Why is the E-field inside a solid conducting sphere zero?
In summary, when a conductor has a net charge, the charges arrange themselves symmetrically around the outside of the sphere, resulting in a canceled electric field inside. However, if the charge is placed on a point outside of the sphere, the charges cannot arrange themselves symmetrically and the electric field inside will not be zero. This is because a conductor has mobile charge carriers that will move until the imposed field is canceled. This can be mathematically proven using the method of "image charges".
OmegaKV
The common explanation is this: If the conductor has a net charge, then the charges repel each other until they arrange themselves symmetrically around the outside of the sphere, and if you do the math the electric field will cancel out everywhere inside the conducting sphere.
Alright, but what if the charge is placed on a point outside of the sphere instead of on the sphere? If you keep the charge separate from the conducting sphere, then the charges won't be able to arrange themselves symmetrically around the sphere to make the electric field inside the conductor cancel out. What keeps the electric field inside the conductor zero in this case?
The charges within the conducting sphere will arrange themselves so that they cancel any imposed field from the charges outside the sphere. That rearrangement will not be symmetric.
Likes OmegaKV
Interesting, I hadn't previously considered that there are charges on the conductor when it is electrically neutral.
Sure. What makes a conductor a conductor is the presence of mobile charge carriers (such as electrons) that can move easily in response to an imposed field. In the electrostatic case, the charges will move until the imposed field is canceled.
It's a mathematical theorem of potential theory. In the case of the sphere you can find the Green's function analytically, using the method of "image charges". You'll find that in the case that charges are present only outside of the sphere the field inside is 0.
Related to Why is the E-field inside a solid conducting sphere zero?
1. Why is the electric field inside a solid conducting sphere zero?
The electric field inside a solid conducting sphere is zero because the charges in the sphere rearrange themselves in such a way that the electric field they produce cancels out. This is known as electrostatic shielding.
2. Does this mean there is no electric potential inside a solid conducting sphere?
No, the electric potential inside a solid conducting sphere is not zero. It may be constant or have a specific value, depending on the charge distribution on the surface of the sphere.
3. Can there be situations where the electric field inside a solid conducting sphere is not zero?
Yes, if there is an external electric field present, it will penetrate the surface of the conducting sphere and create an induced electric field inside. However, this induced field will only exist until the charges in the sphere rearrange to cancel out the external field.
4. How does the radius of the conducting sphere affect the electric field inside?
The radius of the conducting sphere does not have an effect on the electric field inside. As long as the sphere is a perfect conductor, the electric field inside will always be zero, regardless of its size.
5. Is the electric field inside a hollow conducting sphere also zero?
Yes, the electric field inside a hollow conducting sphere is also zero. This is because the charges on the inner surface of the sphere rearrange themselves to create an electric field that cancels out the external field, similar to how it works in a solid conducting sphere.
