Why is cos(1/n) an increasing function?
In summary: This equation is telling you that cos(x) is decreasing for 0<x<pi/2 which means that if we take a positive integer n, then 1/n > 1/(n+1) and as such, because cos(x) is decreasing, cos(1/n) < cos(1/(n+1))Thanks!You're welcome! And by the way,I thought my n+1 > n method was valid most (if not all) functions. Obviously not :(
phyzz
35
I have the series an = (-1)^{n} cos(1/n) and I have to determine whether it converges or diverges.
I used the Leibniz criterion
However, I determined that bn = cos(1/n) is a decreasing function because:
n+1 > n
1/(n+1) < 1/n
cos(1/(n+1)) < cos(1/n)
ie cos(1/(n+1)) - cos(1/n) < 0
so bn+1 - bn is < 0 meaning it's decreasing no?
I said it diverged because lim n -> ∞ bn = 1 (and not 0 which is the condition for it to converge)
I got the answer correct, but for the wrong reasons...
How do you show that cos(1/n) is an increasing function? Or any function for that matter? I thought my n+1 > n method was valid most (if not all) functions. Obviously not :(
Thanks a lot!
phyzz said:
1/(n+1) < 1/n
Is this true? Think about the value of cos(x) for x approaching zero.
I don't know whether it's true or not, that's the thing
cos(x) x approaching 0 is 1 right?
[cos(1/n)]' = - sin(1/n) / n^2
ie f'(n) < 0 for all n because of the negative sign, so it should be decreasing?
ok I understood
n+1 > n
1/(n+1) < 1/n
sin(1/(n+1)) < sin(1/n)
ie sin(1/(n+1)) - sin(1/n) < 0
BUT if it's cos:
n+1 > n
1/(n+1) < 1/n
cos(1/(n+1)) > cos(1/n)
ie cos(1/(n+1)) - cos(1/n) > 0
gonna learn it like:
cos of something with a larger denominator is > cos of something with smaller denominator and
sin of something with a larger denominator is < sin of something with smaller denominator
Yes, cos(x) is decreasing for 0<x<pi/2 which means that if we take a positive integer n, then 1/n > 1/(n+1) and as such, because cos(x) is decreasing, cos(1/n) < cos(1/(n+1))
Thanks!
What I wanted you to think about is that as x approaches 0 (thus getting smaller and smaller) then the value of cos(x) approaches 1 (thus getting bigger and bigger).
phyzz said:
1/(n+1) < 1/n
Just in case it's not entirely clear to you, when
x < y,
it follows
f(x) < f(y)
only if x and y are both contained in a range for which f(x) is a monotonically increasing function: f'(x) > 0.
If the function is monotonically decreasing (f'(x) < 0) on a range for which both x and y are in, then
f(x) > f(y).
This second case corresponds to the problem here.
Lastly, note that these are not the only possibilities. If f(x) is not monotonic on a range that contains both x and y, you can get any of f(x) < f(y), f(x) > f(y) or f(x) = f(y) for x < y. For example, if ##y = x + 2\pi##, then x < y, but for f(x) = cos(x), f(x) = f(y).
##\frac{d}{dn} \cos{(\frac{1}{n})} = - \sin{(\frac{1}{n})} \cdot (- \frac{1}{n^2})##
You missed a minus sign.
FAQ: Why is cos(1/n) an increasing function?
The function cos(1/n) is an increasing function because as the value of n decreases, the value of 1/n increases. As a result, the input for the cosine function (1/n) becomes smaller, causing the output to increase in value. This trend continues as n approaches 0, resulting in an overall increase in the function.
How does the graph of cos(1/n) show that it is an increasing function?
The graph of cos(1/n) shows an upward trend as n decreases. This can be observed by plotting various values of n and observing that the corresponding values of cos(1/n) are increasing. Additionally, the derivative of cos(1/n) is positive for all values of n, indicating that the function is increasing.
What is the domain and range of the function cos(1/n)?
The domain of cos(1/n) is all real numbers except 0, as division by 0 is undefined. The range of the function is [-1, 1], as the cosine function outputs values between -1 and 1 for any input.
Can you provide a real-life example of a situation where cos(1/n) would be an increasing function?
One real-life example of a situation where cos(1/n) would be an increasing function is a pendulum. As the pendulum swings back and forth, the angle of the pendulum decreases, causing the value of 1/n to increase. This results in an overall increase in the cosine function, as the angle of the pendulum decreases.
How does the concept of periodicity relate to the function cos(1/n) being an increasing function?
The concept of periodicity, which refers to a function repeating its values in a regular pattern, relates to the function cos(1/n) being an increasing function. As n decreases, the values of cos(1/n) repeat in a regular pattern, resulting in an overall increase in the function. This is due to the periodic nature of the cosine function, which repeats its values in a pattern as the input changes.
