turaturer
- 2
Time-varying magnetic field makes electric field circular(or close loop). I am asking the reason why it is circular or close loop shape?
The fields are non-conservative. They have to follow the laws of electromagnetism ( discovered by Faraday and Maxwell). In this case, electric field is induced only when there is change in magnetic flux associated with a loop (real or hypothetical).turaturer said:Time-varying magnetic field makes electric field circular(or close loop). I am asking the reason why it is circular or close loop shape?
Any vector field can be decomposed into an irrotational part and a solenoidal part. Faraday discovered that the solenoidal part is equal to the time variation of the magnetic field.turaturer said:Time-varying magnetic field makes electric field circular(or close loop). I am asking the reason why it is circular or close loop shape?
Thank you. But I asked how time-variation of the magnetic field makes electric field rotate, not make it divergence field.DaleSpam said:Any vector field can be decomposed into an irrotational part and a solenoidal part. Faraday discovered that the solenoidal part is equal to the time variation of the magnetic field.
An induced electric field is a type of electric field that is created by changes in the magnetic field. This change in the magnetic field can be caused by a moving magnetic field, a changing electric field, or a changing magnetic field.
An induced electric field is circular because of the way it is created. When a magnetic field changes, it creates a circular electric field around it. This circular electric field is perpendicular to the direction of the changing magnetic field and follows the direction of the magnetic field lines.
An induced electric field is different from a regular electric field because it is created by changes in the magnetic field, rather than by charged particles. It also only exists while the magnetic field is changing, whereas a regular electric field can exist permanently.
The circular induced electric field has several significant properties. It is always perpendicular to the changing magnetic field, it has a constant magnitude, and it forms closed loops around the changing magnetic field. These properties make it useful in applications such as electromagnetic induction and motors.
Yes, an induced electric field can be non-circular if the changing magnetic field is not uniform. In this case, the electric field will still be perpendicular to the changing magnetic field, but it will no longer form closed loops and may have a changing magnitude and direction. This type of induced electric field is known as a non-uniform or non-circular induced electric field.
