Why is electric field at the center of a charged disk not zero?
The discussion centers on the electric field at the center of a uniformly charged disk, which is counterintuitive due to symmetry considerations. While it seems that the electric field should be zero based on the contributions from concentric rings, the correct formula for the electric field at the center of the disk indicates a finite value when approaching from either side. The formula used is valid only for points away from the center, as it diverges when evaluated at the center. Thus, the electric field at the center is indeed zero, despite the limit approaching a non-zero value as one moves closer. This highlights the discontinuity in the electric field at that specific point.
vcsharp2003
A disk that is very thin and uniformly charged has a non-zero electric field at its center. Explain why this statement is true or false.
##E = \dfrac {\sigma} {2 \epsilon_{0}} [1 - \dfrac {x} {(R^2 + x^2)^{\frac {1}{2}}} ]##, where
##E## is electric field strength at a point P on the axis of the disk
##x## is distance of point P from the center of the sphere ( axis is perpendicular to the disk and passing through its center)
##R## is radius of disk
##\sigma## is the uniform charge density per unit area of the thin disk
##\epsilon_{0}## is electrical permittivity of vacuum
The electric field strength at the center of a uniformly charged disk should be zero according to symmetry of concentric rings about the center, where each ring is contributing to the electric field at the center of the disk.
For a thin ring of uniform charge distribution the formula is ##E = \dfrac {1} {4 \pi \epsilon_{0}} \dfrac {Qx} {(R^2 + x^2)^{\frac {3}{2}}}##, where the electric field ##E## is at a point P that is a distance ##x## from the center of the ring and along the ring's axis. When we consider the center of the ring, then ##x =0## which gives us ##E = 0## at the center of the ring.
Thus, each concentric ring will contribute ##0## to the electric field at the center of the thin disk. Consequently, the electric field at the center of the thin disk must be ##0##.
However, I do see from the formula for a thin charged disk as given under the relevant equations, that the electric field at the center of a disk is found to be ##E = \dfrac {\sigma} {2 \epsilon_{0}}## when we substitute ##x =0## in the mentioned formula.
I am unable to understand the flaw in my logic.
Your logic is correct. The field will be zero.
The formula you quote only holds for ##x\neq 0##. It does not apply when ##x=0##. For an infinitely thin disc, the electric field is discontinuous at the centre of the disc. In practice, no disc is infinitely thin so we don't need to worry about that.
The reason the formula does not apply when ##x=0## is that we obtain it by integrating the formula for field from an infinitesimal ring, for ring radius ##a\in [0,R]##. The integrand for that is always finite if ##x>0## but if ##x=0## it becomes infinite at ##a=0## and the integral diverges. So the formula's derivation is invalid if ##x=0##. See here for a derivation of the formula for the disc. You can see how they use that integral over ##a##.
Likes MatinSAR, PhDeezNutz and vcsharp2003
andrewkirk said:
The formula you quote only holds for x≠0. It does not apply when x=0. For an infinitely thin disc, the electric field is discontinuous at the centre of the disc. In practice, no disc is infinitely thin so we don't need to worry about that.
Ok. Thanks for the excellent explanation.
It seems that if we plot a graph of ##E## vs ##x## for a thin charged disk then the the y-axis will be a vertical asymptote to the plot. Is that correct?
It will have a stranger form than that: no asymptote. The function will tend to a finite nonzero limit, per the above formula, as ##x\to 0##. But the actual value of the function at ##x=0## will be 0, which is different from the limit. Effectively, it is the function specified by
$$f(x)
= \left\{
\begin{array}{ll}
-\dfrac {\sigma} {2 \epsilon_{0}} [1 - \dfrac {x} {(R^2 + x^2)^{\frac {1}{2}}} ] & x < 0 \\
0 & x = 0\\
\dfrac {\sigma} {2 \epsilon_{0}} [1 - \dfrac {x} {(R^2 + x^2)^{\frac {1}{2}}} ] & x > 0\\
\end{array}
\right.
Note that not only is the function at 0 not equal to the limit, but the left and right limits also differ.
Likes vcsharp2003
andrewkirk said:
It will have a stranger form than that: no asymptote. The function will tend to a finite nonzero limit, per the above formula, but with ##x=0##, as ##x\to 0##. But the actual value of the function at ##x=0## will be 0, which is different from the limit. Effectively, it is the function specified by
$$f(x)
= \left\{
\begin{array}{ll}
0 & x = 0\\
\end{array}
\right.
That is very beautifully explained. It makes complete sense now. Thankyou.
Likes hutchphd and PhDeezNutz
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
