Why is Cramer's rule for determinants not 'symmetric'?
In summary, Cramer's rule can be used to solve non-homogeneous equations in matrix form, but it is only valid when replacing the columns. Swapping rows and columns will change the determinant, which is why it cannot be used for finding solutions to non-homogeneous linear equations. This is because the columns in A represent the coefficients for each variable, so swapping rows would not give the correct coefficients for solving the equations.
Jinius
we can solve non-homogeneous equations in matrix form using Cramer's rule. This rule is valid only if we are replacing the columns. Why can't we replace the rows and carry on the same? For eg we can use elementary transformations for obtaining inverses either via rows or via columns.
But we can't find solutions to non homogeneous linear equations by replacing rows. Could someone please explain this? I am in a need
Mathematics news on Phys.org
You can! Who told you you can't? Swapping rows and columns will not change a determinant.
Au=v
Yes, but in Cramer's rule you plug v as a column in A, so you swap certain data. If you plug v as a row in A, you will swap another data, and the determinant will certainly change.
As to the question itself, I think that's how it is. In this order (Au=v) the columns of A are the coefficients of each variable u1,2,3,... Therefore to pull data on u1 you will have to swap the first column and not the first row.
I am asuming that, by "using rows rather than columns, the OP simply meant taking the transpose. Otherwise, the question just doesn't make sense.
of a response
Cramer's rule is a method for solving systems of linear equations by using determinants. It involves replacing one column of the coefficient matrix with the constants from the right-hand side of the equations and then calculating the determinant of the resulting matrix. However, this method cannot be applied by replacing rows instead of columns.
This is because Cramer's rule relies on the properties of determinants, which are not symmetric when it comes to rows and columns. When we replace a column with the constants, we are essentially creating a new matrix with the same number of rows and columns as the original matrix. This is necessary for calculating the determinant, as it is only defined for square matrices.
On the other hand, if we were to replace a row with the constants, we would end up with a matrix that has a different number of rows and columns, making it impossible to calculate the determinant. Furthermore, the properties of determinants do not hold when we replace rows instead of columns, making the resulting solution invalid.
In short, the reason why Cramer's rule is not 'symmetric' is due to the properties of determinants and the requirement for square matrices. While we can use elementary transformations to find inverses by replacing rows or columns, this method does not apply to solving non-homogeneous linear equations using Cramer's rule.
Related to Why is Cramer's rule for determinants not 'symmetric'?
1. Why is Cramer's rule for determinants not "symmetric"?
Cramer's rule for determinants is not "symmetric" because it involves a division by the determinant of the original matrix, which is not necessarily the same as the determinant of the transpose of the matrix. This leads to different solutions for the same system of equations depending on which version of the determinant is used.
2. What is the difference between the determinant and the transpose of a matrix?
The determinant of a matrix is a scalar value that represents the "size" or "stretch" of the matrix. It is calculated by multiplying the elements of the matrix in a specific way. The transpose of a matrix is the same matrix flipped along its main diagonal. This means that the rows and columns of the transpose are switched.
3. Why is Cramer's rule used in solving systems of linear equations?
Cramer's rule is used as an alternative method for solving systems of linear equations when traditional methods like elimination and substitution are not feasible. It involves using determinants to find the unique solution to the system of equations.
4. Can Cramer's rule be used for any size of matrix?
Yes, Cramer's rule can be used for any size of matrix as long as the matrix is square (meaning it has the same number of rows and columns). However, as the size of the matrix increases, the calculations become more complex and time-consuming.
5. What are the limitations of using Cramer's rule for solving systems of linear equations?
Cramer's rule can only be used to solve systems of linear equations with the same number of equations as variables. It also becomes increasingly complex and time-consuming as the size of the matrix increases. In addition, Cramer's rule relies on the existence of a unique solution, which may not always be the case for certain systems of equations.
  • General Math
  • Linear and Abstract Algebra
  • Quantum Physics
