Why is Earth made of Iron and Stone?
  • Thread starter zadignose
  • Tags
    Earth Iron
In summary, Sagan explains that stars fuse hydrogen into helium, and then if a star is big enough it creates higher order elements in later stages, before going supernova.
zadignose
In Cosmos, Sagan explains to us laymen that stars fuse hydrogen into helium, and then if a star is big enough it creates higher order elements in later stages, before going supernova.
What isn't explained is why such a high proportion of heavier elements (heavy relative to hydrogen) collect to form planets. I can *assume* that the heavier elements come together first, in the earth, in the sun, in all of the planets, and that only the larger objects capture and hold the lighter elements. IF this were so, then I'd expect that the Sun contains far more iron and stone than the Earth in terms of mass, but less as a percentage of total mass. That is, I'd expect the sun to be built upon a foundation of heaver elements which had been ejected from supernovae. I'd *expect* this, but it wasn't stated or explained, so I just don't know.
Now, if this is the case, does it suggest that the sun also contains a center consisting of Uranium, maybe even Plutonium or other elements? If traces of Uranium are a part of the Earth's constitution, I'd think there should be much more within the sun. Or, do these elements undergo fission in the early evolution of a small star?
Astronomy news on Phys.org
The sun does contain a far greater amount of iron and the elements that comprise stone. The planets nearest the sun are 'rocky' because the gaseous elements were too warm to freeze out and have very low densities in the gaseous state. So, the 'wind' from the birthing sun carried biggest part of them off to the outer solar system - where the gas giants now reside. There is stone out there too, just a much higher percentage of these lighter materials.
Well, I doubt that they stay in the center. The Sun is pretty hot, so they'd be diffused throughout it. But at any rate, yes, we can be pretty certain that there's a lot more heavy elements in the Sun than there are in the Earth, it's just that the Sun is over 300,000 times more massive.
So the picture here is that the Sun formed first, and then when it formed nearly all of the lighter elements were blown away from the inner solar system, leaving only rocky planets behind.
Thanks folks, this makes sense.
That also explains why outer-Solar-System objects are so icy -- water and ammonia and methane could condense out there.
The Sun contains about 1.5-2.0% of elements heavier than helium, what astrophysicists confusingly call "metals". Most of the "metals" are carbon, nitrogen and oxygen. You can look up the abundances of the elements relative to hydrogen on the Web. You're quite right about there being more of the metals in the Sun than in the planets - there's about 16-22 Jupiter masses of "metals" total mixed in with all the hydrogen and helium.
^ I think this is most right. Still in proportion, its not too significant. A freshly born sun is still mostly H and He. I never really thought about that though. That probly explains the huge magnetic field as well. Who knows what's truly at the very very center. Maybe the H fuses around a radius of liquid metal soup composed of everything from Li -> Fe, with trace amounts of heavier elements from a previous supernova. It could even be the same for the gas giants at their centers, but not massive enough to fuse.
I doubt the metalicity has much to do with the magnetic field. The material in the Sun is ionized, which means you've got large electric currents running around, and those electric currents are going to produce magnetic fields.
Related to Why is Earth made of Iron and Stone?
1. Why is the Earth made of iron and stone?
The Earth is made of iron and stone due to its formation process. When the Earth was first formed, it was a hot, molten ball of rock and metal. As it cooled, heavier elements like iron sank to the center and formed the Earth's core, while lighter elements like silicon and oxygen rose to the surface and formed the Earth's crust.
2. How much of the Earth is made of iron and stone?
Approximately 85% of the Earth's volume is made of iron and stone. The Earth's core, which is primarily made of iron and nickel, makes up about 16% of its volume, while the Earth's crust, which is mostly composed of silicon, oxygen, and other elements, makes up the remaining 69%.
3. Can the Earth's composition change over time?
While the overall composition of the Earth has remained relatively constant over its history, there have been some changes. The Earth's crust has undergone continuous processes such as erosion, volcanic activity, and plate tectonics, which can change the distribution of elements on the surface. Additionally, meteorite impacts can also introduce new elements to the Earth's composition.
4. Are all planets in our solar system made of iron and stone?
No, not all planets in our solar system are made of iron and stone. For example, gas giants like Jupiter and Saturn are primarily composed of gas and ice, while smaller rocky planets like Mercury and Venus have a similar composition to Earth. Each planet's composition is determined by its formation process and distance from the sun.
5. Is the Earth the only planet with an iron core?
No, the Earth is not the only planet with an iron core. The other rocky planets in our solar system, such as Mercury, Venus, and Mars, also have iron cores. Additionally, some larger moons, such as Jupiter's moon Ganymede and Saturn's moon Titan, are also thought to have iron cores.
  • Astronomy and Astrophysics
12K
