I Why is an iron cover needed for a solenoid?
  • I
  • Thread starter Thread starter yaxlei
    Iron Solenoid
An iron cover is essential for a solenoid as it enhances the magnetic circuit by concentrating magnetic flux lines, which increases the magnetic flux density. This increased density leads to a stronger magnetic force, as the force generated by a solenoid is proportional to the square of the magnetic flux density. By reducing leakage flux with a high-permeability jacket, more flux is contained within the solenoid, resulting in greater efficiency. The design of modern magnets allows for effective force generation across various shapes. Overall, the iron casing significantly improves the solenoid's performance.
yaxlei
Hi everyone,
I've heard that it's better to close the "magnetic circuit" of a solenoid by adding a metal casing around the coils, but I don't get why : people say that it's for focusing the magnetic flux lines but how does it increase the force generated by the solenoid ?
Thanks if you reply, have a nice day.
by concentrating the magnetic field in the coil of the solenoid
The magnetic force is proportional to the square of the magnetic flux density.
Likes sophiecentaur and yaxlei
. . . . . and having the same flux across a small area of gap gives a much higher flux density than when the flux is spread over the whole of space around the coil. You put the armature where the gap is and that gives more force.
The old magnets were nearly all Horseshoe shaped so that you could get a worthwhile flux density somewhere, at least. Modern permanent magnets of all shapes can be strong enough to do a useful job.
yaxlei said:
Hi everyone,
With the hi-mu jacket the leakage flux is greatly reduced.
Analytically, when you run the usual amperian loop inside & outside the solenoid there is less of the B integral outside the coil. So that means more flux inside.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
