Why is planet X always depicted as being blue?
In summary, the conversation discusses the possibility of a ninth planet in our solar system, inferred from the eccentric orbits of some Kuiper Belt Objects. This planet is proposed to have a mass of 10 Earth-masses, a semi-major axis of 700 AU, and an eccentricity of 0.6. Its blue color is likely due to its methane-rich atmosphere, similar to Neptune. This proposed planet is not confirmed and is only based on hypothetical calculations.
Tris Fray Potter
I know that it is probably a gas giant, but why blue? Saturn and Jupiter, and even Uranus aren't blue, so why would Planet X be blue?
Astronomy news on Phys.org
Presumably, the idea is that a planet that is far away, will look somewhat similar to the farthest planet we know, or that blue is evocative of cold temperatures.
In the end, though, I think this is for the same reason why unicorns are pink.
Likes russ_watters
Yeah, so just to be clear; you worded the question as if you think there is such a thing as Planet X. There probably isn't. The "Planet X" you typically hear about is a fiction generated by crackpots, not a scientific prediction (or at best an abandoned one).
Could the OP have in mind this proposed planet?
Caltech Researchers Find Evidence of a Real Ninth Planet | Caltech
A Ninth Planet in Our Solar System?
'Planet Nine' May Exist: New Evidence for Another World in Our Solar System
Journal article: EVIDENCE FOR A DISTANT GIANT PLANET IN THE SOLAR SYSTEM - IOPscience
Its existence is inferred from the orbits of some Kuiper Belt Objects. Six of them have very eccentric orbits with similar orientations. Astronomers Konstantin Batygin and Mike Brown propose the existence of an additional planet to account for this oddity.
The AASNova page cites this set of representative solution parameters:
  • planet mass of 10 Earth-masses
  • semi-major axis of a = 700 AU
  • eccentricity of e = 0.6
This means going between 280 and 1120 AU with a period of nearly 20,000 years.
That page and the Caltech page also have an artist's conception showing the planet as blue.
This is likely an extrapolation from Neptune, which is very blue because of its atmosphere's methane content.
This planet may likely be kept warm by its internal heat. Uranus (mass 14.536 Earth masses) radiates 1.1 times as much light energy as it gets from the Sun, and Neptune (mass 17.147 Me) 2.61 times (numbers from Wikipedia).
Assuming the same radiation rate per unit volume and scaling to 700 AU, this planet will radiate 1300 (scaled from Uranus) or 1200 (scaled from Neptune) times as much light energy as it receives from the Sun. Thus, a Neptune-like appearance is very plausible.
Related to Why is planet X always depicted as being blue?
1. Why do we always see planet X as blue in pictures or illustrations?
The blue color of planet X is often depicted due to the presence of water on its surface. Water reflects blue light, giving the planet a blue appearance when viewed from a distance. Additionally, the composition of planet X's atmosphere and the scattering of light by its particles can also contribute to its blue color.
2. Is planet X actually blue in reality?
It is impossible to definitively answer this question without further information about planet X. However, many planets in our solar system, such as Earth and Neptune, appear blue due to the presence of water or other gases in their atmospheres. Therefore, it is likely that planet X may also have a blue appearance if it has similar atmospheric conditions.
3. Could planet X's blue color be due to artificial means?
While there is currently no evidence to support this theory, it is possible that the blue color of planet X is artificially created. Some scientists have proposed that advanced civilizations could potentially manipulate the color of their planet through the use of technology or atmospheric engineering.
4. Are there any other factors that could contribute to planet X's blue color?
In addition to the presence of water and atmospheric conditions, the angle at which we view planet X can also affect its perceived color. The amount of light that reaches our eyes can also play a role in how blue the planet appears. For example, if planet X is viewed from a different angle or under different lighting conditions, it may appear to be a different color.
5. Do all planets in our solar system have a blue appearance?
No, not all planets in our solar system appear blue. For example, Mars appears to be red due to the presence of iron oxide on its surface. Additionally, the color of a planet can vary depending on its composition, atmosphere, and distance from the sun. Therefore, not all planets will have the same color, including blue.
  • Astronomy and Astrophysics
