Why is the most probable energy different from the speed?
In summary: E})$$In summary, the most probable energy level according to the Maxwell-Boltzmann distribution is not equal to the most probable speed squared multiplied by ##\frac{1}{2}m##. The most probable speed has a different value.
JohnnyGui
796
51
It appears that the most probable energy level according to the Maxwell-Boltzmann distribution is not equal to the most probable speed squared multiplied by ##\frac{1}{2}m##. The most probable speed has a different value.
$$E_{max} = \frac{k_BT}{2}$$
$$v_{max} = \sqrt{\frac{2k_BT}{m}}$$
I am trying to understand this physically rather than mathematically, but I have a hard time comprehending this.
An energy level with the highest probability means it has the most particles out of all other energy levels, therefore that same largest number of particles has the speed corresponding to that energy level.
If I’m imagining energy levels as containers and I draw a specific number of particles in each container, there is no way I can distribute the particles in a way to have the most probable speed in an energy container different from the most probable energy. Energy is tied to speed.
The only way I can think of how this can be possible is if in the continuous approach a certain energy level covers a range of different speed values. If that’s the case then I’d deduce further that the reason is because an infinitesimally small ##dE## covers a larger range of speed values dan an infinitesimally small speed ##dv## does.
Is this reasoning correct?
Where are you getting your formulas for ##E_{max}## and ##v_{max}## from?
You take averages, and thus [EDIT corrected in view of #5]
$$\langle |\vec{v}| \rangle=\left \langle \sqrt{\vec{v}^2} \right \rangle \neq \sqrt{\langle \vec{v}^2 \rangle}.$$
Likes Tazerfish, etotheipi, Ibix and 1 other person
Note that vanhees' comment is not only applicable to this one problem. This happens all the time with distributions.
Likes vanhees71
$$\langle |\vec{v}| \rangle=\left \langle \sqrt{\vec{v}}^2 \right \rangle \neq \sqrt{\langle \vec{v}^2 \rangle}.$$
Minor quibble - shouldn't the middle expression have the square under the square root?
Likes vanhees71
Of course there is. Try it. Here's a simple Python program with a triangular distribution. <v> is different from sqrt(<v^2>). The output is:
Mean velocity = 6.3313
Mean energy = 45.1507
Velocity of mean energy = 6.7194
Python:
import numpy as np
left = 0.0
mode = 9.0
right = 10.0
nSamples = 1000000
velocities = []
energies = []
for i in range(nSamples):
    v =  np.random.triangular(left, mode, right)
    velocities.append(v)
    energies.append(v * v)
vbar = np.mean(velocities)
ebar = np.mean(energies)
print("Mean velocity = %.4f"%vbar)
print("Mean energy = %.4f"%ebar)
print("Velocity of mean energy = %.4f"%(np.sqrt(ebar)))
Likes vanhees71
Major quibble "most probable" is not the same as "average".
Likes Tazerfish and JohnnyGui
PeterDonis said:
Where are you getting your formulas for EmaxEmax and vmaxvmax from?
They can be found here and http://people.physics.tamu.edu/syeager/teaching/222/hw4solution.pdf. For the 2nd link, please search for the terms "most probable".
@vanhees71 @Ibix @Vanadium 50 @phyzguy I'm aware that the average speed is not the same as the root-mean-square speed. I don't see how this has a link with the most probable speed. Please see @PeroK 's post #8 above.
The formula for those averages also differ from the most probable speed as shown here.
This is exactly what I thought.
The "most probable speed", i.e., the ##v##, where the probability distribution ##f(v)## has a maximum is in general again different from the other two considered "average speeds".
Likes Tazerfish
@vanhees71 @Ibix @Vanadium 50 I'm aware that the average speed is not the same as the root-mean-square speed. I don't see how this has a link with the most probable speed.
Do all particles have the same mass?
Likes JohnnyGui
That's what I'm saying. My question in that regard is how it can be physically explained that the most probable energy does not correspond to the most probable speed that belongs to that energy.
@PeroK Yes
A distribution is a distribution, i.e., it transforms under changes of the independent variable. Let ##f(v)## be the velocity distribution. For the Maxwell distribution, it's ##f(v) = N v^2 \exp[-m v^2/(2 kT)]##.
Then you have ##E=m v^2/2m##. From this you get
$$\tilde{f}(E) \mathrm{d} E =f(v) \mathrm{d} v.$$
Now ##v=\sqrt{2mE}## and thus ##\mathrm{d} v=\mathrm{d} E \sqrt{m/(2E)}##, leading to
$$\tilde{f}(E) \mathrm{d} E = f(v) \sqrt{m/(2 E)} \mathrm{d} E \; \Rightarrow \; \tilde{f}(E)=\sqrt{\frac{m}{2 E}} f(\sqrt{2 m E}).$$
I understand that the formulas are different mathematically, but my question is how this can be imagined physically, for example using my scenario to distribute the particles in such a way to fulfill that criteria.
If that's not possible then how about the following reasoning?
JohnnyGui said:
The only way I can think of how this can be possible is if in the continuous approach a certain energy level covers a range of different speed values. If that’s the case then I’d deduce further that the reason is because an infinitesimally small dEdEdE covers a larger range of speed values dan an infinitesimally small speed dvdvdv does.
Here's a slightly artificial example:
Consider a large finite set of particles, clustered round ##v = 0## and ##v = v_0##, with more around ##v_0##. If you square these numbers, the cluster round ##0## stays close to zero, but the cluster around ##v_0## spreads out more. And the density around ##v^2 = 0## may be greater than the density around ##v^2 = v_0^2##.
To use a bit of simple maths:
##v = \Delta v \approx 0 \ \Rightarrow \ v^2 = (\Delta v)^2 \approx 0##
But:
##v = v_0 + \Delta v \ \Rightarrow \ v^2 = v_0^2 + 2v_0 \Delta v##
Which is spread much further away from ##v_0^2##.
Likes vanhees71
But:
Ah, so in the context of my reasoning. A ##dE## starting from low energy values (thus low speeds) would cover more particles of the same speed and a ##dE## starting from higher energy (higher speeds) covers only a portion of the particles with the same speed because they are more spread out when squared?
Likes vanhees71 and PeroK
@PeroK I noticed an inner clash afterwards, because I also know that ##dE = mv \cdot dv##. Doesn't this mean that ##dE## get wider at higher speeds and thus covers the increasing spread of the speed anyway?
Isn't that just another way of saying what's already been said?
I don't think so because I said in post #16 that ##dE## covers only a portion of higher speeds because of the spread, but if ##dE## gets wider at higher speeds, it would compensate for that spread and thus cover all of them anyway. I.e. the "density" within ##dE## stays the same.
The fact that these look different to you in vague ordinary language does not mean you have actually proposed two different possible answers to your question. The mathematical fact that ##dE = m v dv## is the answer to your question. If you think that means "gets wider at higher speeds", and you think that's something different from "covers only a portion of higher speeds", then what do you think "covers only a portion of higher speeds" means mathematically that makes it different?
How an answer "looks" is also influenced by how one understands it. I'm not solely basing the difference on the "looks" of my answers, but on my own understandings when writing them.
As I see them, there is a difference since one answer says "covers a portion" and the other says "covers all"
PeterDonis said:
The mathematical fact that dE=mvdvdE=mvdvdE = m v dv is the answer to your question. If you think that means "gets wider at higher speeds", and you think that's something different from "covers only a portion of higher speeds", then what do you think "covers only a portion of higher speeds" means mathematically that makes it different?
"covers only a portion" in the sense that the value ##dE## stays as a constant and does not get wider with increasing speed.
The only one who used the words "covers a portion" was you. What mathematical fact are you basing that on?
So what mathematical fact justifies this description? Note that nothing @PeroK said in any of his posts implies this.
The fact that he, as well as another user, liked my post #16 containing that very description of ##dE## as a statement I asked about would make me assume that my understanding about ##dE## was correct. Hence me asking about it after.
Perhaps I based my description on his mathematical fact because I understood it in another way than what he meant?
When reading him talking about the density of speed squared values changes around different ##v##'s, I concluded that the reason the probability gets influenced by that is because a ##dE## would eventually not cover all the speed squared values when they're spread more out, thus ignoring a number of particles that had speeds very close to a certain (high) ##v##.
I discarded this thought when I noticed that ##dE## gets wider with increasing speeds, thus thinking not ignoring a number of particles that are close to a certain (high) ##v## and and taking them all into account for the probability. Which brought me back to the initial OP question.
...the wrong thing. What he meant was simply that ##dE = m v dv##.
This is a good example of why it's better to use math, not ordinary language, when talking about physics.
Likes vanhees71
Because they thought you were just trying to say ##dE = m v dv## in different words. If they had known you were describing something different and inconsistent with ##dE = m v dv##, they would not have liked your post.
Again, an example of why it's better to just use math instead of vague ordinary language.
You asked about what I based it on and I took the time to explain to you how I understood it so you could perhaps pinpoint how I should understand it with ##dE = mvdv##.
Merely substituting my whole explanation with "...the wrong thing" and that he meant something that I already mentioned noticing it in the meantime won't help me understand this any better.
I would not have known that. I would've expected mentioning "##dE## covering a portion" would be inconsistent with that formula.
Do you see how ##dE = m v dv## explains why the most probable energy is not the same as the most probable velocity?
It should be even clearer if we replace the phrase "most probable" with "greatest probability density".
Likes JohnnyGui and Ibix
And if that doesn't help you, @JohnnyGui, draw the distribution twice as a function of ##v##. In one case, slice it up into bands of width ##\Delta v##. In the other, slice it up into bands of width ##\Delta E## - note that you'll have to determine the velocities corresponding to ##n\Delta E##. Then use the trapezium rule to approximate the area under the curve in each bin in both cases. Is the highest value in the same place?
Then imagine repeating the exercise with smaller and smaller ##\Delta v## and ##\Delta E## - eventually in the limit as ##\Delta\rightarrow d##. Do you expect the answers to ever be the same?
Likes JohnnyGui
@Ibix & @PeroK I think using your info's helped me a bit by explaining it as follows:
For a certain ##E_0## and a corresponding ##v_0##, the following must be valid:$$f(E_0)\cdot dE = f(v_0) \cdot dv$$
For ##f(E)##, the maximum number of particles lies within the range ##\frac{k_BT}{2} \geq \frac{k_BT}{2} + dE##.
For ##f(v)##, the maximum number of particles lies within the range ##\sqrt{\frac{2k_BT}{m}} \geq \sqrt{\frac{2k_BT}{m}}+dv## which, in energy terms, is equal to a range of ##k_BT \geq k_BT + \frac{dE}{\sqrt{2mE}}##
The maximum number of particles differ because for ##f(E)## a range width of ##dE## has been used while for ##f(v)## a range width of ##\frac{dE}{\sqrt{2mE}}## has been used.
Does this make sense?
Likes Philip Koeck
  • #31
The complete solution is in #13. I still don't know, what else you need.
  • #32
Never mind, I figured it out, thanks. My calcuations in post #30 are wrong, I didn't pay attention when doing them. I was overlooking the fact that the relation between ##dE## and ##dv## is a function of ##v## while the probability itself is also a function of ##v##. If the relation between ##dE## and ##dv## were a constant, then then ##E_{max}## would correspond to ##v_{max}## .
Is there actually a mathematical way to explain why the maximum probability density in terms of energy ##E_{max}## is exactly half the energy that corresponds to ##v_{max}##?
Likes Philip Koeck
  • #33
It doesn't look like it, since you come right back with the same question:
JohnnyGui said:
Is there a mathematical way to explain why the maximum probability density in terms of energy ##E_{max}## is exactly half the energy that corresponds to ##v_{max}##?
The math has already been discussed quite sufficiently in this thread. I think the discussion has run its course.
Thread closed.
Likes vanhees71
Related to Why is the most probable energy different from the speed?
1. Why is the most probable energy different from the speed?
The most probable energy and speed are two different concepts in physics. The most probable energy refers to the energy state that is most likely to be occupied by a particle in a given system, while speed refers to the rate at which an object is moving. These two quantities are not directly related to each other and are governed by different principles in physics.
2. How is the most probable energy determined?
The most probable energy is determined by the Boltzmann distribution, which describes the probability of a particle occupying a certain energy state in a system at thermal equilibrium. This distribution takes into account factors such as temperature, energy levels, and degeneracy of states to calculate the most probable energy for a given system.
3. Can the most probable energy and speed ever be the same?
No, the most probable energy and speed cannot be the same as they represent different physical quantities. However, in certain cases, such as in an ideal gas, the average kinetic energy of particles can be directly related to their speed through the kinetic theory of gases.
4. How does the most probable energy affect the behavior of particles?
The most probable energy plays a crucial role in determining the behavior of particles in a system. It affects the rate of chemical reactions, the distribution of particles in a system, and the overall stability of a system. In systems at thermal equilibrium, particles tend to occupy the most probable energy state, leading to a more stable and organized system.
5. Are there any real-world applications of understanding the difference between the most probable energy and speed?
Yes, understanding the difference between the most probable energy and speed is crucial in various fields such as thermodynamics, statistical mechanics, and chemical kinetics. It allows scientists to predict and control the behavior of particles in a system, leading to advancements in fields such as material science, energy production, and drug development.
  • Electromagnetism
