MHB Why is $p_i + \frac{k}{p_i}$ divisible by $3$ and $8$?
  • Thread starter Thread starter lfdahl
    Sum
The discussion revolves around proving that the sum of the divisors of a natural number \( k \), where \( k+1 \equiv 0 \mod 24 \), is also divisible by 24. It is established that \( p_i + \frac{k}{p_i} \) is divisible by both 3 and 8, which leads to the conclusion that the overall sum of divisors is divisible by 24. The participants explore the implications of \( k \equiv 0 \mod p \) and the relationships between \( p \) and \( \frac{k}{p} \) in modular arithmetic. A key insight is that one of the terms \( p+1 \) or \( \frac{k}{p}+1 \) must be a multiple of 3, while a similar argument holds for divisibility by 4. The discussion concludes with a resolution of the initial query, affirming the divisibility conditions.
lfdahl
MHB
Problem:
Let $k$ be a natural number, and $k+1 \equiv 0 \:\: (mod\:\:24)$
Show, that the sum of $k$´s divisors is also divisible by $24$.
Solution:
First, note that since $k = 4n_1+3$ for some $n_1\in \mathbb{N}$, $\sqrt{k}$ is not a natural number.
Let $p_1,p_2,…,p_m < \sqrt{k}$ be all $k$´s divisors smaller than $\sqrt{k}$.
Then, the sum of all $k$´s divisors is: $\sum_{i=1}^{m}\left ( p_i+\frac{k}{p_i} \right )$.
Now, since $k = 3n_2+2$ and $k = 8n_3+7$, and $k = p_i\frac{k}{p_i}$, the term $p_i+\frac{k}{p_i}$ is divisible by $3$ and $8$.
Thus, the sum : $\sum_{i=1}^{m}\left ( p_i+\frac{k}{p_i} \right )$ is also divisible by 24.
Can someone explain to me, why $p_i+\frac{k}{p_i}$ is divisible by $3$ and $8$??
Thankyou in advance!
Mathematics news on Phys.org
lfdahl said:
Problem:
Solution:
Hint: Let $p$ be a divisor of $k$. Can you show that $(1+p)\Bigl(1+\dfrac kp\Bigr)$ is divisible by $3$ and by $8$?
Thanks for the hint:
I´m not sure. Here is my attempt:
If $p < \sqrt{k}$ and $k \equiv 0 \:\: (mod \:\: p)$ then $k+1 \equiv 0 \:\: (mod \:\: p+1)$
$\Rightarrow$ $p+1 \equiv 0 \:\: (mod \:\: 3)??$
but it is not necessarily true, that: $k+1 \equiv 0 \:\: (mod \:\: 1+\frac{k}{p}).$
For example: Say $k = 95$, then $k \equiv 0 \:\: (mod \:\: p=5)$ and $k+1=96 \equiv 0 \:\: (mod \:\: p+1=6)$
- but $\frac{k}{p}=\frac{95}{5}=19$ and $k+1=96 \not\equiv 0 \:\: (mod \:\: p+1=20)$
Still it is true, that $3$ and $8$ divides $96$. I just don´t know how to prove this ... :(
If I could show, that $3$ and $8$ divides $(1+p)(1+\frac{k}{p})$ then $k+1 + p + \frac{k}{p}$ would of course also
be divisible by $24$, that is $p +\frac{k}{p}$ would be divisible by 24 as required.
For convenience, write $q = \dfrac kp$, so that $k = pq$. You know that $k\equiv-1\pmod3$. As you say, it does not necessarily follow that $p\equiv-1\pmod3$. But the only way that the product of two integers can be congruent to $-1\pmod3$ is that one of them is $\equiv1\pmod3$ and the other one is $\equiv-1\pmod3.$ So what is true is that either $p+1$ or $q+1$ must be a multiple of $3$.
A similar argument working mod $4$ shows that one of the integers $p+1,\,q+1$ is a multiple of $2$ and the other one is a multiple of $4$.
Thanks a lot, Opalg! This really helped me solve the matter!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
