Why is component reverse in Conical Pendulum?
In summary, the conversation discussed the confusion about the components of a conical pendulum, particularly the x-component which is often associated with the sine function but can also depend on the angle θ and the direction of motion. It was clarified that the x component should be determined based on the right triangle formed by the motion, and not solely on the trigonometric function used. Overall, it was emphasized to use trigonometry to accurately determine the components of the pendulum's motion.
soccer5454
Hello. In class today, we studied conical pendulum but I was confused at the part about its components. In all the diagrams ( http://dev.physicslab.org/img/90c0fb7a-ffb4-4573-b389-b50a559732c8.gif ) if shows The x-component as being sine, but I always thought x-comp was cos?? ( http://faculty.ccbcmd.edu/~jzelinsk/phys_101/chapter3/chapter3.htg/img2.gif )
Also for equations I made them
T cos(θ) = mv2/r
T sin(θ) = mg
But teacher say it is wrong and it should be other way but I don't understand, please help!
Often the direction of a vector is specified by the angle the vector makes with respect to the x axis, as in your second link. What about θ in your first link?
But even it was at a different spot, wouldn't the horizontal always be cos?
Look at the figure below. How would you use trig to find the lengths of the green and red sides of the triangle?
Green would be sin and red would be cos. so
T cos(θ) = mv2/r
T sin(θ) = mg
Yes, that's right.
so
T cos(θ) = mv2/r
T sin(θ) = mg
Which side of the triangle "points toward the center" of the circular motion of the pendulum bob?
Red line I believe
Where is the center of the circular motion in the picture in your first link? Is it to the left of the mass, to the right of the mass, above the mass, or below the mass?
I think its to the left
Yes.
So, according the the figure below, which component of the tension points toward the center of the circular motion? The green component or the red component?
Green comp
Yes. So, which component should be set equal to mv2/r?
sine!:)
Good.
Just a quick question,so the x-comp can always change? So it is not always cos or sin but it depends on where the center of motion is right?
The x component is not always obtained by using cos(θ). It depends on whether or not θ is measured from the x axis. Whenever you are in doubt, construct a right triangle and use trig to get the x and y components.
Oh ok got it thanks :)
Related to Why is component reverse in Conical Pendulum?
1. Why does the component reverse in a conical pendulum?
The component reverses in a conical pendulum due to the principle of conservation of energy. As the pendulum swings, it constantly exchanges kinetic energy for potential energy, causing the component to reverse direction.
2. What is the impact of gravity on the reverse component in a conical pendulum?
Gravity plays a crucial role in the reverse component of a conical pendulum. It acts as a restoring force, pulling the pendulum back towards its equilibrium position and causing the component to reverse direction.
3. How does the length of the string affect the reverse component in a conical pendulum?
The length of the string has a direct impact on the reverse component in a conical pendulum. A longer string will result in a larger conical angle, leading to a greater reverse component. Similarly, a shorter string will result in a smaller conical angle and a smaller reverse component.
4. What is the relationship between the mass of the pendulum and the reverse component in a conical pendulum?
The mass of the pendulum does not have a direct effect on the reverse component in a conical pendulum. However, a heavier pendulum will have a greater inertia, which can affect the speed of the pendulum and thus the reverse component.
5. Can the reverse component in a conical pendulum be eliminated?
No, the reverse component cannot be eliminated in a conical pendulum as it is a result of the exchange of energy between kinetic and potential energy. However, the reverse component can be reduced by minimizing external forces such as air resistance and friction.
