Why is horizontal escape velocity less ?
In summary, the escape velocity for an asteroid with a mass of 6.6x10^17kg and radius of 46km is 44ms. However, if a projectile is launched horizontally, the escape velocity is only 31ms. This difference can be explained by the rotational speed of the asteroid, which can help reduce the escape velocity. However, without further information about the asteroid's rotation, it is unclear how to calculate the exact escape velocity. Additionally, the velocity needed to get a stone into orbit is different from the escape velocity, and this could impact the calculations as well. More information is needed to fully understand and solve this problem.
victoriafello
34
an asteriod with mass 6.6x10^17kg & radius 46km has escape velocity 44ms, but if the projectile is launched horizontally then the escape velocity is only 31ms, show that this is correct
Vesc = SQRT (2GM/R)
G = 6.67x10^-11
the only thing i can think of is that the rotational speed of the asteriod is helping to reduce the escape velocity, but I am not sure how to work it out ?
Hi victoriafello! :smile:
victoriafello said:
an asteriod with mass 6.6x10^17kg & radius 46km has escape velocity 44ms, but if the projectile is launched horizontally then the escape velocity is only 31ms, show that this is correct.
(hmm … 31 is approx √(1/2) times 44)
I think that's rubbish …
escape velocity (ignoring rotation) is the same for any direction, since it's the solution to 1/2 mv2 - GM/r2 = 0 + 0.
And although, yes, the rotation of the asteroid can make a difference, you're not given any information about it. :confused:
Is this part of a longer question?
Hi
No its not part of a longer question that's it, the only thing that's maybe wasnt clear is that the 31ms is to get the stone into orbit, does that make any difference ?
im really stuck with this one so any ideas would be great
victoriafello said:
… the only thing that's maybe wasnt clear is that the 31ms is to get the stone into orbit, does that make any difference ?
D'uh! :rolleyes: yes of course it does!
"escape velocity" means that at large r the speed is zero.
"into circular orbit" means that at large r the speed is proportional to … ? :smile:
But I'm still not understanding the question …
is it a circular orbit? or just a very eccentric elliptical one, always returning to just miss the asteroid?
and does the vertical launch also go into orbit, or does it just keep going straight up? :confused:
Related to Why is horizontal escape velocity less ?
1. Why is the horizontal escape velocity less than the vertical escape velocity?
The horizontal escape velocity is less than the vertical escape velocity because of the Earth's gravitational pull. When an object is launched horizontally, it still has a component of its velocity moving towards the Earth's center, which is affected by gravity. This means that the horizontal velocity needs to be greater to overcome the pull of gravity and escape the Earth's orbit.
2. How does the shape of the Earth affect the horizontal escape velocity?
The shape of the Earth does not have a significant impact on the horizontal escape velocity. The Earth's curvature is negligible when compared to the distance an object needs to travel in order to reach escape velocity. Therefore, the shape of the Earth does not have a significant effect on the required velocity for horizontal escape.
3. Can the horizontal escape velocity be greater than the vertical escape velocity?
No, the horizontal escape velocity cannot be greater than the vertical escape velocity. This is because the vertical escape velocity is the minimum velocity required for an object to escape the Earth's gravitational pull. The horizontal velocity can only add to this minimum velocity, but it cannot exceed it.
4. How does air resistance affect the horizontal escape velocity?
Air resistance does not have a significant impact on the horizontal escape velocity. This is because air resistance primarily affects the vertical motion of an object and has minimal effect on horizontal motion. Therefore, air resistance does not significantly affect the required velocity for horizontal escape.
5. Is the horizontal escape velocity the same for all objects?
No, the horizontal escape velocity varies depending on the mass of the object. The larger the mass of an object, the greater the velocity required for it to escape the Earth's orbit. However, for objects with the same mass, the horizontal escape velocity will be the same.
