Why is a leading figure of 1 so special in uncertainties?
In summary: This is because rounding the uncertainty down to one significant figure would give a leading figure of 1, so we keep the next digit (0) as well to have two significant figures. This ensures that the overall answer is accurate and reflects the level of uncertainty in the measurement. In summary, when rounding uncertainties in physics, if the leading figure is a 1, we use two significant figures, otherwise we use one significant figure. The answer should then be rounded to match the decimal place of the uncertainty. This is to ensure that the overall answer is accurate and reflects the level of uncertainty in the measurement.
Valour549
57
"The uncertainty should be rounded off to one or two significant figures. If the leading figure in the uncertainty is a 1, we use two significant figures, otherwise we use one significant figure. Then the answer should be rounded to match."
"Here’s a rule of thumb you can rely on: round the uncertainty to one significant figure. Then round
the answer to match the decimal place of the uncertainty. One exception to the rule of thumb: If rounding the uncertainty to one significant figure would cause that figure to be a 1, then you keep the next digit as well."
Both the quotes are taken from leading universities such as Harvard, regarding the number of significant figures to keep (in uncertainties in Physics), and they both say the same thing.
So my question is: Why is a leading figure of 1 so special in uncertainties (in physics) that the said uncertainty deserves two significant figures, as opposed to just one sig fig?
Look at it this way: 2 is 100% more than 1, while 3 is only 50% more than 2 (and progressively less). Thus, if your uncertainty estimate is better than 50% precise, you should include one extra digit if it is somewhere between 1 and 2.
Hmm I kinda get what you mean, but not entirely clear. Where are you getting the 50% from (...better than 50% precise)?
Say we get a value of 5.64 with uncertainty 0.73, we write our answer as 5.6+-0.7 because the extra 0.03 (only 4.3% of 0.7) is meaningless if we're already unsure about the 0.7? Do correct me if I'm wrong.
Now we have a value of 5.64 with uncertainty 0.13, we write our answer as 5.64+-0.13, because the 0.03 is actually 30% of 0.1? Is this what you mean?
But then what about 5.64 with uncertainty 0.98? According to the rules described we should not round the uncertainty to one sig fig (and cause the figure to be 1) and get an answer of 6+-1. Instead we should leave it as 5.64+-0.98. Why?
Yes.
Well, no. The rules are a bit sloppily described. It should be "If rounding the uncertainty down to one significant figure would cause that figure to be a 1, then you keep the next digit as well."
By the way - here is a list of numbers between 1 and 10 with constant relative precision (rounded to one decimal).
1.0
1.3
1.6
2.0
2.5
3.2
4.0
5.0
6.3
7.9
Hey you're reading taylor too!
Thanks for the answer btw I was actually curious about that rule too.
1.0
1.3
1.6
2.0
2.5
3.2
4.0
5.0
6.3
7.9
What do you mean by constant relative position? Could you kindly clarify?
I still don't get where the 50% comes from. Thanks.
Also my example of 5.64 with uncertainty 0.98, is the correct answer 6+-1, or 5.6+-1.0?
No, sorry. I just did some maths.
Precision, not position. Every number is about 27% greater than the previous number.
5.6 ± 1.
Related to Why is a leading figure of 1 so special in uncertainties?
1. What is a leading figure of 1?
A leading figure of 1 refers to the first significant digit in a measurement or calculation. It is the digit that represents the highest order of magnitude in the number.
2. Why is a leading figure of 1 important in uncertainties?
The leading figure of 1 is important in uncertainties because it indicates the level of precision in a measurement. It tells us how many significant figures are reliable in the measurement and helps us understand the level of uncertainty present in the data.
3. How does a leading figure of 1 affect the accuracy of a measurement?
The leading figure of 1 does not necessarily affect the accuracy of a measurement. It is a representation of the precision or uncertainty in the measurement. However, if the leading figure of 1 is not significant or is uncertain, it could indicate a possible error in the measurement.
4. Can a leading figure of 1 change in different calculations?
Yes, a leading figure of 1 can change in different calculations depending on the level of precision of the measurements used. In some cases, it may be more significant while in others it may be less significant or uncertain.
5. How can we use the leading figure of 1 to make more accurate measurements?
By using more precise instruments and techniques, we can reduce the level of uncertainty in our measurements and obtain a more significant leading figure of 1. It is also important to properly record and report all significant figures in a measurement to ensure accuracy.
  • Other Physics Topics
15K
  • Classical Physics
