zippyhippy
- 2
Hey guys,
So in class I learned that the current has to have a constant value in a series circuit. We later went on to learn that if the current were not the same, charges would clog up in certain parts of the circuit. I'm having trouble understanding this. I've been scouring the internet for a simulation of this, but I can't find one! Please help me.
To clarify, this is what we learned (maybe a bit off):
We have two resistors linked in a series circuit, one wider than the other (so the wider one has less resistance). At the junction between the wider resistor and the narrower resistor, charge builds up as it tries to enter the narrower resistor. As the charges build up, their electric field pushes against the original electric field of the wider resistor and the electric field of the charges that go through add to the electric field of the narrower resistor.
But how does this mean that the current is the same? What if you had a narrower resistor first, linked to a wider one? Would it be the same?
I also tried to explain it this way:
The charges in the wider resistor are traveling at a slower rate than those in the narrower resistor. However, there is more charge/are more electrons passing a point in the wider resistor than there are in the narrower resistor (more lanes vs. less lane). The extent to which these increase or decrease result in a constant current. The wider resistor has more electrons but a slower speed, while the narrower resistor has less electrons but a greater speed.
Thanks for reading through my essay. I hope you can help me out.
