Why is the Axiom of Power Set needed?
In summary, the Zermelo-Fraenkel axioms include an axiom that states the existence of a power set for any given set. This is necessary because definitions only serve to support language and abbreviate it, while axioms are rules that determine allowed conclusions. Without this axiom, the existence of a power set would need to be proved, which can be difficult in certain cases. Additionally, the axiom helps to avoid paradoxes and maintain the restrictions on what can be considered a "set" in ZF theory.
pellman
684
In the Zermelo-Fraenkel axioms of axiomatic set theory we find:
Axiom. Given any set x, there is a set
dcde29bc2e45577cf48fce37eace431df129adf0
such that, given any set z, this set z is a member of
if and only if every element of z is also an element of x.
Why is this needed as an axiom? why isn't it merely a definition? Under what situation would the existence of the power set be in question? seems like it can always be constructed.
Definitions are only names. They do not have any other function than to support language and abbreviate it.
Axioms are rules. They determine whether a conclusion is allowed or not.
Why does a power set exist at all? Do you know a derivation from the other axioms?
If it was a definition, then it would read: "A set with this and that property is called a power set."
As an Axiom, the existence of such a set is required: "There is a power set."
So the axiom frees you from the need to construct one, which would be rather difficult for let's say ##x=\mathbb{R}\,.##
Apparently it is used to prove that Cartesian products exist. Look at the proof used here where there is no such axiom.
You can only define objects that already exist.
As an easy example, we can define ##\sqrt{x}## for ##x \geq 0## as the unique number ##y \geq 0## with ##y^2 =x##.
But who says that such a number ##y## exists? And that it is unique? These things have to be verified (and any proof will somehow invoke the LUB property), or the definition wouldn't make sense.
For the same reason, before we define what the term "power set" means, we have to verify if that object exists.
Since we can't deduce the existence of the power set from the other ZFC axioms, it is added as an axiom.
Likes mathwonk, Tosh5457 and FactChecker
i am a novice in this area, but in my opinion an essenctial point here is to note that the word "set" has a special significance in ZF theory. I.e. to avoid problems arising from naive treatment of sets, one has to disallow certain collections of objects that can be easily described, from being called "sets". So even though the description of P(X) seems to be something one could easily imagine, hence it surely exists in the imagination, it still is saying something that this object deserves to be labeled a "set". I.e. those classes of objects that are called sets must be restrictive enough so as not to allow any of the usual ("set of all sets") paradoxes to arise. The idea here seems to be that if one has a class of allowable sets that do not lead to a paradox, then including also all their powers, then still no paradox will arise. Without that, this axiom would not be a good one. I.e. the collection of all sets appears also to exist, at least in language, but it apparently may not be called a "set" in ZF theory. So, building on the previous post, an axiom is added when it not only gives something new and useful, but (hopefully) also does not lead to a contradiction.
Related to Why is the Axiom of Power Set needed?
1. Why is the Axiom of Power Set necessary?
The Axiom of Power Set is necessary because it allows us to define and work with sets that contain all possible subsets of a given set. Without this axiom, we would not be able to fully explore the properties and relationships of sets, making it an essential tool in set theory.
2. What does the Axiom of Power Set state?
The Axiom of Power Set states that for any set, there exists a set that contains all possible subsets of that set. In other words, for every set A, there exists a set B that contains all possible subsets of A.
3. How does the Axiom of Power Set work?
The Axiom of Power Set works by allowing us to take any set and create a new set that contains all possible subsets of the original set. This allows us to define and work with sets that have infinite elements, as well as investigate the relationships between elements within a set.
4. Can the Axiom of Power Set be proven?
No, the Axiom of Power Set cannot be proven. It is an axiom, which means it is accepted as a fundamental truth without needing to be proven. However, its validity has been supported through its usefulness in constructing and analyzing mathematical theories.
5. Are there any limitations to the Axiom of Power Set?
The Axiom of Power Set does have some limitations, as it can lead to the creation of sets that are too large to be considered sets in traditional mathematics. This is known as Russell's paradox and has led to the development of other axioms, such as the Axiom of Regularity, to prevent such contradictions.
