- #36
- 8,943
- 2,953
ElmorshedyDr said:So during the slow compress the gas keeps gaining and losing heat to the surrounding medium at the same rate staying at an equilibrium position with surrounding, so its temperature stays constant
Normally, compressing a gas would cause it to get hotter. But you can view isothermal compression as a limiting case of the following process:
Compress the gas a tiny bit.
Let it cool off.
Compress it a tiny bit more.
Let it cool off.
Etc.
The resulting pressure when you reach your final volume will be less than it would have been if you hadn't allowed it to cool off.
Isothermal compression results in this relationship between pressure and volume:
[itex]P \propto V^{-1}[/itex]
If the gas were prevented from exchanging heat with the reservoir, the relationship would be:
[itex]P \propto V^{-5/3}[/itex] (for a monatomic gas).
