Why is jerk the change in acceleration over time?
In summary: Sin(t) (if the mass is changing).For an object at rest, these solutions will be equal and the jolt will be zero.If the mass is changing (i.e. the object is oscillating), then the jolt will be different for each solution.
Mahkoe
Recently I found out about jerk (or jolt). I've found that it represents the change in acceleration over time. To me, this makes no sense at all. To me, the change in acceleration is directly related to the radial distance between the two objects (if the forces acting on or imaginary objects are due to gravity), and has nothing to do with time. I don't get why the fact that jerk is measured in change in acceleration over time will give the correct results if we for example, throw a 20g ball directly upwards from a 20kg planet whose radius is say, 100m, at two different speeds. The faster initial velocity will cause the ball to travel higher, therefore the change in acceleration being greater, and although yes the change in time will be greater, I just can't grasp why it works and how the change in acceleration is related to the change in time. Could someone please explain what is going on and why, or maybe point a very digestible tutorial, and try to avoid calculus if possible. Thank you very much
But that radial distance between two objects changes with time, so by extention so does the acceleration and alas acceleration can be written as a function of time.
But here's the thing; when the initial velocity is faster, the radial distance will change more with time. You're probably right, but I really don't understand
Yes, if the radial distance changes more with time then the acceleration also changes more with time, since as you say, acceleration is directly related to the radial distance.
If you were to use calculus this is the equivelant of saying simply that j(t)=a'(t) where j(t) is the jerk as a function of time and a(t) is the acceleration as a function of time.
You've just said that if the initial velocity is greater, the acceleration will change more with time, meaning the jerk is greater. Maybe I was never told that jerk is not something constant, that it is found with the initial vertical velocity?
I don't understand, Jerk is DEFINED to be the third time derivative of position, or the first time derivative of the acceleration. That's all there is to it...
Sorry to be the freak here, but "That's all there is to it" is not good enough for me
Change in position is velocity.
Change in velocity is acceleration.
Change in acceleration is jerk.
A common example of jerk acceleration is a rocket that burns fuel, thus decreasing it mass, thus (due to a=F/m) causing a steady increase in the rate of acceleration over time.
In your example of tossing a ball, you've missed one critical component:
For a low altitude throw, the acceleration is indeed constant (9.8m/s2 on Earth) - thus no jerk.
But for very big distances on your tiny planet (or, on Earth a high altitude throw of many miles) gravity drops off noticeably. Thus, the acceleration is not constant. The rate of acceleration decreases over time (9.8m/s2 at the start, but < 9.8m/s2 at the top of the arc).
I think most of your problem is that you picked a bad example to understand the idea. The fact that in your example you can write the acceleration as a simple function of distance isn't relevant to the idea of what "jerk" is.
Think about a different example, like a car accelerating from rest and then driving at the speed limit. Suppose the initial acceleration was 2 m/s2. When the speed is near the speed limit, the driver lifts his foot off the gas so the acceleration drops to zero (i.e. the car continues driving at constant speed) in say 0.5 seconds.
The acceleration has changed from 2 to 0 in 0.5 sec. So the jerk or jolt is (0-2) / 0.5 = -4 m/s3.
That's "all there is to it".
Okay, I understand now. But then, how is jolt used in the example of the ball on the 20kg planet? How do you calculate the jolt, and is it the same for every altitude and initial velocity? Thanks for all the help, btw
Working with the 1/r potential is kinda tricky if we want exact answers
Let's use a simple example of the harmonic oscillator.
We can solve the equations of motion to get x(t)=Cos(t) (if we use units such that all the coefficients like mass, spring constant etc = 1)
In this case the acceleration is x''(t)=-Cos(t)
Why is this?
Because the definition of the harmonic oscillator is one where the force is equal to minus the displacement from the origin.
As we can see, this function changes with time. If we were to calculate the change of x''(t) with respect to time we would get the function x'''(t)=Sin(t)
This is so because at t=n pi the displacement is at a maximum (Cos(n pi)= ±1) and so the force is also at a maximum which means that the rate of change of the force is zero (Sin(n pi)=0).
If we change the initial conditions we get the solution x(t)=a Cos(t+b), changing the initial velocity gives us the a and changing the initial position gives us the b. If we use this new x(t) we arrive at the jolt as x'''(t)=a Sin(t+b), so the jolt as a function of time does indeed change given different initial conditions.
As the wikipedia page http://en.wikipedia.org/wiki/Jerk_(physics ) says, it probably isn't used in practice in that situation, because it doesn't tell you anything interesting.
If you can define acceleration easily as a function of position, you could find the jerk by using the chain rule:
[tex]\frac{da}{dt} = \frac {da}{dx}\frac{dx}{dt} = v \frac{da}{dx}[/tex]
(you said you preferred avoiding calculus, but that's not always possible). That shows it is not indepedent of the velocity. You can understand that without calcuus, because when the ball is at the top of its flight and the velocity is zero, the acceleration is not changing so the jerk is also zero. But it the ball was at the same height and moving with a high velocity, its acceleration would be changing and the jerk would not be zero.
Jerk or jolt is only used where it represents something physically important to what is being designed or analysed, like starting or stopping of a vehicle or an elevator, etc.
There are many engineering applications for jerk... from design of auto air bags to roller coasters to ejection seats.
You can see from the eqn. that jerk can be increased by an increase in acceleration or by decrease in the time span for the change.
Also, (briefly mentioned in Wiki) jerk involves a change in force per unit time (dF/dt) when mass is involved...and is sometimes referred to as "yank"... :)
dF/dt = m(dA/dt)
Creator
Oh, yea, don't forget about "jounce" which is the rate of change of jerk with time. :)
Fourth time derivative of position.
what's there to make sense or nonsense? it's just a definition. what you're saying here makes little sense to me.
objects in free fall experience no jerk and, from the POV or general relativity, don't even experience acceleration that can be measured in their own frame of reference.
i don't know if you have ever ridden a subway train. sometimes there are no seats and you have to stand. there were even times i had to stand and could not even reach a strap or bar to stabilize my stand. when the train accelerates or decelerates at a constant rate (the jerk is zero), then i can adjust the angle of my standing and i need no strap to hang on to. it's just like standing on a slightly sloping incline (and a slight increase in the apparent gravity). but as soon as that acceleration changed, the risk of me bumping into someone else or falling over was greater. that is what jerk is all about.
sitting in a chair or standing on the floor is indistinguishable from a constant acceleration (where the jerk is zero). but even in general relativity, jerk is absolute. doesn't matter where you are, everyone will experience an equal amount of jerk equally.
Thing is, it's not like jerk really is about jerks and jolts. I listed several examples of smooth, continuous and long-duration jerks.
Related to Why is jerk the change in acceleration over time?
1. What is jerk in physics?
Jerk is the rate at which acceleration changes over time. It is the third derivative of position with respect to time and is measured in meters per second cubed (m/s^3).
2. Why is jerk important in understanding motion?
Jerk is important because it helps describe how quickly an object is accelerating or decelerating. It also affects the smoothness and comfort of movements, such as in vehicles or amusement park rides.
3. How is jerk different from acceleration?
Acceleration is the change in velocity over time, while jerk is the change in acceleration over time. In other words, acceleration tells us how fast the velocity is changing, while jerk tells us how quickly the acceleration is changing.
4. What causes jerk in a moving object?
Jerk can be caused by various factors, such as changes in the force acting on an object, changes in the direction of motion, or sudden starts or stops. It can also be caused by external forces, such as friction or air resistance.
5. How is jerk related to other kinematic quantities?
Jerk is related to other kinematic quantities through their derivatives. For example, velocity is the first derivative of position, acceleration is the second derivative of position, and jerk is the third derivative of position. This means that jerk affects the rate of change of both velocity and acceleration.
  • Mechanics
  • Mechanics
  • Mechanics
  • General Discussion
