Prof. Hawking
- 4
I am preparing a report on black holes and I recently learned about a phenomenon I was previously unaware of: the photon sphere of a black hole. While reading an article on said occurrence (I have now confirmed this on multiple sources) the photon sphere which is the minimum distance anything (in this case light) can orbit from a black hole and the photon sphere is the lower bound where only something going at the speed of light (photons) can orbit.
However the distance from the singularity for this boundary is 1.5 times as far as the event horizon is from the center of the black hole. From what I understand the equation for the velocity required to orbit an orbit an object stabely is v=sqrt((2GM)/r) where G is the gravitational constant M is the mass of the object being orbited and r is the distance from the center of mass of the object ( I found this equation on physicsforums here https://www.physicsforums.com/threa...-speed-for-putting-an-object-in-orbit.299929/). However the formula for escape velocity (the event horizon in the case of a black hole) is v=sqrt((GM)/r).
These formulas would show that to escape from the gravity of a body takes much more energy than to orbit it from the same distance however the speed of light is not enough to orbit outside the minimum escapable distance at the speed of light if this distance is inside the photon sphere so I am rather confused.
what I found to be the formula for minimum velocity to be in a stable orbit v=sqrt((2GM)/r)
escape velocity v=sqrt((GM)/r)
