Why Is an Object's Weight Equal to the Force of Gravity It Experiences?
In summary, an object's weight is equal to the force of gravity it experiences because weight is defined as the gravitational force acting on an object due to its mass. This relationship is described by Newton's second law of motion, where weight (W) is calculated using the formula W = m × g, with 'm' representing mass and 'g' the acceleration due to gravity. Thus, an object's weight directly correlates with the gravitational pull exerted on it by a planet or other celestial body.
  • #36
adjurovich said:
I don’t think astronomers can stand?
Do you mean astronauts? Astronomers use telescopes, astronauts fly spaceships.
  • #37
Thanks for pointing out, it made me laugh really hard :smile:
  • #38
adjurovich said:
I will point something out. Weight is defined, here where I live, as the force that object exerts on other objects when it’s standing
As I've indicated, I take "weight" as the downward inertial force on an object arising from an accelerating reference frame, from gravity or from both taken together.
Normally, this is a distinction without a difference. For a stationary object subject to no forces other than the support force of interest, the interaction force of the object against its support will be equal to the net inertial force on the object.
That is part of how bathroom scales work. They require the user to stand still and ignore the buoyancy from bathroom air.
Questions (about language usage, not about physics):
For you, does your "weight" increase as you jump into the air and as you land from a jump? Are you "weightless" in between?
For you, does your "weight" decrease when you are wading in a swimming pool?
  • #39
1. Yes, you are weightless during the free fall
2. Yes, it does decrease when you are wading in swimming pool
Likes jbriggs444
  • #40
Ibix said:
The point is that all of them are (approximately) affected the same way by gravity so they have zero acceleration with respect to each other so do not see effects we commonly think of as due to gravity. That's why they are called "weightless". But the "approximate" part is neglecting tidal forces, and sufficiently precise experiment can detect them. So even "weightless" you can, if sufficiently careful, detect the presence of gravity.
They are affected the same way by gravity whether the gravitational field is either uniform or null (flat spacetime). In that case there is no spacetime curvature, i.e. no tidal forces or geodesic deviation.
  • #41
I don’t think Sir Isaac Newton had an idea of what spacetime curvature is?
  • #42
adjurovich said:
I am not from the USA / UK and here we have kinda different terminology. Weight is usually considered to be the pulling force exerted on rope / force that body exerts on surface (the one of which reaction pair is the normal force ##\vec{N}##).
Weight is the force that would make a body accelerate at a rate equal to the local freefall acceleration.
adjurovich said:
However we have the other thing that I wouldn’t be sure how to directly translate, probably something like Earth’s force of gravity? The force that Earth exerts on all objects in its atmosphere. That’s why I started this thread quite some time ago
The force of gravity.
The two are very nearly the same and are often erroneously equated. The weight is actually a bit less than the gravitational force due to the effect of Earth's spin.
  • #43
Right, because the local freefall acceleration is zero.
No. Weight doesn't include the effects of buoyancy.
Freefall is, by definition, in a vacuum.
  • #44
PeroK said:
It's possible of course to define the weight of a body of mass m as simply W=mg. Often, however, astronauts in the space station are described as weightless - which clearly contradicts this definition.
Not if you go with the officially-sanctioned definition of weight. It's the force that would make a body accelerate at a rate equal to the local freefall acceleration. Therefore it's zero in the orbiting ISS because ##g## is zero.
  • #45
That's interesting. What precisely is "officially sanctioned"?
  • #46
Following a reference from NIST, I found ISO 80000-4 where:
transcription by hand from a rotated PDF said:
Item: 4-9.2
Symbol: ##F_g##
Quantity: Force (Item 4-9.1) acting on a body in the gravitational field of Earth.$$F_g=mg$$where m (item 4-1) is the mass of the body and ##g## is the local acceleration of free fall (ISO 80000-3)
Unit: $$N$$ $$\text{kg} \text{ m} \text{ s}^{-2}$$
Remark: In colloquial language the term "weight" continues to be used where mass is meant. This practice should be avoided.
Weight is an example of a gravitational force. Weight comprises not only the local gravitational force but also the local centrifugal force due to the rotation of the Earth
This definition seems pretty restrictive. Using this definition, one could not meaningfully ask "what would your weight be on the moon?".
However, this is not the only "officially sanctioned" meaning.
In commerce (as opposed to in science, engineering or physics pedagogy) in the U.S. the term "weight" or, in particular, "net weight" has a government mandated operational definition as a mass, not a force. This is just as well since we would not want a bottle of ketchup or a box of Cheerios to have the correctness of its label depend on the city in which it is vended.
Likes PeroK
  • #47
International Organization for Standardization, International Standard ISO 31-3, Quantities and Units, Part 3: Mechanics (ISO, Geneva, Switzerland, 1992).
"The weight of a body in a specified reference system is that force which, when applied to the body, would give it an acceleration equal to the local acceleration of free fall in that reference system."
Note that when we write the expression ##w=mg## we can use the above standard in which case ##g## is the local free fall acceleration and ##m## is the inertial mass.
An alternative definition would be to refer to ##w## as the gravitational force, which would make ##m## the gravitational mass, and people using this definition would refer to ##g## as the acceleration due to gravity. They would then refer to the above as the "apparent weight".
The difference is of course due to Earth's spin. My observation is that the free fall acceleration varies from about 9.747 9.781 N/kg at the equator to 9.832 N/kg at the poles. This is a difference of about 0.051 N/kg. About 2/3 of this difference is due to Earth's spin, the other 1/3 being due to the equatorial bulge.
People who round ##g## to 9.81 N/kg or 9.80 N/kg are using values that include the effects of Earth's spin. Yet some of them will erroneously refer to it as the acceleration due to gravity. If they were really using the acceleration due to gravity they would not be including the effects of Earth's spin and the value of ##g## would vary from about 9.781 9.815 N/kg at the equator to 9.798 9.832 N/kg at the poles, due to the equatorial bulge. No way they'd get the rounded-off values they use! unless they insisted that it rounds to 9.80 N/kg at the poles, and to heck with what it is right here where we're using it!
Note: Edited to correct mistakes made in the calculations.
Likes PeroK
  • #48
And that would be especially true if it were a bar of gold instead of a bottle of ketchup or a box of cereal.
  • #49
And by the way, while I'm on my little rant, I'll point out that the pound Avoirdupois, which is the pound used throughout the USA and many other places, is by international treaty, exactly 0.453 592 37 kg.
In other words, it's officially a unit of mass, not force.
Throughout the ages the pound with its various definitions has always been a unit of mass. It is called a unit of weight only in the sense described in the last paragraph of Post #46. It is not, and never has been, a unit of force, despite what many textbooks would have you believe.
Why would merchants buy and sell commodities based on a unit of measure that varies with location?!
Likes adjurovich and jbriggs444
  • #50
Nevertheless, the informal use of "pound" as a unit of force, instead of the more precise term "pound-force", is rather common. For example:
ACDelco digital torque wrench (amazon.com)
Easy to read LCD display with measurements (kg-cm, N-m, in-lb. ft-lb)
which also has "kg" instead of "kgf".
Likes jbriggs444 and adjurovich
  • #51
It's nearly ubiquitous in introductory physics textbooks. Even NASA uses it. Nevertheless, there is no officially-sanctioned definition of the pound-force.
jtbell said:
For example:
The kilogram-force was officially dropped by the SI as of, IIRC, 1960. Prior to that a so-called standard value of ##g## equal to 9.806 65 N/kg was used to define the kilogram-force. It was simply an invention designed to allow the measurement of mass using units of force. There is no place on Earth where ##g## has a value of 9.806 65 N/kg for any significant length of time.
Unfortunately, no such standard value was ever adopted for the definition of the pound-force, although the above value appears to be used by NASA for their definition. So they end up defining the pound-force as the product of 0.453 592 37 kg and 9.806 65 N/kg, resulting in an unjustifiably large number of significant digits.
  • #52
According to the Wiki article the figure was the result of a measurement (made in 1888 in Paris) and a correction (specified in the previous year by the CIPM) to obtain a corresponding estimate applicable to 45 degrees latitude).
Wisely, no one bothered to correct the figure to account for more accurate gravitational measurements obtained in the years since.
Likes Mister T
12K
11K
18K
