Why Is the Existence of m and n Guaranteed in the Cauchy Sequence Proof?
In summary, the article explains that if $\left\{{x}_{n}\right\}$ is a Cauchy sequence, then we can use a method to prove that it is Cauchy. However, there is a problem with the method that I need help with.
ozkan12
149
to prove that $\left\{{x}_{n}\right\}$ is Cauchy seqeunce we use a method. I have some troubles related to this method. Please help me...
$\left\{{c}_{n}\right\}$=sup$\left\{d\left({x}_{j},{x}_{k}\right):j,k>n\right\}$.Then $\left\{{c}_{n}\right\}$ is decreasing. If ${c}_{n}$ goes to 0 as n goes to $\infty$, then we are done. Assume that ${c}_{n}$ goes to c>0. Choose $\varepsilon$ <$\frac{c}{8}$ small enough and select N such that for all n$\ge$N.$d\left({x}_{n},{x}_{n+1}\right)$<$\varepsilon$ and ${c}_{n}$<c+$\varepsilon$.
By definition of ${c}_{N+1}$ there exists m,n $\ge$ N+1 such that d(${x}_{m}$,${x}_{n}$)>${c}_{n}$-$\varepsilon$>c-$\varepsilon$.
why By definition of ${c}_{N+1}$ there exists m,n $\ge$ N+1 such that d(${x}_{m}$,${x}_{n}$)>${c}_{n}$-$\varepsilon$>c-$\varepsilon$. I didn't understand. Please explain to me...Thank you :)
Hi ozkan12,
Since $c_{N+1}$ is the least upper bound of the set $A_{N+1} := \{d(x_j,x_k): j, k > N+1\}$, $c_{N+1} - \varepsilon$ is not an upper bound of $A_{N+1}$. So there exists $m, n > N+1$ such that $c_{N+1} - \epsilon < d(x_m,x_n)$. This is what follows from definition. The inequalities $d(x_m,x_n) > c_n - \varepsilon > c - \epsilon$ are incorrect. Note that since $c - \varepsilon < c_n$ for all $n \ge N$, $c_N - \varepsilon > c - 2\varepsilon$, not $c_N - \varepsilon > c - \varepsilon$.
But this is written in article ? If you want, you send your email adress...I can send article to you
Let me get more to the point. The inequality $d(x_m,x_n) > c_n - \varepsilon > c - \varepsilon$ should be $d(x_m,x_n) > c_n - \varepsilon \ge c - \varepsilon$, so not all inequalities are strict. What we know is that $c_n$ decreases to $c$, so $c_n \ge c$ for all $n \in \Bbb N$. However, we do not know that $c_n > c$ for all $n \ge N$, which is what you'll need to establish the strict inequality $c_n - \varepsilon > c - \varepsilon$.
We can prove $d(x_m, x_n) > c_n - \varepsilon$ from the fact $d(x_m,x_n) > c_{N+1} - \varepsilon$. Indeed, since $n > N+1$ then $c_{N+1} \ge c_n$. Thus $d(x_m,x_n) > c_{N+1} - \varepsilon \ge c_n - \varepsilon$.
Yes...But I don't understand How we can prove d(xm,xn)>cn−ε from the fact d(xm,xn)>cN+1−ε and
why By definition of cN+1 there exists m,n ≥ N+1 such that d(xm,xn)>cn-ε>=c-ε
I did explain it in my last post, but let me try again. Since $\{c_k\}$ is decreasing and $n > N+1$, then $c_{N + 1} \ge c_n$. Hence $c_{N+1} - \varepsilon \ge c_n - \varepsilon$. Since $d(x_m, x_n) > c_{N+1} - \varepsilon$ and $c_{N+1}-\varepsilon \ge c_n - \varepsilon$, then $d(x_m, x_n) > c_n - \varepsilon$.
Now since $c_n \ge c$ (because the sequence $\{c_k\}$ decreases to $c$), $c_n - \varepsilon \ge c - \varepsilon$. Therefore $d(x_m, x_n) > c_n - \varepsilon \ge c - \varepsilon$.
I understood thank you so much :) But I have a little problem there exists m,n>N+1 such that cN+1−ϵ<d(xm,xn).
Why Hence cN+1>d(xm,xn)−ε. I didnt understand
The part "Hence $c_{N+1} > d(x_m,x_n) -\varepsilon" was accidental; it wasn't supposed to be there. (Tongueout) Sorry about that! I have removed that statement. Hopefully everything is clear now.
Thank you so much, it is very helpful for me :)
FAQ: Why Is the Existence of m and n Guaranteed in the Cauchy Sequence Proof?
1. What is a Cauchy sequence?
A Cauchy sequence is a sequence of real or complex numbers in which the terms get closer and closer together as the sequence progresses. This means that for any small margin of error, there exists a term in the sequence after which all subsequent terms are within that margin of error.
2. How is the Cauchy sequence proving method used to prove the convergence of a series?
The Cauchy sequence proving method is used to prove that a series converges by showing that the sequence of partial sums of the series forms a Cauchy sequence. If the sequence of partial sums is a Cauchy sequence, then the series is said to converge to a finite limit.
3. What is the importance of the Cauchy sequence proving method in mathematics?
The Cauchy sequence proving method is important in mathematics because it provides a rigorous way to prove the convergence of a series. It is also a fundamental concept in analysis and is used in many mathematical proofs and theorems.
4. Can the Cauchy sequence proving method be used to prove the divergence of a series?
No, the Cauchy sequence proving method can only be used to prove the convergence of a series. It cannot be used to prove the divergence of a series, as a series can diverge even if its sequence of partial sums is a Cauchy sequence.
5. Are there any other methods for proving the convergence of a series?
Yes, there are other methods for proving the convergence of a series, such as the comparison test, the ratio test, and the root test. These tests all use different criteria to determine the convergence or divergence of a series.
