Why Is the Diophantine Problem for \( R[T] \) Solvable If It Is for \( R \)?
  • MHB
  • Thread starter mathmari
In summary, the diophantine problem for $R[T]$ with coefficients in $\mathbb{Z}$ is solvable if and only if the diophantine problem for $R$ with coefficients in $\mathbb{Z}$ is solvable. This is because any solution of the equation with coefficients in $\mathbb{Z}$ is also a solution of the polynomial equation with coefficients in $\mathbb{Z}$, so if there is an algorithm to decide whether or not an equation has a solution in $R$, then there is also an algorithm to decide whether or not a polynomial equation has a solution in $R[T]$.
mathmari
MHB
5,049
Hey! :eek:
One part of the paper that I am reading is the following:
Let $R$ be a commutative ring with unity and let $R'$ be a subring of $R$.
We say that the diophantine problem for $R$ with coefficients in $R'$ is unsolvable (solvable) if there exists no (an) algorithm to decide whether or not a polynomial equation (in several variables) with coefficients in $R'$ has a solution in $R$.
$$\dots \dots \dots \dots \dots$$
Theorem.
Let $R$ be an integral domain of characteristic zero; then the diophantine problem for $R[T]$ with coefficients in $\mathbb{Z}[T]$ is unsolvable.
($R[T]$ denotes the ring of polynomials over $R$, in one variable $T$.)
It is obvious that the diophantine problem for $R[T]$ with coefficients in $\mathbb{Z}$ is solvable if and only if the diophantine problem for $R$ with coefficients in $\mathbb{Z}$ is solvable.
Could you explain to me the last sentence?
Why does this stand?
Does the direction $\Leftarrow$ stand because of the following?
We know that there is an algorithm that decides whether or not an equation with coefficients in $\mathbb{Z}$ has a solution in $R$.
We consider this equation as the constant term of a polynomial equation, so there is an algorithm that decides whether or not an equation with coefficients in $\mathbb{Z}$ has a solution in $R[T]$.
Is the justification of this direction correct?
Yes, the justification of this direction is correct. When we consider an equation with coefficients in $\mathbb{Z}$ as the constant term of a polynomial equation, it follows that any solution of the equation with coefficients in $\mathbb{Z}$ is also a solution of the polynomial equation with coefficients in $\mathbb{Z}$. Therefore, if there is an algorithm to decide whether or not an equation with coefficients in $\mathbb{Z}$ has a solution in $R$, then it follows that there is an algorithm to decide whether or not a polynomial equation with coefficients in $\mathbb{Z}$ has a solution in $R[T]$.
FAQ: Why Is the Diophantine Problem for \( R[T] \) Solvable If It Is for \( R \)?
What is the diophantine problem for R[T]?
The diophantine problem for R[T] is a mathematical problem that involves finding integer solutions to polynomial equations where the coefficients are taken from the ring R[T] of polynomials with coefficients in the ring R.
Why does the solvability of the diophantine problem for R[T] depend on the solvability of the diophantine problem for R?
This is because every polynomial in R[T] can be written as a linear combination of powers of T with coefficients in R. Therefore, if the diophantine problem for R is solvable, then the diophantine problem for R[T] is also solvable.
Can you provide an example to illustrate this concept?
Sure. Let's say we have the polynomial equation 2x^2 + 3x + 1 = 0 with coefficients in the ring Z. This is a diophantine problem for Z because we are looking for integer solutions. Now, we can rewrite this equation as (2+3T+T^2)x^2 + (3+T)x + 1 = 0, where the coefficients are now in the ring Z[T]. Therefore, the diophantine problem for Z[T] is solvable if the diophantine problem for Z is solvable.
Is the converse also true?
No, the converse is not always true. Just because the diophantine problem for R[T] is solvable does not necessarily mean that the diophantine problem for R is solvable. This is because the additional variable T in R[T] may introduce new solutions that were not possible in R.
What are the implications of this result in mathematics?
This result has important implications in the study of diophantine equations and in the theory of rings. It allows us to reduce the solvability of more complex equations in R[T] to simpler equations in R, which can make them easier to solve. It also helps us understand the relationship between polynomial rings and their coefficients.
