Why is the drain current steady after pinchoff in a JFET?
In summary, the pinch-off voltage in a JFET is the point where the drain current becomes constant and the channel becomes resistive. Despite the depletion region blocking the channel, the drain current is still able to flow at the maximum channel width. When a gate voltage is applied that completely stops the drain current, it is because the gate is limiting the channel width and the current is reduced to a minimum.
Muhammad Usman
52
TL;DR Summary
1) At pinch off voltage the depletion region blocks the channel so how does the current still flow or it remain constant.
2) What happens when we apply the gate voltage that completely stopped the drain current as depletion region for P-types already touched each other.
Hi,
I was studying JFET and it was written that at Pinch off voltage the drain current becomes constant. And when the gate to source voltage is applied. The more negative the voltage is the current will be decreased and eventually reached to 0. I don't understand below both points.
2) What happens when we apply the gate voltage that completely stopped the drain current despite the fact the depletion region is already touched or blocked.
Please consider me as a basic learner while replying.
It does NOT block the channel. The term pinch-off voltage is very misleading.
With the gate connected to the source, Vgs = 0, the pinch-off voltage is defined as the drain voltage, Vds, at which the channel changes from being resistive to being current limiting. The drain current, Id, is then at a maximum and is limited by the maximum channel width.
Referring to the most common N-channel depletion mode JFET.
Gate voltages, Vgs, more positive than the source cannot further increase the width of the channel as it is then limited by the physical size of the gate structure.
As the gate voltage, Vgs, becomes more negative, the gate progressively increases in thickness. That progressively restricts the channel width, until the channel width approaches zero, when the drain current, Id, is reduced to the minimum.
Related to Why is the drain current steady after pinchoff in a JFET?
What is the basic principle behind the steady drain current in a JFET after pinchoff?
The steady drain current in a JFET after pinchoff is based on the principle of channel width modulation. As the gate-to-source voltage increases, the depletion region widens, reducing the channel width and therefore limiting the current flow.
How does the drain current remain constant after pinchoff in a JFET?
The drain current remains constant after pinchoff in a JFET because the depletion region has reached its maximum width, and further increases in gate-to-source voltage do not result in a significant change in channel width. Therefore, the current remains steady.
What factors can affect the steady drain current in a JFET after pinchoff?
The steady drain current in a JFET after pinchoff can be affected by the gate-to-source voltage, the channel width, the channel length, and the material properties of the JFET. Any changes in these factors can result in a change in the steady drain current.
Why is the steady drain current in a JFET after pinchoff important?
The steady drain current in a JFET after pinchoff is important because it determines the operating point of the JFET and affects its performance. It also allows for precise control of the current flow, making JFETs useful in various electronic applications.
Can the steady drain current in a JFET after pinchoff be altered?
Yes, the steady drain current in a JFET after pinchoff can be altered by changing the gate-to-source voltage or by using a different JFET with different material properties. However, it is important to note that the current will still remain steady after pinchoff, but at a different level.
  • Electrical Engineering
20K
  • Atomic and Condensed Matter
