Why is speed constant when centripetal acceleration is constant?
In summary: The acceleration in uniform circular motion is not constant, only its magnitude is. The proof for this can be seen by looking at the velocity and acceleration equations for a particle in uniform circular motion.
gionole
281
24
TL;DR Summary
It's actually getting little boring and makes me angry why all the videos/articles show centripetal acceleration formula and presume that speed is constant.
I want to prove backwards, i.e we know the constant perpendicular force acts on an object from the center and why object starts to move in circular motion with constant speed. I'm not looking for intuitive answer with (work, energy and so on), but the proof.
v2 = v1 + vβŠ₯ (vectors)
I think the logic I'm making a mistake is I presume that 𝑣βŠ₯=π‘Žπ‘‘π‘‘ This presumes that during 𝑑𝑑 time interval, π‘Ž is constant, hence this gives us > 0 value which means 𝑣⃗ 2>𝑣⃗ 1
After seeing another question, I realize π‘Ž is not constant during 𝑑𝑑 but even if it's not and changing, then we could split 𝑑𝑑 again in even smaller intervals(𝑑𝑑1,𝑑𝑑2,𝑑𝑑3,...) and say that 𝑣βŠ₯=π‘Ž1𝑑𝑑1+π‘Ž2𝑑𝑑2+π‘Ž3𝑑𝑑3+...... This way, π‘Ž is not constant over 𝑑𝑑. but now this should give us 0 and the only way this is possible is if over small 𝑑𝑑 interval, π‘Ž increases, then decreases and overally results in 0. What's the non-intuitive, solid proof that this is what happens?
proofs like this(https://physics.stackexchange.com/a/770948/366606) are horrible to be honest. Just making dt->0, doesn't say anything solid.
Could there be some good proof ? maybe could you draw a picture ? I understand how centripetal acceleration formula is derived, but they assume that speed is constant and thats how they derive with 2 similar triangles, but i'm tired of this. I need to prove speed is constant, not vice versa.
If you have a particle in uniform circular motion, by definition
$$\vec{x}(t)=a (\cos(\omega t),\sin(\omega t))$$
with ##\omega=\text{const}##. Then the velocity is
$$\vec{v}=\dot{\vec{x}}=a \omega (-\sin(\omega t),\cos(\omega t))$$
and the acceleration
$$\vec{a}=\dot{\vec{v}}=-a \omega^2 (\cos(\omega t),\sin(\omega t))=-\omega^2 \vec{x}.$$
As you see, the acceleration is not constant, because it's changing its direction. Only its magnitude is constant.
Likes SammyS and Lnewqban
Thanks for the answer. Though, you already start your logic by assuming uniform circular motion. but what I'm asking is what causes uniform motion(such as w = const). I need the proof that what causes uniform speed is actually true.
Yes, if ##dt## were a finite interval during which ##a## is constant in both magnitude and direction, this would mean that the ending velocity would have a larger magnitude than the starting velocity.
But we are talking about a limiting process. If we subdivide the actual curved arc more and more finely so that each individual ##dt## gets smaller and smaller, the cumulative ##\Delta v## computed by summing all of the ##dt##'s over a fixed arc length gets smaller and smaller as well.
The limit of the cumulative ##\Delta v## as ##dt \to 0## is zero.There is a different and more idiosyncratic way that I like to think about this conundrum. In deciding that velocity is increasing under the effect of a "radial" acceleration over a bunch of constant ##dt##'s, you are running time forward. You are basing your acceleration estimate on the starting velocity for each the interval. Naturally, you would get a result with velocity increasing into the future.
If you ran your simulation backward then you be basing your acceleration estimate on the ending velocity for each interval instead. You would get a result with velocity increasing into the past.
In my mind's eye, I see this as observer bias. An analysist who prefers the future to the past will see an increasing velocity.
An unbiased analysist will see that the two distinct results cannot both match reality. If one reduces the step size in the simulation, one sees that the discrepancy is reduced. Never eliminated, of course, just reduced. The correct physical result is obtained in the mathematical limit of the reduction process.
The limit of the cumulative is zero
I don't think this is the proof to be honest. I can say that in v = v0 + at. I will make dt -> 0 here, and even in any motion, i prove that v = v0. Do you like this ? i don't think so.
gionole said:
TL;DR Summary: centripetal acceleration
If you apply a force to an object in motion, then the component of the force in the direction of the velocity changes the object's speed. And the component of the force perpendicular to the velocity changes it's direction.
In general, therefore, a force of constant magnitude does not result in uniform circular motion. You only get uniform circular motion if the force is always perpendicular to the instantaneous velocity.
PS planetary orbits are elliptical in general with near circular orbits as a special case.
To do that, we start with ##\vec{F}=m\vec{a}## where ##\vec{F}## has constant magnitude ##F## and always points towards the center. This is a differential equation that we solve for ##\vec{x}(t)##, the trajectory of the moving object given its initial position and velocity. For any given distance from the center there is one particular combination of initial position and velocity we will find that the trajectory is the one given by @vanhees71 above, leading to the constant speed and acceleration conclusion.
This is only true for uniform circular motion; that sets the conditions for this particular discussion; there is no 'proof' about initial conditions. Only when you have a 'piece of string' to restrain a particle into a circular path will the centripetal force / acceleration have constant magnitude. There are many other systems with non-uniform circular motion; we only learn how to treat them when we have established the easiest situation.
That's a somewhat more complicated task. Just let's calculate it. It's a central-force problem with a potential,
$$V(\vec{x})=F_0 r \; \Rightarrow \; \vec{F}=-\vec{\nabla} V=-F_0 \vec{x}/r.$$
Then we have energy conservation and conservation of angular momentum:
$$\frac{m}{2} \dot{\vec{x}}^2+F_0 r=E=\text{const}$$
and
$$\vec{x} \times \dot{\vec{x}}=\vec{L}=\text{const}.$$
The latter equation means that the trajectory is a plane curve. Then we introduce polar coordinates in that plane, ##x_3=0##:
$$\vec{x}=(R \cos \varphi,R \sin \varphi,0).$$
This implies
$$\dot{\vec{x}}=\dot{R} (\cos \varphi,\sin \varphi,0) + R \dot{\varphi}(-\sin \varphi,\cos \varphi,0)$$
Then
$$E=\frac{m}{2} (\dot{R}^2+R^2 \dot{\varphi}^2)+F_0 R$$
and
$$\vec{L}=m R^2 \dot{\varphi} (0,0,1) \; \Rightarrow \; m R^2 \dot{\varphi}=L=\text{const}.$$
Eliminating ##\dot{\varphi}## from the energy equation gives
$$E=\frac{m}{2} \dot{R}^2 + \frac{L^2}{2m R^2} + F_0 R.$$
This is a separable differential equation for ##R(t)##, but the integral looks pretty much like an elliptic integral, i.e., we can't solve this in the general case.
Of course, circles around the center are always solutions for any central force. Then ##\dot{R}=0## and ##R=\text{const}##, which implies ##\dot{\varphi}=L/(m R^2)=\text{const}##, i.e., this leads to the solution given in the inverse way in #2.
Due to symmetry there is no way decide if it should increase or decrease, so it must be constant.
Or apply mechanical power definition:
P = F dot v
which is 0 when F and v are orthogonal, so no energy input/output, thus KE = const
Likes Vanadium 50
As my analysis in #10 shows, a central force with constant magnitude does NOT imply a constant speed and thus not ##R=\text{const}##. Of course, there are always special solutions with ##R=\text{const}## in any central-force problem. You can also analyze whether it's a stable solution.
I believe that the nature and magnitude of the tangential velocity is not as important as the movement of that object.
As per Newton's first law, the natural free movement is always linear.
"A body remains at rest, or in motion at a constant speed in a straight line, unless acted upon by a force."
Therefore, when that natural movement is perturbed by a force, the object resists that deviation from the straight line (centripetal force), which induces that reactive centripetal (towards the instantaneous center of rotation) force.
Whenever we have a perturbing vector force and a mass in movement, an acceleration vector is present.
That acceleration vector can be constant in magnitude (if the angular velocity is constant) or not, but it is always changing direction on the plane of rotation, exactly at the rate of the angular velocity.
I don't know how to do it, but I believe that you can prove that the tangential velocity does not need to be constant for you to have centripetal acceleration.
Whenever you see centripetal acceleration of constant magnitude, you either have constant angular velocity and constant radius of rotation, or one increasing as the other decreases, at such rates that the tangential velocity remains constant.
There is such a thing as non uniform circular motion, you know. Tie a string to a rock and swing it in a vertical circle. The motion of the rock is circular, but it's not uniform. The speed is constantly changing.
When you utter the phrase uniform circular motion you are assuming the speed is constant.
Likes sophiecentaur and vanhees71
You need to learn calculus.
  • Love
Likes vanhees71
Yes, and it's very easy in this case. See my posting #2.
[itex]F=m \cdot a [/itex] is the equation for bodies moving in a straight line. The corresponding equation for bodies in a rotating system is [itex]D=I\cdot\dot{\omega} [/itex] (moment of force equals moment of inertia times angular accelration).
  • Skeptical
Likes weirdoguy and PeroK
Use a bit of caution with that formulation. It works for rigid rotations where ##I## is constant. If you write with slightly more generality then you get a term from the product rule: ##D = \frac{dL}{dt} = \frac{d(I(t) \times \omega(t))}{dt} = I \frac{d\omega}{dt} + \omega \frac{dI}{dt}##
Admittedly, that more general formulation is still quite restricted. It applies to bodies that are sufficiently rigid to have an identifiable rotation rate. (e.g. a skater pulling in her arms).
Of course. Just as the original linear formula reads [itex]F=\frac{d}{dt}(m\cdot v) [/itex]
##m## is a constant (and not generally time dependent) in Newton's second law.
A particle moving in any trajectory obeys$$\vec F = m\vec a$$
You need to look in some other books. All that's needed is an assumption that the particle has the speed ##v## at some instant. It doesn't have to be constant.
Svein said:
Of course. Just as the original linear formula reads [itex]F=\frac{d}{dt}(m\cdot v) [/itex].
In rocket science [itex]\frac{dm}{dt} [/itex] is negative (the fuel is part of the mass).
The rocket equation is a special case where a time-dependent mass is considered. The rocket equation is, however, not a generalisation of Newton's second law. See, for example:
https://en.m.wikipedia.org/wiki/Tsiolkovsky_rocket_equation
Note that in the derivation there are two velocity terms. One is the instantaneous velocity of the rocket and the other is the exhaust velocity.
These are often conflated and the erroneous generalisation of Newton's second law is remarkably common.
Likes nasu
If the force is always perpendicular to velocity any force magnitude will give a constant speed.
If the force is towards a fixed point, and merely instantaneously perpendicular to velocity, then any force magnitude will give an instantaneous rate of speed change of zero, but only certain magnitudes will give constant speed over time. For other magnitudes the force simply won't remain perpendicular to velocity anymore.
This is something different. In #10 I analyzed the claim that a radial force with constant magnitude leads to constant speed, which is wrong.
It's of course different with what you say, because then the force is given as
$$\vec{F}=\vec{v} \times \vec{f},$$
where ##\vec{f}## can be an arbitrary function (of ##\vec{x}##, ##\vec{v}##, or whatever more), because then
$$\frac{\mathrm{d}}{\mathrm{d} t} \left (\frac{m}{2} \vec{v}^2 \right) = \vec{v} \cdot \vec{F}=\vec{0} \; \Rightarrow \; \vec{v}^2=\text{const}.$$
An example is a charged particle in an arbitrary magnetic field,
$$\vec{F}=q \vec{v} \times \vec{B}.$$
FAQ: Why is speed constant when centripetal acceleration is constant?
Why does constant centripetal acceleration result in constant speed?
Constant centripetal acceleration implies that the force acting towards the center of the circular path is uniform. This force changes the direction of the velocity vector but not its magnitude, thereby keeping the speed constant.
How does centripetal acceleration affect the velocity of an object in circular motion?
Centripetal acceleration affects only the direction of the velocity vector, not its magnitude. This means the object continuously changes direction to stay on the circular path, but its speed remains the same.
Can an object have centripetal acceleration without changing speed?
Yes, an object can have centripetal acceleration without changing speed. Centripetal acceleration changes the direction of the object's velocity, not its speed, so the speed remains constant while the object follows a circular path.
Is it possible for an object to have varying speed with constant centripetal acceleration?
No, it is not possible. Constant centripetal acceleration implies a constant magnitude of velocity (speed) because any change in speed would require a tangential component of acceleration, which would alter the centripetal acceleration.
What role does centripetal force play in maintaining constant speed in circular motion?
Centripetal force provides the necessary inward force to keep an object moving in a circular path. This force changes the direction of the object's velocity without altering its magnitude, thus maintaining a constant speed.
