Why is higher density causing higher surface gravity?
In summary: C'mon man this is a message board not an academic paper >.>, but if it really bothers you i can fix it.
SpiderET
82
Normal density of Earth is 5,5 tons/m3 and surface gravity is 9,8 m/s and. But if we would compress mass of Earth to 50 km diameter, we would get density 1,4 mil tons/m3 and surface gravity would be 158 860 m/s.
I know the math, in basic gravity equotation F=Gm1m2/r2 with decreasing r you get higher gravity, but in this case the overall mass of Earth would be still the same, why is surface gravity so much higher? Is there some good physical explanation for this?
I'm not sure I understand. Are you asking why the force of gravity follows the inverse square law? I.e., why it's stronger the closer you get to the source?
The explanation that gravity follows inverse square law seems to me like not sufficient for explanation of increasing surface gravity as described in example and I am looking for some extended or better explanation.
What's not sufficient about it w/r to your example? You're closer to the source of gravity (mass), and the force is greater as per the inverse square law.
Can you illuminate the issue a bit more? Perhaps with a different example?
So what happens to F, if you keep the masses constant, and decrease r?
That is the explanation. The objection you raise is irrelevant.
The total strength of the Earth's gravitational force hasn't gotten any stronger you've just moved closer to source. Maybe it would help if you imagined yourself standing on the Earth when suddenly it shrank to 1/4th it's size. If you were able to (stay alive) and maintain the exact same distance (to the center of the Earth, not the surface) the "pull" of the Earth's gravitational force you would experience would be exactly the same.
J.J.T. said:
Gravity doesn't get any stronger you've just moved closer to source. Maybe it would help if you imagined yourself standing on the Earth when suddenly it shrank to 1/4th it's size. If you were able to (stay alive) and maintain the exact same distance (to the center of the Earth, not the surface) the force of the Earth's gravity you would experience would be exactly the same.
I don't know what you mean by "gravity". Apparently you do NOT mean "gravitational force" since that does change with distance. So what do you mean?
Sorry that was poor wording. I meant to say that the gravitational force of the Earth didn't get any stronger in the sense that if you maintained your distance as the density increased there would be no effect.
You are still using "gravity" as a noun, apparently not as "gravitational force". What do you mean by that?
Remember that the Earth is not a point-like object. You are closer to the ground you are standing on than the opposite side of the Earth, so the force from the former is greater than that from the latter. Decreasing the radius of the Earth brings all that matter you aren't standing on closer, so the force of gravity from them increases via the inverse square law.
And before you say anything I put "pull" in quotation marks for you so no one would take it literally.
Likes mgkii
FAQ: Why is higher density causing higher surface gravity?
1. Why does higher density lead to higher surface gravity?
Higher density means that there is more mass in a given volume. According to Newton's Law of Gravitation, the force of gravity is directly proportional to the mass of the objects and inversely proportional to the square of the distance between them. This means that the more mass an object has, the stronger its gravitational pull will be. Therefore, objects with higher density will have a higher surface gravity due to the increased mass within a smaller volume.
2. How does density affect surface gravity on other planets?
The relationship between density and surface gravity remains the same on other planets. However, the density and mass of a planet can vary greatly, resulting in different surface gravities. For example, the planet Mercury has a much higher density than the gas giant Jupiter, resulting in a much stronger surface gravity.
3. Can density and surface gravity change over time?
Yes, the density and surface gravity of a planet or any object can change over time. This is due to various factors such as the movement of tectonic plates, erosion, and changes in the atmosphere. These changes can alter the mass and distribution of mass, ultimately affecting the surface gravity.
4. How does surface gravity affect the habitability of a planet?
The surface gravity of a planet plays a crucial role in its habitability. If the surface gravity is too low, the atmosphere may be unable to support life. On the other hand, if the surface gravity is too high, it may crush any potential life forms. The Earth's surface gravity, which is moderate compared to other planets, allows for the existence of diverse life forms.
5. Is there a limit to how high the surface gravity can get due to density?
There is technically no limit to how high the surface gravity can get due to density. However, there is a limit to the density of an object, known as the Chandrasekhar limit. This limit states that if a star's density exceeds a certain point, it will eventually collapse into a black hole. So, while there is no limit to the surface gravity, there is a maximum density that can be reached without resulting in a black hole.
