Why is spacetime shown on a 2 dimensional plane?
In summary, the conversation discusses the concept of gravity and how it is often described using a 2 dimensional plane. The analogy of a planet bending space-time is used, but it is not entirely accurate. The conversation also delves into the complexities of visualizing three-dimensional curvature and the limitations of using analogies to explain gravity. The idea of gravity collapsing space around the center of gravity is also brought up, but it is noted that this is an imperfect explanation. Overall, the conversation highlights the difficulties of understanding and visualizing the concept of gravity.
Crazyhorse2882
I don't have the mathematics down quite yet but one thing I've noticed whenever I watch documentaries about gravity in relativity is that it's always described on a 2 dimensional plane. They show a planet bending space time as if the space time is underneath it but I'm thinking that the space time actually encircles the mass creating almost a bubble of sorts around it. Can someone explain this in laymen's terms to me please? Thank you
Space news on Phys.org
You are correct. This pop-sci analogy is very poor, really, but it DOES give the basic idea of "bending space-time" to the layman. It just isn't accurate at all in any real sense.
Such analogies are often rather poor once you actually understand what is being explained, they just serve as an introduction for laymen.
Because it's really, really hard to visualize three-dimensional curvature (let alone four-dimensional space-time curvature). Drakkith's picture isn't bad, but it's still hard to understand what that means (at least to me).
Likes ohwilleke
... Here is rough indirect approximation and representation of gravity to a point(). A somewhat similar effect. A few pointers thought. It is important to limit yourself to only what the presentation is trying to convey. 2D appears to give the basic and effective illustration for GR. It is simpler when explained in manifolds. Anyways here is the link.
link: http://www.youtube.com/watch?feature=player_embedded&v=MTY1Kje0yLg
julcab12 said:
... Here is rough indirect approximation and representation of an actual dynamic physical effect of gravity to a point(). A few pointers thought. It is important to limit yourself to only what the presentation is trying to convey.
Cool. Though I think one thing to bear in mind is that setup has quite a lot of friction, so it doesn't produce orbits much at all like real ones. If you could produce the same sort of setup, but with minimal friction, that might change. But I doubt that's possible because anything placed on there will deform the sheet, which uses energy and acts as a source of friction. Gravity doesn't have this issue because you don't lose any energy when you deform space-time (if the deformation causes a reduction in the energy of the object doing the deforming, then that energy is stored in the fabric of space-time and not lost...the energy from deforming the sheet is lost to heat).
A fun thing to do [if you are really bored] with 2D spacetime diagrams is try to represent them in 3D using isometric projection.
Likes Android Neox
The universe is three-dimensional therefore when gravity is projected onto a two-dimensional analog plane it is for demonstration purposes. Gravity collapses space around the center of gravity in three dimensional space but in a two-dimensional analog plain gravity bends space. Only in flatland does gravity bend space.
Clayjay said:
Gravity collapses space around the center of gravity in three dimensional space...
That description sounds like the picture Drakkith linked to in post #3, and as he said, " It's a little more accurate than your standard 2d grid."
Yours is the first mention of 'space' in the thread, as opposed to space-time. I don't think gravity collapses space, but it does create different world lines in space-time - geodesics for mass in inertial frames.
I'm posting outside of my limits here, and standing by to learn more from the experts. :rolleyes:
Gravity certainly is a warping of space as well as space-time.
I have no experience in 4D isometric projection. I think I need bigger paper.
Likes ohwilleke
The rubber sheet model is imperfect but still excellent. It shows the curvature of space due to stretching (dilation) in a gravity well. Instead of viewing it from the side, it should be viewed from above because gravitational space dilation is radial... away from the observer. Also, as the sheet is stretched away from the observer, there need to be more lines added, like altitude lines on a topological map. If the lines on the sheet are separated by identical differences in gravitational potential energy, you can relate the difference in time flow between two points as a direct function of how many lines you have to cross to get from one point to the other.
If everyone understood and presented the rubber sheet model the way you do, we wouldn't have a problem with it. Unfortunately, very few do, so practically speaking it is a source of misconception and confusion, and that makes it a problem.
The correct picture that you describe is found in many decent textbooks because it's one of the better ways of explaining how a surface with Schwarzschild coordinate ##r## is a sphere of surface area ##4\pi{r}^2## and a surface with Schwarzschild coordinate ##r+\Delta{r}## is a sphere of surface area ##4\pi{(r+\Delta{r})}^2##, yet the distance between them is greater than ##\Delta{r}##. We just make an analogy between the circumference of circles in the "funnel" and the area of the spheres, and we're there. However, these correct presentations are seldom if ever done in terms of the rubber sheet model, and I will bet long odd against anyone who presents the rubber sheet model as an explanation understanding what's really going on.
The key is that if you showed a representation of space-time distortion around a body by drawing the three-dimensional spatial representation you get a drawing that is very confusing and hard to understand. Lines and grids all over the place. A bowling ball on a sheet just works better.
Can the explanation of Earth orbiting the sun but not being pulled in because it is moving perpendicular to the curvature of the sun be visualized like a swimmer that can overcome and undertow if they swim perpendicular to the force of the undertow? Also if anyone can explain the way time slows or speeds up relative to gravity or speed i would love to know. For some reason i can't picture how this is possible. From the moment twins are born they would age the same regardless how could one possible age slower based on gravity or speed. How do either of those variables really affect it?
I don't get what you are asking but it doesn't matter since the celestial orbits are well understood and there's no need for that kind of analogy (if that is in fact what you're striving for).
You should read up on it. Google "The Twin Paradox" and really study it. The different paths through spacetime will likely become clear to you after a while.
Also, just FYI, it is bad form here on PF to hijack a thread in this way. If you have a separate question, start your own thread.
I agree on the orbit being well understood I was thinking of a way to visualize the forces at play, why the Earth would not crash into the sun, how to think of the feeling on our bodies like the pulling force on your body when in an undertow but how you can overcome that force like the Earth does by moving perpendicular. But let's forget that one.
I get the twin paradox and its fine if calendars and clocks move slower, but biologically regardless of the movement of a second hand the twins bodies would have to be the same, not one older than the other. Or does speed and gravity change our biology in some fashion.
AGAIN, read about and actually study the Twin Paradox. The different paths through space-time fully explain that the twins CANNOT have the same age when they meet back up. It has nothing to do with biological processes slowing down (they don't) it is just what happens because of different paths through spacetime.
And by the way, clocks and calendars do NOT move slower. In their own frame of reference time passes at one second per second just as it does for the stay at home twin. It's just that different paths through space-time take different numbers of seconds.
Likes Jaime Rudas
I suppose so, assuming:
1. The water is flowing into something like a large hole from all directions such that the swimmer is moving in an ellipse around the hole.
2. The swimmer is moving quickly enough and never exerts a force towards or away from the hole.
It's certainly not the analogy I would go with though.
There are plenty of threads in the Relativity forum dealing with time dilation and the twin paradox. Please have a look there instead of asking in this thread.
Drakkith said:
There are plenty of threads in the Relativity forum dealing with time dilation and the twin paradox ...
You are a master of understatement. At last count there were 18,397
Likes Drakkith
... if calendars and clocks move slower, but biologically regardless of the movement of a second hand the twins bodies would have to be the same, not one older than the other. Or does speed and gravity change our biology in some fashion.
Biology and every other chemistry is all subject to the same clock regardless of speed and gravity.
In your own frame of reference one second always passes in one second.
While relative speed or gravity might make it look different to an observer in a different frame,
life for you, and biology in general is unchanged.
All true but still does not resolve his confusion because he does not understand different space-time paths creating differing amounts of time passage.
I have the same issue getting past this “ball on water” depiction of space-time (ST). I would like to see and hear ST depicted as a neutrally buoyant ball (mass) suspended in instead of on water. In that case, and assuming the ball is a perfect sphere and its mass is uniformly distributed, it would displace the same amount of water (ST) at any point around the sphere. How then would the path of that passing mass be effected in terms of bending of ST? I get stuck here, as it seems to me that, in that case, gravity must be an unseen force - a force inconsistent with the two dimensional depictions of bending ST.
I don't have the math. I need to get past this barrier in my thinking.
Hmmm. I'm not familiar with this depiction and I can't quite picture it from your description. What do you mean by "it would diplace the same amount of water (ST) at any point around the sphere"?
Not having the math is the barrier. As Roger Bacon said nearly 800 years ago:
Mathematics reveals every genuine truth, for it knows every hidden secret and bears the key to every subtlety. Whoever then has the effrontery to study physics while neglecting mathematics should know from the start that he will never make his entry through the portals of wisdom.
Likes vanhees71, Vanadium 50 and Jaime Rudas
Why would you like this? Why do you think it has any relevance to the actual theory of GR?
(Hint: it doesn't.)
Likes vanhees71
The best way to get past this kind of barrier is to give up the idea that you can come up with any useful visualization or intuitive picture without knowing the math and without having tried to work any problems yourself using the theory. Pop science books, articles, and videos try to peddle the fiction that this can be done, but unfortunately it can't. GR simply does not work like anything in your current intuitions; if you want to understand it intuitively, you need to retrain your intuitions. And that requires going through the laborious process of learning the actual theory, which means learning the math.
Likes vanhees71
True but. It’s a bit like trying to make sense / feeling about any partial differential equation is telling you. You look at the x’s and the y’s and the z’s and, if you’re lucky, you can appreciate the higher ‘slopes’ involved. Try to draw the surface and you may ‘get it’ yourself but will you get it across to another person? 2D is a common language and that may be your limit for some models. For orbits , 3D on 2D can help but the risk is that the drum skin will be taken literally and a rubber sheet will fail.
Be prepared for HARD MATHS.
About the time this thread was started.... :wink:
  • Haha
Likes sophiecentaur, berkeman, phinds and 1 other person
Related to Why is spacetime shown on a 2 dimensional plane?
1. Why is spacetime represented on a 2-dimensional plane?
The concept of spacetime was first introduced by Albert Einstein in his theory of General Relativity. In this theory, Einstein proposed that space and time are not separate entities, but rather they are interconnected and should be considered together. In order to visualize this complex concept, it is often represented on a 2-dimensional plane, where time is represented as the vertical axis and space as the horizontal axis. This allows for a simplified representation of the intricate relationship between space and time.
2. How does representing spacetime on a 2-dimensional plane help with understanding?
By representing spacetime on a 2-dimensional plane, it becomes easier to visualize and understand the concept of how space and time are interconnected. It allows for a simplified representation of complex mathematical equations and helps scientists and researchers to make predictions about the behavior of objects in the universe.
3. Are there any limitations to representing spacetime on a 2-dimensional plane?
Yes, there are limitations to representing spacetime on a 2-dimensional plane. This representation is based on the assumption that the universe has only three dimensions (length, width, and height). However, some theories, such as string theory, suggest that there may be more than three dimensions. Additionally, this representation does not take into account the effects of gravity and other forces on the fabric of spacetime.
4. How is the curvature of spacetime depicted on a 2-dimensional plane?
In the representation of spacetime on a 2-dimensional plane, the curvature is depicted as a bending or warping of the plane itself. This bending is caused by the presence of massive objects, such as planets or stars, which create gravitational fields that affect the fabric of spacetime. The amount of curvature is determined by the mass and energy of the objects present.
5. Can spacetime be represented in any other way?
Yes, there are other ways to represent spacetime, such as using mathematical equations or diagrams. However, the 2-dimensional plane representation is the most commonly used and widely accepted method, as it allows for a simpler visualization of this complex concept. Other methods may be used to explore specific aspects or theories of spacetime, but the 2-dimensional plane representation remains the most useful and widely applicable.
  • Beyond the Standard Models
  • Quantum Interpretations and Foundations
