Why Is My Calculated 'g' Value Incorrect When Using the Pendulum Equation?
  • Thread starter Danni11111
  • Tags
    Pendulum
In summary, the data in the homework statement was recorded for different lengths and times of pendulum swings, and the value of 'g' was found to be around 40. However, every time the equation for 'g' was used, it ended up with the value being around 9.81, which is much lower than what it should be. The problem seems to be that the data is not accurate, as when the same pendulum was swung by different angles, the value of 'g' was found to be much closer to the correct value of 9.81.
Danni11111
Hi,
I was given a coursework where I have to find the value of the acceleration due to gravity by recording different pendulum lengths & their time period.
here is my data:
Pendulum Length (cm) Time Period (10 swings) (s)
80 8.97
70 8.45
60 7.84
50 7.32
40 6.50
However, every time I used the pendulum equation, I ended up with 'g' having a value around 40, when it is mean to be about 9.81.
I've tried for hours to work out where the flaw in my workings is, but I just can't find it. I've tried converting the cm to m, etc.
T = 2π * √(L/g)
g = 4π² L / T²
Where T = time period & L = length of pendulum
One example of my workings:
T = 0.897
L = 0.8
g = 4π² L / T²
g = 39.478 * 0.8 / 0.897²
g = 39.252 :confused:
I'm very sure my data isn't wrong either.
Thanks in advance! :)
well you see that T2=4π2*L/g = (4π2/g)L
so if you plot T2 against L, you will get a straight line passing through the origin whose gradient is 4π2/g.
So plot your graph and get the gradient from it.
I already plotted it for T squared against L, only problem is, that gradient was ~1.005. That meant that g had to be around 4π2- which is ~39.
Does this mean that it is definitely the data that is wrong and not any of my workings?
I can't help thinking that a second per swing for a pendulum with a length of 80 cm seems reasonably accurate though...
I can't help thinking that a second per swing for a pendulum with a length of 80 cm seems seasonably accurate though...
For your period, did you divide by 10 to get the time for one period before plotting?
Yeah- that graph gave me a gradient of ~0.01 :(
I am not too sure why it is not working out, normally your gradient should be around 4. The most I can say is that your measurement of the times are off, but you said they are correct.
EDIT: When you were swinging the pendulum by what angle did you displace the pendulum by each time?
I'll just have to redo the experiment then- I must have done something awfully wrong :P
thanks for the help!
edit- erm, I didn't do it by an angle, I displaced the pendulum by 20cm from the center for each pendulum length- is that the problem?
I doubt that that's the reason your data didn't work out. But it would definitely be better to displace the pendulum by the same angle each time.
Just to check when you were timing swings, you did count a complete back-and-forth cycle as only one swing, right? If not (i.e. if you measured each "swing" only from one maximum displacement to the other), that would almost explain the error in your result.
I'd guess you didn't measure the period, which is the time for the pendulum to go through one complete cycle, but rather the time for the pendulum to go from one side to the other, so your times are off by a factor of 2, which will cause your estimate of g to be 4 times too large.
Yep- that's it. I counted each swing as a time period, instead of a swing & back.
I'm changing my excel sheet now.
Thank you so much :)
FAQ: Why Is My Calculated 'g' Value Incorrect When Using the Pendulum Equation?
How do I calculate the period of a pendulum?
The period of a pendulum can be calculated using the equation T = 2π√(L/g), where T is the period in seconds, L is the length of the pendulum in meters, and g is the acceleration due to gravity in meters per second squared.
What is the relationship between the length of a pendulum and its period?
The length of a pendulum and its period are inversely proportional. This means that as the length of the pendulum increases, the period also increases. Similarly, as the length decreases, the period decreases.
Can the pendulum equation be used for all types of pendulums?
The pendulum equation can be used for simple pendulums, which consist of a mass suspended from a fixed point by a string or rod. It can also be used for physical pendulums, which have a more complex shape but still follow the same principles.
How does the acceleration due to gravity affect the period of a pendulum?
The acceleration due to gravity has a direct effect on the period of a pendulum. As g increases, the period decreases, and as g decreases, the period increases. This is because the gravitational force is what causes the pendulum to swing back and forth.
Can the pendulum equation be used to calculate the velocity of a pendulum?
No, the pendulum equation only calculates the period of a pendulum. To calculate the velocity, you would need to use the equation v = √(2gL(1-cosθ)), where v is the velocity in meters per second, g is the acceleration due to gravity, L is the length of the pendulum, and θ is the angle of the pendulum's swing.
