Why is "dr" not used for moment of inertia calculations?
In summary: I think you should be able to work on some of this stuff now, but maybe Student100 knows your situation better than I do. I don't know what your course is like, what your background is, or the like. So, I'll defer to him.In summary, when calculating the moment of inertia for a rotating object, the distance variable "dr" is not incorporated into the integral, but the mass variable "dm" is. This is because "dr" is already taken into consideration in the form of "r" in the integral, which represents the perpendicular distance from the axis of rotation. The use of "r" instead of "dr" is due to the simplification of the integral
Ehden
29
When calculating the moment of inertia for a rotating object, why is "dr" not incorporated into the integral? However, dm is part of the integral, isn't the distance from the axis of rotation changing as well? Hence shouldn't the integral involve both dm and dr?
Can you show us an example of an moment of inertia calculation that you're wondering about? The simpler and more symmetrical it is, the better.
Likes Ehden
It IS taken into consideration.
dm = ρ dV
So for, say, a spherical mass distribution, you get
dm = ρ r2 sinθ dr dθ dφ
There's your "dr" there!
Zz.
Likes Ehden
However, watch out for the different kinds of "r"s. The "r" that matters in a moment of inertia calculation (dI = dm⋅r2) is the perpendicular distance from the axis of rotation, whereas the "r" in spherical coordinates is the distance from the origin (usually the center of a spherical distribution).
Likes Ehden
Thanks for all your responses.
So generally, I = Σmiri2 = ∫r2dm
Why is the r2 left as a constant? Isn't it also changing depending on where the dm is located?
I asked this question to a physics major, and he said I should just take it as it is because I only know up to single variable calculus. He said, the integral is a multivariable integral involving dr as well. Not sure if he's correct though.
Did you even read my post?!
Oy vey.
Zz.
Likes Ehden
Oy vey.
Zz.
Oh, I don't know how I skipped your post.
I don't if I'm correct though, but, isn't that multivariable calculus? I'm still taking single variable at the moment. So I guess, dr is taken into consideration, but, I should just take the general formula as it is given?
Or in general, why is the r left as a constant in ∫r2dm?
Because the prereq for the course probably didn't include multivariate calculus. Just asking why it's left constant doesn't mean a whole lot without context, but generally in these courses where they try to keep things simple they will use some sort of symmetry or constraints to avoid math students haven't had yet.
You'll see this a lot in E&M.
Likes Ehden
The course just requires calc 2, or a coreq in calc 2. Currently I'm taking calc 2, so I guess I should just take this general formula as is?
However, I do plan to take mechanics, which requires multivariable, I guess that's where the proof for r2 will be explained?
That reminds me, my professor showed the class a differential equation for harmonic motion, and the answer to it. Since it's a certain class of differential equations and the class hasn't done differential equations, he said we should just take the answer for what it is. I guess it's the same for this case?
I second Nugatory's request. It would prevent a lot of confusing guessing if you could give us a specific example of the kind of calculation you're thinking of.
Likes Ehden
A simple one would be a uniform rod. The method would involve ∫r2dm. However, I was confused as to why r2 is left as a constant. Since r is changing compared to where dm is, so shouldn't r also be represented as dr?
But, Student100 told me to just take the equation for what it is, since it involves higher level math (multi-variable), which I haven't taken yet.
It's not quite the same, since moment of inertia for things like thin rigid body rods with fixed axis of rotations that are highly symmetrical (##dm = \rho dl## ... etc.) are fully accessible.
The differential equation for simple harmonic motion should also be accessible, but is easier with auxiliary equations which you probably haven't see yet either.
Edit: Tried to clean it up, think I'm confusing myself here.
Errr, uniform thin rod is perfectly accessible. So in that case, you're looking a specific example of a fixed axis of rotation with a rigid body.
The moment of inertia when we constrain ourselves to rigid bodies around fixed axis's of rotation depends on the mass distribution of in the body with respect to the axis of rotation. ## I = \int r^2 dm## where ##dm = \rho dV## and r is the perpendicular distance to the axis of rotation.
For a uniformly thin rigid rod with mass M and length L you have get $$I = \int r^2dm$$ where if we choose our coordinate system so that the rod lays in the x-axis with the fixed axis of rotation around the origin at the middle of the rod it then becomes $$I = \int_{-L/2}^{L/2} x^2 dm$$ With ##dm = \frac{M}{L} dx## so $$I = \frac{M}{L} \int_{-L/2}^{L/2} x^2 dx$$
Basically, you're integrating over r. r (as the location of the axis of rotation) is also a constant (not changing, stays at origin) in this case. You can have other cases were r changes with time, etc, etc. Maybe it would make more sense to call the distance from the axis of rotation another variable.
Likes Ehden
Student100 said:
It's not quite the same, since moment of inertia for thing like rigid body rods with fixed axis of rotations (##dm = \rho dl##) are fully accessible.
Errr, Rod is perfectly accessible. So in that case, you're looking a specific example of a fixed axis of rotation with a rigid body. |r| is then constant.
Okay, I think I found the solution to my dilemma. Since, the distance from each point mass is r distance away, hence, r is changing, but, the mass at each point is the same for a uniform rod. So we represent the small changes in mass by dm, so we can replace it with a density formula to represent the change in r?
r isn't changing, the distance the mass elements are from r is.
Likes Ehden
Oh, I thought r represented the distance between the mass element and the axis of rotation. Thus, r should be different for every mass element.
ZapperZ said:
This is getting convoluted!
Can you please look at this page and see if you can sort out your understanding here?
http://hyperphysics.phy-astr.gsu.edu/hbase/cm.html
Zz.
I actually read that page and it just added to my dilemma. From the diagram the distance for each xi is different, just as how the masses are different. So why is x represented as a constant in the integral?
The same goes for r2. Like Student100 mentioned, r is a constant and not the distance from the axis of rotation for each element of mass. I thought of r as x is show in the diagram. Except that origin point is the axis of rotation.
I'm just confusing myself now, I've had a lot of different responses.
I still don't understand why you keep thinking that the coordinate variable is a "constant". I will say it once again, this time with emphasis, so that you pay attention:
LOOK AT THE EXPRESSION FOR dm!
For the rod, dm can be written in terms of the linear mass density and... get this... dx!
The position of each mass element is contained in dm, because it has a "length" factor! So you are integrating the mass element over x!
This is no different than when I showed you what happened with a spherical mass distribution earlier where "dr" is actually part of dm!
You need to sit down and figure out why this is not sinking in for you even after you've been told of this several times on here.
Zz.
Likes Ehden
Zz.
I've been receiving different responses that have been confusing me. I should've mentioned, my notion of using calculus may have been wrong. I forgot that dx represents a minute change, and the distance x is basically broken down to small elements of dx using the linear mass formula, as dm correlates with the width of dx.
Check out this link: http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html and scroll down to Moment of Inertia Examples. For a rigid body, we consider the body to be made up of small elements, dm, at distance r from the rotation axis. Each element contributes r2dm to the moment of inertia, which his found by integrating over all the elements: ∫r2dm. If all elements are not at the same distance from the axis, then as ZapperZ showed by example, the expression for dm will contain dr.
Likes Ehden
Meant to add: in general you don't have a d- for every variable in an integral. You determine the elemental expression, such as r2dm, and then you integrate over whatever d- you have in that expression.
Likes Ehden
Oh man! I understand now! It just clicked for me! I was looking at the expression the wrong way!
Thank you all for the help! This feeling of struggling to comprehend something then finally understanding it, it's just impalpable!
Likes jtbell
Its must've been asked like this.
Why dI = r^2 dm.
I believe dI = dmr^2 at first. And r^2 just got excluded from the d.
That's mean r^2 should be a constant, but r^2 is not a constant. It keep changing too.
Related to Why is "dr" not used for moment of inertia calculations?
1. Why is "dr" not used for moment of inertia calculations?
Moment of inertia is a measure of an object's resistance to rotational motion, and is calculated by summing the product of each particle's mass and its distance from the axis of rotation squared. "dr" is not used in this calculation because it represents an infinitesimally small change in the distance, and does not accurately reflect the actual distribution of mass in the object.
2. What is the significance of using "r" instead of "dr" in moment of inertia calculations?
Using "r" instead of "dr" allows for a more accurate calculation of moment of inertia, as it takes into account the distribution of mass in the object rather than assuming an infinitesimally small change in distance. This is important because the distribution of mass affects an object's rotational motion.
3. Can "dr" be used in any other types of calculations?
While "dr" is not used in moment of inertia calculations, it can be used in other types of calculations such as finding the volume of a solid using integration. In this case, "dr" represents a small change in radius, rather than a change in distance from an axis of rotation.
4. Are there any other variables used in moment of inertia calculations?
In addition to "r," other variables commonly used in moment of inertia calculations include "m" for mass, "I" for moment of inertia, and "ω" for angular velocity. These variables are used in different equations to calculate moment of inertia for different types of objects.
5. How is moment of inertia related to an object's shape?
Moment of inertia is directly related to an object's shape, as it takes into account the distribution of mass around an axis of rotation. Objects with a larger moment of inertia require more torque to rotate, meaning their shape affects their rotational motion. For example, long, thin objects have a larger moment of inertia compared to compact, dense objects of the same mass.
  • Mechanics
  • Mechanics
  • Mechanics
