Why is completeness important in characterizing ordered fields?
In summary: Every Cauchy seq converges completeness means that for every sequence there exists a convergent sequence. Least Upper Bound completeness means that for every sequence there exists a sequence such that the length of the longest element of the convergent sequence is less than or equal to the length of the longest element of the sequence.
Bachelier
376
This is not a homework problem. I came across this in an analysis book:
In a complete ordered field (not specifically R) a member that is not zero is positive ⇔ this member is a square.
WHY?
How can we prove it?
Is this similar to Hilbert's 17th problem?
All complete ordered fields are isomorphic, so you can call anyone of them "the" field of real numbers. What you're saying is that if x≠0, then x>0 and there exists a y such that y2=x. The first part of this is clearly not true for x=-1, so I assume that you meant to say that if x>0, then there exists a y such that y2=x, i.e. that every positive real number has a square root.
I don't immediately see how to prove this, and I have to go out for a while. But I might try to prove it later if no one else has posted the proof or a link to it by then.
I guess we can rephrase the question like that.
But it is a bi-condition. It says: a non-zero element in a complete field is positive it is a square.
if complete means lub complete then all are isomorphic but not if it only means cauchy complete. then you have to say complete archimedean ordered field. (of course lub complete implies archimedean)
If this is to be interpreted as "x is non-zero and positive, if and only if x is a square", then the word "non-zero" adds nothing, since "positive" in this context should mean >0 which implies ≠0.
Thanks for explaining that. I've been wondering why some people throw the word "archimedean" in there.
True. I guess it helps in limiting the cases in the converse proof.
I still don't see where to start going from x is positive then there exist a y s.t. x= y2
I'm sure this is proved in lots of books, but I decided to leave my Rudin on my bookshelf and just think about it. It's clear that the axioms for ordered fields aren't enough, because ℚ is an ordered field that has an element that doesn't have a square root. So we have to use that supremum thingy.
Can't we just define y=sup{z|z2<x} when x>1, y=inf {z|z2>x} when x<1, and y=1 when x=1? (I haven't thought this through to the end).
Edit: The full proof is on page 10 of Rudin's "Principles of mathematical analysis", but you can probably find it any analysis book. He doesn't treat x>1 and x<1 separately. I'm not sure why I did. After defining y=sup{z|z>0,z2<x}, he proves that y2=x by showing that y2<x and y2>x both lead to contradictions. (D'oh, I didn't include the condition z>0 in my definition).
Makes sense. Thanks for making that connection. I haven't digested well that part of the proof. time for a review.
I will type something later here to have a complete proof.
What would be the difference between Every Cauchy seq converges completeness and Least Upper Bound completeness. Is it because one is topological and the other isn't?
thx.
FAQ: Why is completeness important in characterizing ordered fields?
1. What is the "Complete Fields" property?
The "Complete Fields" property is a feature found in various scientific software and databases that allows for the automatic population of data fields. It is typically used to streamline the data entry process and reduce errors.
2. How does the "Complete Fields" property work?
The "Complete Fields" property works by using algorithms and pre-existing data to predict and fill in missing or incomplete data fields. This can save time and improve accuracy in data entry.
3. What are the benefits of using the "Complete Fields" property?
The main benefits of using the "Complete Fields" property include increased efficiency in data entry, reduced risk of errors, and improved data consistency. It can also save time and effort for scientists and researchers.
4. Are there any limitations to the "Complete Fields" property?
While the "Complete Fields" property can be a useful tool, it is not foolproof. It relies on pre-existing data and algorithms, so it may not accurately fill in all fields. Additionally, it may not work well with complex or unique data sets.
5. How can I ensure the accuracy of data populated by the "Complete Fields" property?
To ensure accuracy, it is important to regularly review and verify the data filled in by the "Complete Fields" property. It is also helpful to have a good understanding of the data being entered and to regularly update and maintain the pre-existing data used by the property.
