Why is the Maclaurin series of $e^u$ simply $\sum\frac{u^n}{n!}$?
In summary: There's no restriction on the Maclaurin series for $e^{x}$ because it can be derived using the fact that the derivative of $e^{x}$ is $e^{x}$. In summary, we discussed the Maclaurin series of $e^{u}$ where u is some function of x, which is simply $\sum\frac{u^{n}}{n!}$. However, this series does not apply to all functions of x, as $\sum\frac{u^{n}}{n!}$ is not a power series unless u is a power of x. We also looked at the Maclaurin series for $e^{lnx}$, which is just "x". While it may
poissonspot
40
It just occurred to me now that I never asked why the Maclaurin series of $e^u$, u being some function of x, is simply $\sum\frac{u^n}{n!}$. I should say I understand why the Maclaurin series of $e^x$ is $\sum\frac{x^n}{n!}$, due to the derivative of the exponential function being itself, but why this series expansion should apply to functions of x is less clear. I've played with this expansion a little and see what might be an inductive argument, but once again its not clear. Any suggestions?
Well, it isn't! Unless u is just a power of x, $\sum\frac{u^n}{n!}$ is not even a power series.
What is the Maclaurin series for $e^{ln x}$? It isn't $\sum\frac{[ln(x)]^n}{n!}$. That isn't the Maclaurin series of anything- as I said, it is not even a power series.
Because $e^x= \sum \frac{x^n}{n!}$ simple substitution gives $e^{u(x)}= \sum \frac{u^n}{n!}$ but, once again, that is not a "Maclaurin series" nor even a power series.
Is it fair to say the two are equivalent, that is $\sum\frac{[ln(x)]^n}{n!}$ and the Maclaurin series for $e^{ln x}$? If they yield the same values for all x, are they different for all said purposes? I do agree that that is not in the form of a Maclaurin series. I guess this is all an unneeded relationship when it comes down to it. I thought that the series derived for e^x had some restriction due to the fact I had derived it using the fact that the derivative of e^x is e^x. But there is nothing but a substitution at hand. It almost seemed like a leap to just substitute, but why not?
I will agree with your use of the word "equivalent". By the way, the Maclaurin series for $e^{ln x}$ is just "x".
That's understood.
FAQ: Why is the Maclaurin series of $e^u$ simply $\sum\frac{u^n}{n!}$?
What is "Remedial Power Series Work"?
Remedial Power Series Work is a method used in mathematics to approximate a function using a power series. It involves breaking down a complicated function into simpler parts that can be represented by a power series and then combining them to get an approximation of the original function.
How is "Remedial Power Series Work" different from other methods of approximation?
Unlike other methods such as interpolation or regression, "Remedial Power Series Work" allows for a more accurate approximation of a function by breaking it down into simpler parts. It also allows for greater flexibility in choosing the number of terms to include in the series, which can lead to a more precise approximation.
What are the applications of "Remedial Power Series Work" in real-world problems?
"Remedial Power Series Work" is commonly used in fields such as physics, engineering, and economics to approximate complicated functions that cannot be easily solved using traditional methods. It is also used in computer science for data compression and signal processing.
What are the limitations of "Remedial Power Series Work"?
One limitation of "Remedial Power Series Work" is that it can only approximate functions that can be represented by a power series. It also requires a significant amount of computational power and can be time-consuming for functions with a large number of terms.
How can I improve the accuracy of my "Remedial Power Series Work" approximation?
To improve the accuracy of your approximation, you can increase the number of terms included in the power series. However, this can also lead to longer computation times. Another way is to use more advanced techniques such as Taylor series or Fourier series, which can provide a more precise approximation for certain types of functions.
