Why is the ideal gas law a good approximation for stars?
In summary, the conversation discusses the validity of the ideal gas equation in different situations, such as in stars and in chemical engineering. It is mentioned that the approximation breaks down in high densities and non-elastic collisions. Other factors such as gravity, expansion of the universe, and dark matter are also brought up. The conversation concludes by discussing the accuracy and applicability of the ideal gas law in different fields.
jimmy_jollop
Any ideas appreciated!
Astronomy news on Phys.org
It's not.
It IS, that is, at least in a large fraction of the volume of many stars. And why would it not be? Only in very high densities for example the approximation breaks down...
Then please explain to me the gravity, expansion of the universe and dark matter terms in the ideal gas equation.
The approximation also breaks down when collisions become non elastic for example exciting ionising and fusing?
@chemisttree: this really is a question that does not make much sense: the ideal gas equation is an equation of state, relating pressure, density and temperature. Gravity is the attractive force between masses, or if you like the curvature of space-time due to the presence of mass/energy, and the expansion of the universe is just one of the solutions to einsteins field equations which happens to describe the evolution of our universe at large scales. The three entities you name can work together to build galaxies and so on, but one cannot be described in terms of the other.
@Dadface: you're right, it breaks down for non-elastic collisions, or actually in any case where interparticle forces cannot be neglected. But, for example in stars, fusion is going on, but at such a low rate, that even the interior of a star is relatively well approximated by an ideal gas.
Please describe the density term in the ideal gas equation.
Sorry, I misunderstood your response as being applicable to the "volume of many stars" instead of the volume of gas in the outer atmosphere of a star. Thus my confusion regarding gravity, dark matter and expansion.
You cannot be more wrong than this. Tell me more about ion-ion particle interactions in the ideal gas law... both repulsive and attractive. How about radiation pressure?
There are in fect several ways of being more wrong. For example by claiming that an ideal gas is generally a bad approximation of the matter inside stars.
There's radiation pressure (dominant only in massive stars) and ther'es degeneracy, most important for collapsed stars. Everything else at high density and temperature should be well described by an ideal gas.
Hmm, but the ideal gas law is valid that the low pressure-temperature limit.
That said, perhaps the disagreement here is on what constitutes a 'good' approximation.
It's not a good enough approximation for chemical engineering, say. But astrophysics on the other hand is dealing with much larger objects with much lower requirements for accuracy.
Not necessarily for a plasma, with strong magnetic fields around. AFAIK the ideal gas approximation works better inside the star than in the low density regions.
Related to Why is the ideal gas law a good approximation for stars?
1. Why is the ideal gas law used to model stars?
The ideal gas law is used to model stars because it is a simple and convenient way to describe the behavior of gases under a wide range of conditions. Stars are composed of highly ionized gases that are constantly undergoing fusion reactions, and the ideal gas law provides a good approximation of their behavior.
2. What factors make the ideal gas law a good approximation for stars?
The ideal gas law is a good approximation for stars because it takes into account the three main factors that affect the behavior of gases: temperature, pressure, and volume. These factors play a crucial role in determining the physical properties of stars and can be accurately described by the ideal gas law.
3. What are the limitations of using the ideal gas law to model stars?
While the ideal gas law is a good approximation for stars, it does have some limitations. For example, it assumes that the particles in the gas are point masses with no volume, which is not entirely true for stars. It also does not take into account the effects of gravity and radiation pressure, which can significantly impact the behavior of gases in stars.
4. How do scientists account for the deviations from the ideal gas law in stars?
To account for the deviations from the ideal gas law in stars, scientists use more complex models and equations that take into account factors such as gravity, radiation pressure, and the finite size of gas particles. These models are constantly refined and improved as our understanding of stars and their behavior continues to evolve.
5. Can the ideal gas law be used to model all types of stars?
The ideal gas law can be used to model the behavior of many types of stars, but it may not be accurate for all of them. For example, stars with extremely high densities or temperatures may require more complex equations to accurately describe their behavior. Additionally, stars that are undergoing extreme events such as supernovae may also deviate significantly from the ideal gas law.
