Why is the emissivity of metals low?
In summary: I don’t, provided the energy source is radiation. It would help if you clarify instead of rushing to seek agreement for...
jaumzaum
434
33
Hello! I am having trouble to understand why the emissivity of polished metals is much lower than if they are not polished.
Consider, for example, non-polished aluminium at 300K, which is said to have an emissivity of 0.77. We put it floating in vacuum. There is an energy source near it, and in this configuration it absorbs 77W of energy (and emits 77W as it is in thermal equilibrium). Now the metal is polished. It's emissivity drops to 0.05. For it to be in thermal equilibrium the emissivity must be equal to the absorvivity, so that the new emited/absorbed energy is 5W.
If we apply Stefan-Boltzmann law:
$$\sigma T'^4 = \frac{0.05} {0.77} \sigma 300^4$$
$$T'=152K$$
That way the metal needs to drop its temeprature to -121 celcius degrees! Is this true?
I was wondering why don't we see low temperature polished metals in real world situations, is this because the metals are in contact with other surfaces such that conduction plays more? Even with conduction, I would suppose the temperature of polished metals wpuld still be some degrees lower than that of the ambient. Is it true? How much?
EDIT: Even considering conduction, if we consider a body with 1m length and surface area of 1m^2 in 300K, it would radiate 460W of energy. Consider this body is on a table that made of wood at 300K, with thermal conductivity of 0.2 W/mK, This would give a very huge temperature drop.
A black body both absorbs and emits radiation. In fact for any wavelength light the emissivity and absorbtivity are exactly equal (this is dictated by the second law of thermodynamics).
Given enough time any isolated object will radiatively reach temperature equilibrium with its surroundings. The emissivity /absorbtivity will determine the rate at which this happens.
In non-isolated situations (a pot on a stove) the shiny object will emit less heat (which is why pots are polished
Likes Spinnor, vanhees71, russ_watters and 1 other person
$$T'=152K$$
If the metal is polished, we can see that it creates an image of the source, which is a coherent secondary source and radiates almost as much power as it receives.
If the surface is irregular, we see many secondary sources of radiation which are incoherent - they are of random phase. So the rays do not add coherently and the radiated power is less.
You might be interested in the information on the Rayleigh Roughness Criterion under a Google search.
Likes vanhees71, russ_watters, jaumzaum and 1 other person
What? Changing the emissivity does not change the equilibrium temperature. It only changes how quickly it reaches equilibrium.
Likes sophiecentaur, vanhees71, etotheipi and 1 other person
True enough but if you read the passage carefully (I did not originally do so!) there is an energy source near the pot so this is a steady-state but nonequilibrium situation.
Likes jaumzaum
@hutchphd you Agee with the calculations?
As long as the energy source is providing energy via radiation the equilibrium temperature is the same. I guess if it were providing energy by conduction it would make a difference.
Likes hutchphd and russ_watters
I don’t, provided the energy source is radiation. It would help if you clarify instead of rushing to seek agreement for an ambiguous scenario.
Likes vanhees71, hutchphd and davenn
To do the calculation correctly you need to include the details of the "energy source" and perhaps the details of the incoming radiation from the ambient room.
So as @Dale says you need to be much more specific...it looks like you have started OK but that is all one can say.
Likes vanhees71 and Dale
Ok. So let's consider a energy source that radiates 2000W of energy. There are no other energy sources in the system. There is an object, floating in vacuum (so there is no convection or conduction), that receives 100W of irradiated energy from the energy source. It's initial emissivity is 0.77. In the equilibrium, 23W of the irradiated energy is reflected/transmitted and 77W is absorbed by the body. For it to be in equilibrium it needs to emit 77W. Consider the body is a cube of side 1m. We can do some calculations:
$$ 77 = 0.77 \times \sigma \times T^4$$
$$T=205K$$
Now consider this body is polished and the emissivity becomes 0.05. In equilibrium the body emits 5W:
$$ 5 = 0.05 \times \sigma \times T^4$$
$$T=205K$$
I was wrong before, it really does not seem to affect the temperature of the body if we change the emissivity. Is it right now?
Likes Dale
That seems better. Of course even in the vacuum of deep space the universe will be radiating back at you isotropically with characteristic 4K blackbody (microwave background). There will always be incoming radiation in addition to your source so you really need to subtract it to get net emission to find T.
This is hard to understand. Why would a coherent reflection, where all the received and reflected radiation from a point ends up radiating as if from a single image (spherical or cuboidal pan) radiate any more energy, just because there is no identifiable image. Conservation of Energy could just as easily apply except when the surface is so rough as to cause multiple reflections before the radiation finally leaves. Deep surface roughness depth would / could affect the absorption according to angle.
I can't help thinking that a polished surface is cleaner, with no resistive oxide layer (1014 Ωcm) and the conductivity of the surface layer would be greater and the induced surface currents would be greater and cause more re-radiation. Would shininess (coherent reflection of visible wavelengths) be as important as flatness on a bigger scale (if at all) when dealing with much longer IR wavelengths? Microwave reflectors are not made with shiny surfaces so there must be something in my suggestion.
But :
That seems to be a massive effect for a single molecular thickness of Aluminium Oxide[/SUP]
Dale said:
I think that the 0.77 emissivity is for anodized aluminum.
https://www.engineeringtoolbox.com/emissivity-coefficients-d_447.html
Anodization is a few tens of microns thick, and dramatically changes the surface.
Random oxidation of the surface would probably be much more shallow though. But how much difference is due to the surface components and how much to the roughness would be interesting. How 'shiny' is 'shiny', for the purposes of that 0.05 figure, I wonder.
Rough aluminum is 0.07 and highly polished is 0.05. So I would estimate that the roughness/smoothness contribution is fairly small. In contrast, heavily oxidized is 0.25. So I would estimate that the oxidation contribution is the dominant one. This goes along with the fact that the 0.77 figure is for anodized aluminum which is basically just a deliberately thick layer of oxidation. So I would guess that the difference between 0.77 and 0.05 is much more to do with the simple fact that aluminum oxide has different emissivity than aluminum. Apparently aluminum oxide is much better at radiating than aluminum itself, which shouldn't be too surprising.
Likes sophiecentaur
I believe (as indicated by @sophiecentaur) that this is a spurious argument.
If the rough surface itself is perfectly reflective, the presence of the roughness will certainly diminish the specular reflection, but the diffuse reflectance increases . The net reflected power is the same . As I recall there are variants of the optical theorem that show this (and I will provide a reference if I can...)
If however there are dissipative channels the roughness will often facilitate coupling to these internal degrees of freedom in the metal creating inelastic scattering of various kinds.
Likes tech99 and sophiecentaur
If the small hills and valleys are steep enough then a significant amount of radiated energy can be reflected multiple times - with loss at each reflection. At the other end of the scale of things, a very good absorber / radiator can be made with deep pile black velveteen.
Likes hutchphd
I think Aluminium Oxide is a good dielectric and can support long waves efficiently but it has a crystalline structure which scatters waves with a wavelength comparable to the size of the crystals, such as light.
Likes sophiecentaur and Dale
Related to Why is the emissivity of metals low?
1. Why do metals have low emissivity?
Metals have low emissivity because they are highly reflective. This means that they reflect a large portion of the electromagnetic radiation that hits their surface, rather than absorbing and emitting it as heat.
2. How does the atomic structure of metals affect their emissivity?
The atomic structure of metals plays a significant role in their low emissivity. Metals have a highly ordered and tightly packed lattice structure, which allows them to easily reflect electromagnetic radiation instead of emitting it.
3. Why do some metals have higher emissivity than others?
The emissivity of metals can vary depending on their composition and surface properties. For example, rougher surfaces and alloys with different elements may have higher emissivity than pure metals with smooth surfaces.
4. How does temperature affect the emissivity of metals?
Temperature can affect the emissivity of metals in two ways. First, as the temperature of a metal increases, its emissivity may also increase due to a phenomenon known as thermal radiation. However, at extremely high temperatures, metals may begin to emit more radiation as they approach their melting point.
5. What are some practical applications of low emissivity in metals?
The low emissivity of metals has various practical applications, such as in the construction of energy-efficient buildings. By using low emissivity metals in windows and roofing, less heat is able to escape or enter a building, reducing the need for heating and cooling. Low emissivity metals are also used in the production of reflective coatings for mirrors and solar panels.
  • Thermodynamics
  • Classical Physics
  • General Engineering
  • Atomic and Condensed Matter
26K
