Why is red color dominant in 4o'clock plant?
In summary, the conversation discussed how Mirabilis Jalapa exhibits incomplete dominance, resulting in a pink flower when a red and white plant are crossed. When selfed, the ratio of red, pink, and white flowers is 1:2:1. It was questioned how to determine which allele is dominant in this case, and it was suggested to look more closely and consider haplosufficiency. It was also noted that in cases of incomplete dominance, there may not be a dominant gene present.
PhyStudent20
Mirabilis Jalapa exhibits incomplete dominance.
So, if we cross Red and White colored plants (Parental Gen), we get, pink flowers (Filial I Gen).
When these are selfed, we get red, pink, white in ratio 1:2:1
So, how do you determine that Red is dominant, because, we are dealing with incomplete dominance here?
Biology news on Phys.org
The dominant one is usually which of the two alleles present in the heterozygote is expressed, such that the organism is phenotypically identical to one of the two homozygotes ... but in this case, none of the heterozygotes are identical to the homozygote. That your problem?
Probably the red allel is the one that makes the color while the "not red" allel doesn't... which means you need to look more closely.
The red is then the result of twice as much pigment getting made - since the action of the R defeats the default of r it is dominant.
I don't know if that is the case for the specific plant you cite. Not a botanist.
Look up "haplosufficiency"... there are other ways.
Well you can't,
nothing can be said, red is not the dominant gene, simply because of incomplete dominance. so there is no dominant gene in this case :)(similarly in snapdragon also)
Related to Why is red color dominant in 4o'clock plant?
1. Why is red color dominant in 4o'clock plant?
The dominant red color in 4o'clock plants is due to a gene called R, which is responsible for producing the red pigment anthocyanin. This gene is inherited from both parents, making it more likely for the plant to have red flowers than any other color.
2. Is red color dominance in 4o'clock plants a result of natural selection?
No, the red color dominance in 4o'clock plants is not a result of natural selection. It is a result of genetic inheritance from both parents. Natural selection only occurs when certain traits provide an advantage for survival and reproduction.
3. Are there any environmental factors that contribute to the dominance of red color in 4o'clock plants?
Yes, there are environmental factors that can influence the intensity of the red color in 4o'clock plants. Factors such as sunlight, temperature, and soil nutrients can affect the production of anthocyanin, resulting in variations in the intensity of the red color.
4. Can the dominance of red color in 4o'clock plants be altered?
Yes, the dominance of red color in 4o'clock plants can be altered through genetic modification or selective breeding. By manipulating the R gene or selectively breeding plants with desired traits, it is possible to change the dominant color in 4o'clock plants.
5. Are there any other plants with a similar dominance of red color?
Yes, there are many plants with a similar dominance of red color. This is because the R gene responsible for producing anthocyanin is found in a wide range of plant species. Examples include red roses, strawberries, and cherries.
  • Biology and Medical
  • Other Physics Topics
25K
