilon_{ijk}J_{+k},[J_{-i},J_{-j}]=i\epsilon_{ijk}J_{-k},[J_{+i},J_{-j}]=0[/itex], which means that Lorentz group is isomorphic to SU2[itex]\otimes[/itex]SU2.
Now coming back to (1/2,1/2) representation, it means that [itex]J_+[/itex] as well as [itex]J_-[/itex] are represented by 1/2 representation of SU2, i.e. by [itex]1/2\sigma_i[/itex], the Pauli matrices. Here comes the first misunderstanding, Pauli matrices are 2 by 2 matrices, Lorentz generators (therefore [itex]J_{+}, J_{-}[/itex] too, as they are just the sum of the Lorentz matrices) are 4 by 4.
As I couldn't solve it I decided to go backwards. J's and K's can be represented by
[tex]
J_1 =
\begin{bmatrix}
0 & 0 & 0 & 0\\
0 & 0 & 0 & 0\\
0 & 0 & 0 & -i\\
0 & 0 & i & 0\\
\end{bmatrix}, etc,
K_1 =
\begin{bmatrix}
0 & 1 & 0 & 0\\
1 & 0 & 0 & 0\\
0 & 0 & 0 & 0\\
0 & 0 & 0 & 0\\
\end{bmatrix}, etc
[/tex]
therefore, for example [itex]J_{+1}, J_{-1}[/itex] have the following forms
[tex]
J_{+1} =1/2(J_1+i K_1)=1/2
\begin{bmatrix}
0 & i & 0 & 0\\
i & 0 & 0 & 0\\
0 & 0 & 0 & -i\\
0 & 0 & i & 0\\
\end{bmatrix},
J_{-1} =1/2
\begin{bmatrix}
0 & -i & 0 & 0\\
-i & 0 & 0 & 0\\
0 & 0 & 0 & -i\\
0 & 0 & i & 0\\
\end{bmatrix}.
[/tex]
I just can't see how these matrices can be related 1/2 representation of SU2 group, i.e. to Pauli sigma matrices. While the words 'Show by explicit computation' in the exercise tell me, that they somehow should. Any help, even some general sketch of that computation would be much appreciated.
In the (1/2, 1/2) representation, J+ is represented by the tensor product σi ⊗ I, and J- by the tensor product I ⊗ σi which are 4x4 matrices.
The representation (1/2,1/2) of SL(2,C) is isomorphic to the representation of weight 1 of the (restricted homogenous) Lorentz group due to the existence of the Infeld-van der Waerden symbol, [itex] \left(\sigma^{\mu}\right)_{\alpha\dot{\beta}} [/itex]. The direct proof by calculation is done by Wiedemann and Mueller Kirsten in their book on Supersymmetry, Proposition iii), Page 74.
thanks for the answers.
Sam,
this is what I understood from your responses in those threads. (1/2,1/2) is a representation with two indices (dotted and undotted), and each of those two 1/2 representations acts on the corresponding index. I understand this part. Then, as you write, "It (the representation with two indices) can be identified with vector field via"
[tex]\Psi_{r\dot{r}}=V_μ(x)(σ^μ)_{r\dot{r}}.[/tex]
I guess this equation somehow contains the answer to my question, but I can't see how. The right hand side of this equation reminds me of the discussion, which leads to equivalence of Lorentz transfomations and SL(2,C) group. But how will I get some Lorentz transformation from Pauli matrices of those two 1/2 representations still puzzles me.
Hi, check the source I gave you above and note one more thing. The direct product of 2 copies of SU(2) is a double-cover of the compact SO(4) group (which contains only rotations in a 4D flat space), not of the Lorentz group which is non-compact due to the boosts (sub)manifold being homeomorphic to R^3.
hi dex, thanks for the hint, I will check.
Mesmerized, Put together the responses you've gotten so far, and they seem to be saying it will be necessary to master the representations of the Lorentz group in order to solve this simple exercise. Well if that's what you'd like, and you have the time for it, by all means do so.
But I had the impression that your main interest is reading along further in Zee, and you should stop and ask yourself what his aim was in posing this exercise, and how Zee expects you to approach it. It says "explicit calculation", and to do this you do not need the Infeld-van der Waerden symbol, or the two-fold covering, or any of the other stuff.
You were initially on the right track in the OP, so you just need to continue with what you began. Zee wants you to write out the six 4 x 4 generators in terms of Pauli matrices. Then compare them to the 4 x 4 generators acting on the four components of a vector. And see that the two sets are the same!
Sam,
The problem of associating fields (geometrical objects on space-time) with the abstract representations (of any Lie group) is a bit complicated (mathematical) problem. So, at least for now, you will be better off taking the following as a rule.
Since the dimension of [itex]( j_{ 1 } , j_{ 2 } )[/itex] is [itex][ n ] = ( 2 j_{ 1 } + 1 ) ( 2 j_{ 2 } + 1 )[/itex]. You can identify the representation [itex]( j_{ 1 } , j_{ 2 } )[/itex] with n-component field (on space-time) transforming under [itex]SO(1,3)[/itex].
To each [itex]SL( 2 , C )[/itex] transformation of the hermitian spinor-tensor [itex]\psi_{ r \dot{ r }} \in ( 1/2 , 1/2 )[/itex]:
[tex]
\psi_{ r \dot{ r } } \rightarrow A_{ r }{}^{ s } \bar{ A }_{ \dot{ r } }{}^{ \dot{ s } } \psi_{ s \dot{ s } }, \ \ \ ( A, \bar{ A } ) \in SL( 2 , C ) ,
[/tex]
there corresponds a Lorentz transformation of a real 4-component vector, [itex]V_{ \mu } ( x ) \in M^{ ( 1 , 3 ) }[/itex], in the Minkowski space-time:
[tex]
V_{ \mu } ( x ) \rightarrow \Lambda ( A )_{ \mu }{}^{ \nu } \ V_{ \nu } ( x ) , \ \ \ \Lambda ( A ) \in SO( 1 , 3 ) .
[/tex]
It is easy to verify this, if you know that the “connection” [itex]( \sigma^{ \mu } )_{ r \dot{ r } }[/itex] behaves as a spinor-tensor under [itex]SL( 2 , C )[/itex], and as a 4-vector under [itex]SO( 1 , 3 )[/itex]. Indeed, we have the following identity
[tex]
A_{ r }{}^{ s } \bar{ A }_{ \dot{ r } }{}^{ \dot{ s } } ( \sigma^{ \mu } )_{ s \dot{ s } } = \Lambda_{ \nu }{}^{ \mu } ( \sigma^{ \nu } )_{ r \dot{ r } } .
[/tex]
Sam
Related to Why is (1/2,1/2) the vector representation?
1. Why is (1/2,1/2) the vector representation?
The vector representation (1/2,1/2) is typically used to represent a unit vector that is halfway between the x-axis and y-axis in a Cartesian coordinate system. This vector has a magnitude of 1 and an angle of 45 degrees, making it a convenient representation for many mathematical operations.
2. How is (1/2,1/2) related to unit vectors?
In a Cartesian coordinate system, unit vectors are vectors with a magnitude of 1 and are used to represent the direction of each axis. The vector (1/2,1/2) is a unit vector that lies halfway between the x-axis and y-axis, making it a useful representation for certain mathematical operations.
3. Why is (1/2,1/2) often used in 2D graphics?
In 2D graphics, (1/2,1/2) is often used to represent the direction of a diagonal line or the direction of a rotation. Its convenient angle of 45 degrees and magnitude of 1 make it a useful representation for these types of operations.
4. Is (1/2,1/2) the only vector representation that can be used?
No, there are many different vector representations that can be used depending on the context and the specific mathematical operation being performed. However, (1/2,1/2) is a commonly used representation due to its simplicity and convenience.
5. Can (1/2,1/2) be used in higher dimensions?
Yes, (1/2,1/2) can be used in higher dimensions as well. In 3D graphics, for example, it can represent a unit vector that is halfway between the x-axis and y-axis in the xy-plane. In general, the vector (1/2,1/2) can be used in any dimension to represent a unit vector that is halfway between two coordinate axes.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
