Why is the kinetic energy equation multiplied by ½?
In summary: No, the form 1/2 c x2 often pops up, if a constant was integrated twice.The factor of one-half is a convention.
rajen0201
42
How did you find PF?: We can derive the equation 1/2mV2. But what is the fundamental reason behind mV2(total energy) is divided by half?
I find only derivative solutions to this question. But still unsatisfied.
What kind of answer would satisfy you?
Likes russ_watters and etotheipi
You will need to be much more specific. Which specific derivations have you seen and why are you still unsatisfied with them? Since you are already aware of a derivation, this is less a question on the validity of the formula and more a question about what would satisfy you. We need more information to answer that.
Likes russ_watters
In a sense, constant terms out the front of an equation aren't fundamental at all, and are dependent on your choice of system of units. I might define a new unit for energy, the schmoule (##\text{Sc}##), such that ##1\, \text{J} \equiv 2\, \text{Sc}##. If I choose to still measure mass in kilograms and velocity in metres per second, I realize that now my formula has to look like ##T = mv^2##.
Edit
I have subsequently realized that this is not at totally accurate picture. We can at best recast the equation into the form $$T = \text{Sc}\text{J}^{-1} mv^2$$ where the factor ##\text{Sc}\text{J}^{-1}## equals one half. It was thus incorrect of me to omit the leading units.
The formula is always ##T = \frac{1}{2}mv^2##, following by definition from consideration of the work-energy theorem, and this is independent of the chosen system of units.
  • Skeptical
Likes robphy, Delta2, Klystron and 2 others
This is a bit vague. You said that you know the derivation of the kinetic energy equation, but you now want to know the "fundamental reason" for it? What exactly do you mean by "fundamental reason"? A logical, mathematical derivation often trumps intuition and human reasoning. That is as "fundamental" as it gets.
So what exactly are you looking for here?
If you have a problem knowing the fundamental reason for the KE equation, do you also have a a problem understanding the fundamental reason for the kinematical equations derived from Newton's laws? After all, they all came from the same place. Is the "1/2" causing major headache in understanding here?
Zz.
Likes Lord Jestocost
This may be incorrect, but it is the way in which I understand the reason of your question:
It is half the area of the rectangle formed in the velocity versus time graph.
For the body represented in the graph to gain momentum (its velocity to steadily increase), a steady force is applied onto it; therefore, we have a line of constant slope that divides a rectangle exactly in half.
More about the same here:
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
Please, see:
:cool:
Are you under the impression that the "total energy" is ## = mv^2## ? Where did you get that idea? It isn't correct.
More generally, the form 1/2 c x2 often pops up, if a constant was integrated twice.
Likes Lnewqban
The factor [itex]\frac{1}{2}[/itex] in the kinetic energy expression, which is a dimensionless number, is independent of any unit system. It comes from [itex]T = m \int_{0}^{v} v dv[/itex], or more accurately from the classical limit of the relativistic dispersion relation [tex]\mathcal{E} - m = m \left( \sqrt{1 + (\frac{p}{m})^{2}} - 1 \right) \approx \frac{1}{2} \frac{p^{2}}{m} .[/tex] Notice that the (1/2) poped up even though I used a units system in which the speed of light is one [itex]c = 1[/itex].
Likes etotheipi
I'll assume you're right about this, I'm just not too sure why. If I make up a weird system of units identical to the SI units except that the unit of mass is now ##u_M = n\text{kg}##, won't the formula for kinetic energy change? It seems to me that it would become ##T = \frac{n}{2}mv^2##, if ##T## is still measured in joules.
It does not matter which unit you measure the energy with. Joule, eV or even Kg are irrelevant units. You can have an object with 1000 “unit of mass” (any unit of mass), but the half will still be in the expression for [itex]T[/itex]. In orher words: the half is not there because we measure the energy by Joules.
Likes etotheipi and hutchphd
That makes sense. I must be overlooking something whilst messing around with these units. I got the idea because it's possible for certain formulae to change form in different systems of units (e.g. EM in Gaussian vs SI units), however that's perhaps distinct to this. I'll have another look at this in the morning!
etotheipi said:
. If I make up a weird system of units identical to the SI units except that the unit of mass is now uM=nkgu_M = n\text{kg}, won't the formula for kinetic energy change?
Sure. So will the expression for momentum, and force, and probably a zillion others. This turns a set of simple equations into a horrible mess. One that still has relative factors of 1/2 floating around.
Likes etotheipi
First, there are no defintions for energy, only difference in energy is defined:
\Delta E =F\Delta x
This can easily be transformed to:
$$\begin{split}
\Delta E &=F\Delta x \\
&=m\frac{\Delta v}{\Delta t}\Delta x \\
&=m\frac{\Delta x}{\Delta t}\Delta v \\
&= m\bar{v}\Delta v
\end{split}
It is important to note that ##\frac{\Delta x}{\Delta t}## is the average velocity between the two states. Therefore, the difference in energy between state ##1## and state ##2##:
$$\begin{split}
E_2 - E_1 &= m\bar{v}\Delta v \\
&= m\frac{v_1+ v_2}{2}(v_2 - v_1) \\
&= m\frac{v_2^2- v_1^2}{2} \\
&= \frac{1}{2}mv_2^2 - \frac{1}{2}mv_1^2
\end{split}
We should stop here, but one could extrapolate this to:
\begin{split}
E_1 &= \frac{1}{2}mv_1^2 \\
E_2 &= \frac{1}{2}mv_2^2
\end{split}
Or in the general case:
$$E = \frac{1}{2}mv^2$$
Thus the ##\frac{1}{2}## comes from the halving done when calculating the average velocity.
Likes Stephen Tashi, Adesh and Lnewqban
This was what I thought. The equation for work might just change to e.g. ##W = 2Fd## and then when you integrate up to get ##T## you lose that factor of ##\frac{1}{2}##. GPE becomes ##2mgh##, everything scales accordingly. The relative factors of ##\frac{1}{2}## would still be there, but not in the defining equation for ##T##. It was my understanding that a change in the system of units can result in a change in the dimensionless coefficients in physical laws.
However this appears to disagree with what @samalkhaiat suggested. And if in doubt it's probably me that's in the wrong :wink:, so I'd need to have another look when less tired.
That is the biggest mistake you can do. Nothing more wrong than saying [itex]1 = 2[/itex]. You can always play with dimensionfull quantities (following well defined rules), but you cannot do the same with dimensionless quantities which are just real numbers.
Likes etotheipi
Perhaps this is it; the formula in my example only changes because we are still measuring energy in joules, and joules is derived from the kilogram. So I'm cheating. If I were meticulous in redefining all quantities in terms of my new base quantities, and the new unit of energy were 1 new mass unit times 1 square metre times second to the negative two, then I think you would retain the factor of ##\frac{1}{2}##. This is in agreement with your argument.
We see the same thing with LI^2 / 2 and CV^2 / 2.
I thought it was because half the energy of the prime mover is dissipated as heat during the energy transfer.
Yes, for example, you can never get rid of the 2 in the [itex]1/r^{2}[/itex] law.
Likes etotheipi
For example, take a ball and throw it radially upward. you are pushing the Earth same time as per Newton's third law. So, total energy(E=MC^2 chemical energy) used by man throwing ball must be divide in two equal and opposite part. Other example is when we push a empty boat from other boat, both boat will away with respect to their mass. Is this logic is correct?
  • Sad
Likes etotheipi
\Delta E =F\Delta x
$$\begin{split}
&= m\bar{v}\Delta v
\end{split}
$$\begin{split}
\end{split}
\begin{split}
\end{split}
Is it not possible that E is itself 1/2E ? For example, take a ball and throw it radially upward. you are pushing the Earth same time as per Newton's third law. So, total energy(E=MC^2 chemical energy) used by man throwing ball must be divide in two equal and opposite part. Other example is when we push a empty boat from other boat, both boat will away with respect to their mass. Is this logic is correct?
Momentum is equal and opposite, but the ball has almost all the energy. You can see this from:
$$mv = MV \ \Rightarrow \ V = \frac m M v$$
Hence:
$$KE_{Earth} = \frac 1 2 MV^2 = \frac 1 2 M (\frac m M v)^2 = (\frac m M) \frac 1 2 mv^2 = (\frac m M) KE_{ball}$$
And the Earth has almost no KE compared to the ball, because of its huge mass ##M##.
Likes SamRoss, Delta2, jack action and 1 other person
No. You can't have "equal and opposite" parts of energy, and if you could the total would be zero. The ball and the Earth will have equal and opposite momenta, but this will not lead to equal shares of the kinetic energy. If the ball has mass ##m## and the Earth has mass ##m_E## then the ball gets ##m_E/m## times more kinetic energy than the Earth in their center of mass frame.
Likes Lnewqban, jack action and etotheipi
This is quite confused. ##mc^2## is not chemical energy, and it doesn't come into play in classical mechanics. And furthermore ##mc^2## is not the same as double ##\frac{1}{2}mv^2##.
Newton's third law pertains to forces. It generally tells you nothing about how energy is divided up (except in a few specific cases). In a system of two interacting bodies, one could be held at rest and the other moved (in which case only work is done on the latter), or they could both move, etc.
Likes Delta2
Actually, there will be a tiny reduction in the mass of the reagents if a chemical reaction releases energy. It's immeasurably tiny (a few kJ divided by ##c^2## is almost nothing), and I agree that it isn't relevant at all to this discussion.
Likes etotheipi
Sure, I meant it in the sense rest energy is not the same thing as chemical energy, although the latter might well contribute to the former 😁
Likes Ibix
This is not correct. Momentum is conserved so that the Earth'smomentum change is the same as minus the ball's Momentum change. But the Energy is not 'shared' in any way. For a large Earth, the Energy transferred is Zero. Kinetic Energy is proportional to v2, remember so the 'share' is the square of the ratio of speeds.
Then how Newton's third law satisfied here? take another example, A man seating in a boat without paddles. but there is another boat near him, So, he pushes it. So, it allows him to move in the opposite direction. how much energy did he spend? Here man energy is ultimately chemical energy that converts in mechaniical.
  • #31
The ultimate source of energy is electromagnetic energy.
ALso Ibix said: "This will not lead to equal shares of the kinetic energy" Is it not violating Newton's third law? The multiplication of Earth's MeVe^2 must equal to mv^2 of the ball to satisfy Newton's third law.
example:1 of an astronomer away from his space station with no string/rope attached. to get back into the station, he throws items such as a hammer in opposite direction so, as per Newton's third law, he finally servives. What amount of energy he spent?
example:2 A man seating in a boat without paddles. but there is another boat near him, So, he pushes it. So, it allows him to move in the opposite direction. how much energy did he spend? Here man energy is ultimately chemical energy that converts in mechaniical.
  • Skeptical
Likes weirdoguy
  • #32
Requiring the conservation of momentum satisfies it. Newton's third law does not require that equal energy be supplied to both bodies, just that equal forces be applied.
Likes Dale
  • #33
No. Newton's third law says that the applied forces, and hence the momentum changes, must be equal and opposite for the two bodies. This does not mean that the energy changes must be equal.
Likes etotheipi
  • #34
Like @Ibix said, Newton's third law required only the forces to be equal. Energy Power is force times velocity and velocities can be different. So even if the energy power is conserved, it may be split in any proportion between the two.
The best example would a ball bouncing back on a wall. No matter what, the wall is fixed, thus its velocity is zero before and after the hit. Any force felt by the wall, multiplied by zero velocity gives zero energy power. Therefore whatever energy the ball comes with, it goes back with it (only in a different direction).
Edit: I incorrectly used the definition of power for energy. But the principle of conservation of energy extends to power, so I think my point is still valid. Or one could change the term 'velocity' for 'displacement' and the point would still be valid.
Likes Dale and etotheipi
  • #35
Force is the rate at which momentum changes with respect to time (F = dp/dt). Note that if p = mv and m is constant, then F = dp/dt = m*dv/dt = ma so, that is force. So, conservation of momentum also satisfy Newton's third law.
  • Mechanics
  • Mechanics
