Why is stress tensor (in this derivation) symmetric?
In summary, the online tutorial states that the second term must be identically zero (otherwise an infinitesimal fluid element would acquire an absurdly large angular velocity).
genxium
141
First by "this derivation" I'm referring to an online tutorial: http://farside.ph.utexas.edu/teaching/336L/Fluidhtml/node9.html
It's said in the above tutorial that the ##i-th## component of the total torque acting on a fluid element is
##\tau_i = \int_V \epsilon_{ijk} \cdot x_{j} \cdot F_{k} \cdot dV + \int_V \epsilon_{ijk} \cdot \sigma_{kj} \cdot dV + \int_V \epsilon_{ijk} \cdot x_{j} \cdot \frac{\partial \sigma_{kl}}{\partial x_{l}} \cdot dV## -- (*)
where
##\epsilon_{ijk}## is the permutation tensor (http://mathworld.wolfram.com/PermutationTensor.html),
##F_{i}## is the i-th component of the "volume force" acting on the fluid element
and ##\sigma_{ij}## is the "stress tensor" such that the i-th component of the total force acting on the fluid element is
##f_{i} = \int_V F_{i} \cdot dV + \oint_{S=\partial V} \sigma_{ij} \cdot dS_{j}##
The tutorial states that (slightly rephrased but tried to keep the same meaning)
from
Assuming that point ##O## lies within the fluid element, and taking the limit ##V \rightarrow 0## in which the ##F_i##, ##\sigma_{ij}##, and ##\frac{\partial \sigma_{ij}}{\partial x_j}## are all approximately constant across the element, we deduce that the first, second, and third terms on the right-hand side of the above equation scale as ##V^{4/3}, V, V^{4/3}##, respectively (since ##x \sim V^{1/3}##). Now, according to Newtonian dynamics, the ##i-component## of the total torque acting on the fluid element is equal to the ##i-component## of the rate of change of its net angular momentum about ##O##. Assuming that the linear acceleration of the fluid is approximately constant across the element, we deduce that the rate of change of its angular momentum scales as ##V^{4/3}##(since the net linear acceleration scales as ##V##, so the net rate of change of angular momentum scales as ##xV##, and ##x \sim V^{1/3}##). Hence, it is clear that the rotational equation of motion of a fluid element, surrounding a general point ##O##, becomes completely dominated by the second term. It follows that the second term must be identically zero (otherwise an infinitesimal fluid element would acquire an absurdly large angular velocity)
where "the second term" means ##\int_V \epsilon_{ijk} \cdot \sigma_{kj} \cdot dV## in (*).
It's not obvious to me why "the second term" doesn't approximate ##0## when ##V \rightarrow 0## but instead induces absurdly large angular velocity as it "scales as ##V## and ##V \rightarrow 0##".
I understand that it's worth considering ##V \ll 1## thus ##V \gg V^{4/3}## but this is not convincing enough for me to take "the second term" to ##0## and yield the symmetry of ##\sigma_{ij}##. For example, I could argue that even if the ##x_j## factor satisfies ##x_j \ll 1##, i.e. fluid element very close to point ##O##, in the first and third terms, it only makes the first and third terms "small" but NOT necessarily makes the second term "large" especially when ##V \rightarrow 0##.
The first and third term cancel each other due to force equilibrium.
Hi @Orodruin, sorry for the late response, I spent sometime reading the following chapters in the same tutorial and found that I still have problems in understanding this question.
Would you please explain or show some reference for
Why is the 1st term having such strong relationship with the 3rd one? In my understanding they're independent to each other (like, having different "origins"? I can't define this well at the moment) and they're just added together in equation (*).
Moreover how is your answer related to that "the 2nd term must be identically zero"?
Just like for any equilibrium, you need to have force as well as moment equilibrium for any small volume. You are currently working with the moment equilibrium and so you are writing down the moment acting on a small volume. The corresponding argumentation for the force equilibrium will give you ##F_i + \partial_j \sigma_{ij} = 0## and therefore your first and third terms will cancel out.
Requiring moment equilibrium then is giving that the second term is zero. This must be true for any volume and therefore the integrand must be zero.
Is "moment equilibrium" required implicitly in equation (*)? I'm afraid this is the essential point by which I'm confused :)
To my understanding by equation (*) I'm looking at the ##i-th## component of torque of a "fluid element" wrt a "might be randomly chosen" axis ##O##, and this "fluid element" is NOT EXPLICITLY REQUIRED to be static in this chapter (in fact, static fluid is discussed right in the following chapter: http://farside.ph.utexas.edu/teaching/336L/Fluidhtml/node10.html).
It's reasonable that the "fluid element" is not static but it's also required to match some kind of "equilibrium conditions", e.g. what you mentioned above, however this is not quite obvious to me. Would you mind explaining more explicitly? Is there any constraint on choosing the axis?
Btw, did you mean ##F_i + \frac{\partial \sigma_{ij}}{\partial x_i} dV = 0## by force equilibrium? The units would match in this way and it makes sense to me.
Related to Why is stress tensor (in this derivation) symmetric?
1. Why is the stress tensor symmetric in its derivation?
In the derivation of stress tensor, symmetry is assumed based on the physical properties of stress. Stress is a measure of the internal forces acting on a material, and as such, it must be symmetric in order to satisfy the laws of conservation of momentum and angular momentum. This means that the stress experienced by a material in one direction must be equal to the stress experienced in the opposite direction.
2. What evidence supports the assumption of symmetry in the derivation of stress tensor?
The assumption of symmetry is supported by experimental evidence and observations of the behavior of materials under stress. For example, when a material is subjected to shear stress, the resulting deformation is symmetric about the axis of the applied stress. This confirms that the stress experienced by the material is indeed symmetric.
3. Can the stress tensor be non-symmetric in certain situations?
In certain situations, such as when dealing with anisotropic materials, the stress tensor may not be symmetric. Anisotropic materials have different mechanical properties in different directions, and as such, the stress experienced by these materials may not be symmetric. However, in most cases, the stress tensor is assumed to be symmetric for simplicity and to adhere to the laws of conservation of momentum and angular momentum.
4. What happens if the stress tensor is not symmetric?
If the stress tensor is not symmetric, it would violate the laws of conservation of momentum and angular momentum. This means that the resulting equations and solutions would not accurately describe the behavior of materials under stress. It is important to ensure that the assumed symmetry of the stress tensor is consistent with the physical properties and behavior of the material being studied.
5. Are there any exceptions to the assumption of symmetry in the derivation of stress tensor?
The assumption of symmetry in the derivation of stress tensor may not be applicable in certain cases, such as when dealing with non-Newtonian fluids or viscoelastic materials. These materials have complex behaviors and may require different formulations of stress tensor that take into account their non-symmetric properties. It is important to carefully consider the physical properties of the material being studied before making assumptions about the symmetry of the stress tensor.
  • Classical Physics
  • Classical Physics
  • Classical Physics
