Why is convolution used to represent LTI output?
In summary, convolution is a linear operation that sums up the effects of successive inputs. It is useful for systems that need to respond to short impulses, and it is often modeled by the impulse response function.
Nikitin
735
27
Hi. If you have a LTI system with an impulse response function ##h(t)## taking in an input ##x(t)##, why does its output ##y(t)## become
I realize ##y(t)## not only depends on the instantaneous input ##x(t)##, but also on the lingering effects of previous inputs ##x(\tau)## with ##\tau < t##. But how does the convolution integral model this?
Likes Stephen Tashi
OK I found a mathematical proof on wikipedia. It is coherent, but gives zero physical insight (is this the norm in EE?).
http://en.wikipedia.org/wiki/LTI_system_theory#Continuous-time_systems
However, why does the input ##x(u)## and output ##y(t)## have different domains there? Is it because the range of ##y(t)## is directly dependent on every element in the range of ##x(t)##?
There are LTI systems that do not need to be represented by a convolution. So I think the best intuitive approach is to ask why the most general LTI system is represented by a convolution and why all apparently simpler LTI systems can be regarded as being implemented by a convolution.
Suppose the rule for a system S(t) is "the output y(t) is 4 times the input x(t)".
The notation for this can be confusing, since S can be regarded as function t, but we are also thinking of it as function of x(t).
So , abusing notation, S(t) = S( x(t) ) = 4 x(t).
This system is linear. S( A g(t) + B r(t)) = A S(g(t)) + B S(r(t)).
The output is shift invariant in the sense that S(t-h) = S(x(t-h)) = S applied to input function evalated at t-h..
A slightly more general system is
S(t) = S( x(t)) ) = 4 x(t) + 3 x(t-1) + 2 x(t+1)
This is also linear and shift invariant.
This suggests a more general form for LTI systems is:
[itex] S(t) = \sum_{i=0}^N A_i x(t-h_i) [/itex] where the [itex] A_i [/itex] and [itex] h_i [/itex] are constants.
If the [itex] h_i [/itex] are all distinct numbers then we can define a function [itex] g(h) [/itex] that maps the value [itex] h_i [/itex] to the coefficient [itex] A_i [/itex]
Rewriting the above summation in terms of g():
[itex] S(t) = \sum_{i=0}^N g(h_i) x(t - h_i) [/itex]
To further generalize, we replace summation by integration
[itex] S(t) = \int_H g(h) x(t-h) dh [/itex] where [itex] H [/itex] is the range of values that [itex] h [/itex] may take.
Likes Nikitin
Mathematical solutions are deliberately generalised to avoid physical insight as that makes mathematics universally applicable.
So, without using mathematical symbols, why convolution? The important thing is that, being linear, there is no cross-modulation of the signals in the system. All the different frequencies in the response are therefore amplitude and phase independent of each other. The transfer function is then simply the amplitude and phase response of the system to any sinusoidal stimulation. That is not true, as you suggest in the time domain, where all the stimulations and responses are summed in all of time.
Likes Nikitin
I have a more intuitive means of appreciating the power of convolutions.
If you think of the LTI as it responds to a short impulse, you have the impulse function.
If you imagine the input signal as a stream of impulses of various magnitudes, you can imagine the system responding to each impulse.
If you graph the response to the first impulse, then graph the response of the second response under it, and continue making graphs down the page, you'll see that the responses are all the same except for magnitude and a slight delay to account for when each impulse happens.
Now, if you make a "totaled" graph at the bottom by adding the values of each graph (y_total(t) = x1(t) + x2(t) +x3(t)... ) above, you get the cumulative effect of the signal over time.
This is essentially what happens when you perform the integration, but this has always seemed "right" to me as it allows you to better imagine the process behind the math.
Likes Nikitin
The way I look at it, the contribution to the output that input x() makes is "locally linear". At t -h it adds some constant multiple of x(t-h) to the output at t. So you can think of the net output as a sum of the form g(h)x(t-h) where g(h) is a function that tells you what constant to multiply x(t-h) by. (This probably amounts to the "impulse response" view.) If the contribution of the input at t-h was a nonlinear expression like [itex] (x(t-h))^2 [/itex] then the output wouldn't be a linear function of the input.
Likes Nikitin
The simplest way to think about convolution is that for a system that responds immediately that is linear, we get y(t)=hx(t). If it doesn't respond immediately, we can try y(t) =h(0).x(t) + h(1).x(t-1) + h(2)x(t-2) + ..., which written in summation notation is y(t) = sum {h(n)x(t-n)} which is the convolution.
An explicitly non-convolutional form for an LTI system is dy/dt = -y + x. Here I chose the minus sign so that the system doesn't explode when the input x is zero. I think you can show using the impulse response view (make x a delta function) and linearity for superposition to get the convolutional form out of it. I'm not sure I got everything there correct, but you can google "Green's function" for the thing that translates between the differential and integral forms for LTI systems. Also, here I've only used 1 variable.
http://en.wikipedia.org/wiki/Green's_function
http://en.wikipedia.org/wiki/Impulse_response
When one goes to nonlinear systems, the most "general" "nonexploding" convolutional TI approximator in some sense is Volterra series. This precise conditions of this theorem is given by Boyd and Chua http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.126.9363. The usual convolution is just the linear term of the Volterra series.
Related to Why is convolution used to represent LTI output?
1. What is the purpose of using convolution to represent LTI output?
The purpose of using convolution is to mathematically model the output of a linear, time-invariant (LTI) system when given an input signal. It allows us to determine the output signal by convolving the input signal with the impulse response of the LTI system.
2. How does convolution help in understanding LTI systems?
Convolution helps in understanding LTI systems by providing a way to analyze their behavior and predict their outputs for different inputs. It allows us to break down a complex input signal into simpler components and then use the properties of LTI systems to determine the output signal.
3. Can other mathematical operations be used instead of convolution to represent LTI output?
No, convolution is a specific mathematical operation that is used to represent LTI output. Other operations, such as addition or multiplication, cannot accurately model the behavior of LTI systems.
4. Why is convolution considered a powerful tool in signal processing?
Convolution is considered a powerful tool in signal processing because it allows us to analyze and manipulate signals in the time domain. It is also computationally efficient and can be easily implemented using digital signal processing techniques.
5. Are there any limitations to using convolution to represent LTI output?
Yes, convolution assumes that the LTI system is time-invariant and that the input and impulse response are known. In real-world scenarios, these assumptions may not hold true, which can affect the accuracy of the output signal predicted by convolution.
  • Electrical Engineering
  • Topology and Analysis
