Why is current in Van De Graaff generator so low?
In summary, a Van deGraaff generator poses no serious shock hazard, as all the charges are taken to the ball on the moving insulated belt. Current is rate of flow of charge. Few charges per second equals low current.
weezy
92
I know that current depends on the impedance and potential difference b/w two points so why does a van de graaff generator pose no serious shock hazard i.e. why the extremely low current between the generator and ground? As seen in this video demonstration the instructor safely touches the generator and ground:
It's simply because all the charges are being taken to the ball on the moving insulated belt. Those charges are formed on the belt at the bottom by electrostatic induction and the rate they are produced is very small. Current is rate of flow of charge. Few charges per second equals low current.
@sophiecentaur gave you the right answer. A belt picking up one electron at a time is no competition for a wire for conducting currents.
As a college student, I met Doctor Van De Graff. He was very proud of his invention. A company was making large quantities of large Van De Graff generators for use in making heat-shrinkable plastic. They may still use the same method of making heat-shrink today, but I don't know.
Likes Wrichik Basu and weezy
for me, and maybe the OP, that doesn't even begin to answer the question, as it is not about the charge transfer to the dome from the belt rather it is about the transfer from a dome that is now fully charged to a person/other object
The dome sitting at say 250kV and discharging into some object is a higher rate of current flow.
I have just finished reading a dozen links on google and none of them gave any sort of answer regarding current flow from a charged sphere to an object is so low.
One description read that it max's at around 200mA and others commented that the sphere can be considered a constant current source
It does appear as tho it is all about impedance ...
the impedance between the sphere and a discharge want is much lower than that between the sphere and a hand on the sphere ... hence the larger flow of current via the spark discharge ?Dave
Likes Wrichik Basu, weezy and sophiecentaur
From what I read a current of 6mA is enough to shock you on dry skin. While it's true charge build up is slow on a Van De Graff generator it still says that to achieve a potential that big a huge amount of charge is needed and if you touch the ground while touching a generator it should shock you appreciably. Given it's DC and human skin resistance is around 1Mega Ohm
Is it because of the short duration of shock?
You can look at it as a high resistance (charges carried by the belt at a slow rate) and a small capacitance to Earth. At 250kV (on a good day) and with not many pF, the charge available is very small.
Likes davenn
But isn't a lot of charge required to reach the potential in the first place?
Q=CV
If you have a small capacitance, you only need a small charge to reach a high voltage. That's why Van deGraaff generators are approved for Schools; you really can't harm anyone with one of those. Wimshurst Machines, on the other hand, are not allowed anywhere near a School because the Leydon Jar capacitors ('Condensers') have a significant capacitance.
Likes Jehannum and weezy
If it makes a flash every 3 seconds, then discha
The deceiving part is the impressive lightning flashes. Unlike natural lightning, these flashes have very low currents. That is why the humans don't get injured.
. . . . and charge. In the end, it's total charge passed that governs the damage done. Initial current from a 250kV source through a human will be very high ( a substantial fraction of an Amp, even). That current is only sustained for a very short while (fraction of a millisecond) so it's harmless.
Likes Delta2 and weezy
Capacitance is very relevant here. If you get a chain of half a dozen kids to hold hands, standing on plastic buckets, with one end attached to the Van de Graaf (switched 0ff). Then start the motor and wait a minute or so. The total capacitance of kids plus ball is much greater and will give a seventh kid much more of a belt when they touch one of the charged kids.
Yes I agree it's the short duration which makes the current spark sting from a V.D generator but nothing lethal
So the potential should go down right? With C increased so much?
Leakage may get worse and limit the final volts a bit but with a higher C, it just takes longer to charge up. The input current is, as always, limited by belt speed and rate of deposited charges on the best.
Likes weezy
Related to Why is current in Van De Graaff generator so low?
1. Why does the current in a Van De Graaff generator decrease over time?
The current in a Van De Graaff generator decreases over time due to the buildup of static charge on the dome. As the charge builds up, it creates a repulsive force between the dome and the surrounding air, making it more difficult for electrons to be transferred to or from the dome.
2. What factors affect the current output of a Van De Graaff generator?
The current output of a Van De Graaff generator is affected by several factors, including the size and shape of the dome, the type of material used for the belt, and the humidity of the air surrounding the generator. Additionally, the speed and direction of the belt and the presence of any external sources of charge can also impact the current output.
3. Why is the current in a Van De Graaff generator often described as "leaky"?
The current in a Van De Graaff generator is often described as "leaky" because it is constantly losing energy due to the buildup of charge on the dome. As the charge builds up, it creates a repulsive force that pushes electrons away, reducing the overall current output of the generator.
4. How can the current in a Van De Graaff generator be increased?
The current in a Van De Graaff generator can be increased by increasing the size of the dome, using a more efficient belt material, or reducing the humidity in the surrounding air. Additionally, the use of a charge collector or grounding the dome can help to maintain a higher current output.
5. Can the current in a Van De Graaff generator be dangerous?
The current in a Van De Graaff generator can be dangerous if proper safety precautions are not taken. While the current output is typically low, the high voltage produced by the generator can still pose a risk of electric shock. It is important to always follow safety guidelines and use caution when operating a Van De Graaff generator.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
