Why Is My Calculation for the Plane's Correct Heading Incorrect?
In summary: Nowadays we use GPS. In summary, the desired ground track is due east, and the pilot needs to head 0.497 south of east to reach the desired destination.
turpy
A plane has an airspeed of 200 mph. The pilot wishes to reach a destination 600 mi due east, but a wind is blowing at 10.0 mph in the direction 10.0 degrees north of east.
In what direction must the pilot head the plane in order to reach her destination?
______________ degrees south of east
The attempt at a solution
I drew two vectors
one horizontal facing east of magnitude 200 mph (plane) + 10cos10 (wind)
and one vertical of magnitude 10sin10
I solved for the angle b/w the horizontal vector and the resultant vector
arctan theta = (10sin10/(200+10cos10))
and I get that theta = 0.474 degrees south of east
When I type this answer (0.474) into masteringphysics.com, it tells me that I'm incorrect.
What is it that I'm doing wrong?
Thanks!
I drew two vectors
Thanks!
Your wind triangle is in error. The desired ground track (velocity unknown) is due east; the 200 mph is the length of a vector along the new heading which you have yet to determine.
I really have no idea how your formula means.
OH! thank you so much i get it now
now i have arcsin theta = (10sin10)/200
theta = 0.497 south of east, which is the correct answer
a simple question but i totally misinterpreted what "airspeed" meant
You're welcome.
As a navigator if I fed that to the pilot he'd try to do it, but share a laugh with the copilot. But that's when there were navigators.
I would suggest double-checking your calculations and making sure you are using the correct units for each value (mph for speed, degrees for angles). Additionally, it is important to consider the direction of the wind in relation to the plane's heading. In this problem, the wind is blowing in a direction 10 degrees north of east, so the plane's heading must be in a direction south of east in order to counteract the wind and reach the destination. I would recommend drawing a diagram to visualize the problem and make sure all calculations and directions are accurate.
FAQ: Why Is My Calculation for the Plane's Correct Heading Incorrect?
1. What is relative motion?
Relative motion is the motion of an object in relation to another object. It takes into account both the speed and direction of the objects, as well as the observer's perspective.
2. How do you solve relative motion problems?
To solve relative motion problems, you must first identify the objects involved and their respective speeds and directions. Then, you can use mathematical equations, such as the formula for velocity, to calculate the relative motion between the objects.
3. What is the difference between relative motion and absolute motion?
Absolute motion refers to the motion of an object in relation to a fixed point or reference frame, while relative motion takes into account the motion of multiple objects in relation to each other. Absolute motion is often used in physics, while relative motion is more commonly used in everyday situations.
4. Can relative motion be negative?
Yes, relative motion can be negative. Negative relative motion indicates that the objects are moving in opposite directions, while positive relative motion indicates that the objects are moving in the same direction.
5. How does relative motion affect velocity and acceleration?
Relative motion can affect both velocity and acceleration, as it takes into account the motion of multiple objects. For example, the relative velocity between two objects can impact the acceleration of one object towards the other.
