Why is one root rejected when solving equations with multiple solutions?
  • Thread starter zorro
  • Tags
    Root
In summary: So is x = -4.5 a solution? Do the curves intersect in the complex plane?In summary, when solving to equations say y2 = 4x and x2 + y2 = 9/4 for x, there are two possible values - x=0.5 and x=-4.5. The equation represents a parabola and a circle, with x=either 0.5 or -4.5 as the abcissae of intersection. I do not understand why x=-4.5 is not a point of intersection, but I am interested in knowing the reason behind it.
zorro
1,384
When we solve to equations say y2 = 4x and x2 + y2 = 9/4 for x, we get two values -
x=0.5 and x=-4.5
The equations represent a parabola and a circle resp. with x=either 0.5 or -4.5 as the abcissae of intersection. I don't understand why do we reject one value which is -4.5 in this case. By drawing a figure we can find out why but I am interested in knowing the reason behind -4.5 as one of the solutions. Why -4.5 is not a point of intersection? Why do we get this value if it is not a solution?
if you put x=-4.5 inside the first equation
[tex] y^{2}=-18 [/tex] this makes NO sense for real numbers
Hi Abdul,
It seems to me that if you assume y is a real number, then the first equation constrains x to be positive. I'm not algebra-savvy enough to give you a precise answer to the question of why -4.5 appears, except to note that any quadratic will give you two (possibly complex) roots (counted with multiplicity), so some second solution must exist. I can't think of a good reason to pin it down more precisely than that though; I'll have a think...
Because it's not a point at all. 0.5 isn't a point of intersection either. :smile:
I suspect you are holding a widely held misunderstanding about solving problems.
When you (correctly) do these algebraic manipulations, you are making the assertion:
Any solution to the original problem is also a solution to the new problem​
which is a very different statement than
Any solution to the new problem is also a solution to the original problem​
or even
The new problem and the original problem have the same set of solutions​
What are these values then?
or even
err I don't understand what are you trying to convey. Can you please explain it more clearly?
If it doesnot make sense why do we get that value?
A point of intersection has two coordinates. :-p (and the coordinates satisfy the original system of equations)
What part don't you understand? Do you not understand what the English sentence
means? Do you not understand what I mean by "new problem" and "original problem"? Something else?
Here's a simple example.
Consider the simple equation x = 2.
Of course, the equation already states the solution: for x = 2 it is true.
But let's try and solve it by first squaring both sides:
x² = 4.
The solutions are, clearly, x = 2 and x = -2. Yet, x = -2 is not a solution to the original equation x = 2, because -2 does not equal 2.
I did not understand what you meant by "new problem" and "original problem".
Hi Abdul! :smile:
x=0.5 and x=-4.5
The solutions to y2 = 4x and x2 + y2 = 9/4
are (0.5, √2) (0.5, -√2), (-4.5, 3√2i), (-4.5, -3√2i).
If you're allowed imaginary numbers, then the last two solutions are ok.
If you're not allowed imaginary numbers, then the last two solutions are … not allowed!. :wink:
Initially, you were trying to solve the problem
y^2 = 4x and x^2 + y^2 = 9/4​
By doing an algebraic manipulation (substituting 4x for y^2 in the second equation, I expect), you produced a new problem:
x^2 + 4x = 9/4​
You are guaranteed that if (x,y)=(a,b) for the first problem, then x=a is a solution for the second problem...
sort-of …
if we let the y coordinate range over a "vertical" plane, perpendicular to the "horizontal" x-axis,
then y2 = 4x is a horizontal parabola for x ≥ 0, touching a vertical parabola for x ≤ 0,
while x2 + y2 = 9/4 is a horizontal circle, touching a vertical hyperbola for |x| ≥ 3/2 …
the vertical parabola intersects the vertical hyperbola at (-4.5, 3√2i) and (-4.5, -3√2i) :wink:
Thank you tiny-tim. :smile:
FAQ: Why is one root rejected when solving equations with multiple solutions?
What is the significance of rejecting one root?
The process of rejecting one root refers to a method used in mathematics to solve equations. It helps to narrow down the possible solutions and find the most accurate root.
Why do we need to reject one root?
Rejecting one root is necessary because some equations may have multiple solutions, and not all of them are valid. Rejection helps to eliminate the incorrect solutions and find the one that satisfies all the conditions of the equation.
How do we determine which root to reject?
The root to be rejected is typically the one that does not satisfy a given condition or criterion in the equation. This could be a negative or imaginary value, or a value that does not fit within a given range.
What happens if we do not reject one root?
If we do not reject one root, it may lead to an incorrect solution for the equation. This can cause errors in calculations and can also result in an invalid solution that does not meet the conditions of the equation.
Can we always reject one root?
No, not all equations require the rejection of one root. It depends on the nature of the equation and the conditions given. In some cases, all roots may be valid, and there is no need for rejection.
