Why is the gradient vector normal to the level surface?
In summary, the gradient of a function involving only two variables is the instantaneous rate of change of one variable with respect to the other, and is usually tangent to the curve. However, in 3 dimensions, the gradient vector is the direction of maximum increase, which is orthogonal to the level surface. The gradient vector represents the rate of change of a function relative to a change of position in two or three dimensions. In addition, the gradient vector of a function in the form of a plane equation has no component in the direction of the variable being solved for, while the gradient vector of a function in the form of a constant equation has a component in the direction of the variable being solved for.
animboy
27
In functions involving only two variables the gradient is supposed to be the instantaneous rate of change of one variable with respect to the other and this is usually TANGENT to the curve. So then why is the gradient NORMAL to the curve at that point, since it is supposed to represent the direction of maximum increase?
Same thing for 3 dimensions. Shouldn't the direction of maximum increase be some vector tangent to the level surface at a point rather than orthogonal? Yet the gradient vector is the direction of maximum increase and is orthogonal. Also I would like to know what exactly the gradient vector represents, since I have usually understood derivatives to be of one variable with respect to another eg, "dy/dx". Than what exactly does "d/dx" or "d/dy" represent (ie. what is their physical/geometric interpretation, how can I visualize this?). And by extension, what does a gradient vector in 3d represent, an increase in exactly WHAT? I know that when the equation of a plane is given in the form:
z = x + y
The gradient vector has no z component and represents the direction in the xy plane corresponding to maximum increase in "z". But what about when an equation is given in the form
K = x + y + z
Then the gradient vector is calculated in terms of x, y and z, but what does it now represent? Since K is a constant and neither increase nor decreases?
Thanks
No, you are misunderstanding what function we are talking about. You seem to be thinking of f as changing value on a surface. f is a function of three variables, NOT restricted to that surface. A "level surface" (or "level curve" in two dimensions) for function f(x,y,z) is a surface upon which f is constant. The derivative of f in a direction tangent to a level surface would have to be 0, not a maximum. Since the derivative of f in a direction pf unit vector [itex]\vec{v}[/itex] tangent to the level surface is [itex]\nabla f\cdot\vec{v}= 0[/itex], and [itex]\vec{v}[/itex] is not 0, it follows that [itex]\nabla f[/itex] is perpendicular to [itex]\vec{v}[/itex]. Since it is perpendicular to every vector tangent to the surface, it is perpendicular to the surface.
[itex]\nabla f[/itex] is the rate of change of f relative to a change of position in two or three dimensions. That change of position is a vector, not a number.
z = x + y
The gradient vector of what function? Are you thinking of this as z= f(x,y)= x+ y or as f(z,y,z)= x+ y- z= 0?
The gradient of the first is [itex]\nabla z= \nabla f= \vec{i}+ \vec{j}[/itex] which has "no z-component" because you really talking about a function of x and y only. If you are thinking of z= x+ y as a level surface of f(x,y,z)= x+ y- z, then [itex]\nabla f= \vec{i}+ \vec{j}- \vec{k}[/itex] which certainly does have a z compoent.
K = x + y + z
Again, you are confused as to what your function is. If you are thinking of z as a function of x and y, z= x+ y+ k so the gradient is [itex]\nabla z= \vec{i}+ \vec{j}[/itex] which has no z component just as before. But if you are thinking of this as a level surface of the function f(x,y,z)= x+ y+ z, then [itex]\nabla f= \vec{i}+ \vec{j}+ \vec{k}[/itex].
You are thinking there is a difference between the two because you changed your interpretation of the function. In the first you were thinking of z= x+ y with z a function of the two variables x and y and in the second you were thinking of k= x+ y+ z as a level surface of the function f(x,y,z)= x+ y+ z, of the three variable x, y, and z.
Thanks
No, you are misunderstanding what function we are talking about. You seem to be thinking of f as changing value on a surface. f is a function of three variables, NOT restricted to that surface. A "level surface" (or "level curve" in two dimensions) for function f(x,y,z) is a surface upon which f is constant. The derivative of f in a direction tangent to a level surface would have to be 0, not a maximum. Since the derivative of f in a direction pf unit vector v⃗ tangent to the level surface is ∇f⋅v⃗ =0, and v⃗ is not 0, it follows that ∇f is perpendicular to v⃗ . Since it is perpendicular to every vector tangent to the surface, it is perpendicular to the surface.
Ok, I understand that much now.
The gradient of the first is ∇z=∇f=i⃗ +j⃗ which has "no z-component" because you really talking about a function of x and y only. If you are thinking of z= x+ y as a level surface of f(x,y,z)= x+ y- z, then ∇f=i⃗ +j⃗ −k⃗ which certainly does have a z compoent.
I was talking about the gradient vector of, f(x,y,z)= x+ y- z. Because this equation still represents a plane so does that mean that shifting the plane in the direction of the gradient will yield the largest increase in f ?
Does this mean that we can rewrite f(x,y,z)= x+ y+ z as:
K = x + y + z + q where say, q = f(x, y, z) and K = some arbitrary constant?
Well, no,it would be x+ y+ z- q= 0.
Related to Why is the gradient vector normal to the level surface?
1. Why is the gradient vector normal to the level surface?
The gradient vector is normal to the level surface because it represents the direction of steepest increase in a scalar field. Since the level surface represents points with the same value of the scalar field, the gradient vector must be perpendicular to it in order to point in the direction of maximum change.
2. How is the gradient vector calculated?
The gradient vector is calculated by taking the partial derivatives of the scalar field with respect to each variable and arranging them into a vector. For example, in a two-dimensional space with variables x and y, the gradient vector would be [∂f/∂x, ∂f/∂y].
3. Can the gradient vector be zero?
Yes, the gradient vector can be zero. This occurs when the scalar field has a constant value and there is no change in any direction. In this case, the level surface is a flat plane and the gradient vector is perpendicular to it.
4. How does the gradient vector relate to the directional derivative?
The gradient vector is directly related to the directional derivative. The directional derivative is the dot product of the gradient vector and a unit vector in the desired direction. This gives the rate of change of the scalar field in that direction.
5. Why is the gradient vector important in vector calculus?
The gradient vector is important in vector calculus because it allows us to determine the rate of change of a scalar field in any direction. It also helps us find the maximum and minimum values of a scalar field, as these occur in the direction of the gradient vector. Additionally, the gradient vector is used in many applications, such as optimization problems and physical simulations.
  • Calculus
  • Calculus
  • Differential Equations
