Why is the right side of the equation incorrect in 3^(2x) = 18x?
  • MHB
  • Thread starter mathdad
In summary: Thank you.In summary, the equation given cannot be solved algebraically. A numeric root-finding technique could be used though.
mathdad
1,283
Can this be a mistake?
Find x.
3^(2x) = 18x
Shouldn't the right side be 18^(x)?
If so, I can then take the log on both sides.
Mathematics news on Phys.org
Yes, the equation as given cannot be solved algebraically. A numeric root-finding technique could be used though. If we take the equation to be:
\(\displaystyle 3^{2x}=18^x\)
Then we could write this as:
\(\displaystyle 3^{2x}-2^x\cdot3^{2x}=0\)
Divide through by $3^{2x}$ since it cannot be zero for real values of $x$:
\(\displaystyle 1-2^x=0\implies x=0\)
You could also use logs, but I just wanted to present an alternate method. :D
Is this not an exponential equation?
Yes, but it's not always necessary to use logs to solve them. If we can arrange such an equation in the form:
\(\displaystyle a^b=a^c\) where $a$ is neither 0 nor 1, then we know:
\(\displaystyle b=c\)
In this problem, we found:
\(\displaystyle 2^x=1=2^0\)
Therefore we conclude:
\(\displaystyle x=0\)
3^2x = 18^x
3^2x - 2^x • 3^2x = 0
You said "Divide through by 3^2x..."
We are left with 1 - 2^x = 0.
1 = 2^x
ln(1) = ln[2^(x)]
0 = xln2
0/ln2 = x
0 = x
Once you reach the point:
\(\displaystyle 2^x=1\)
Instead of taking the natural log of both sides (which is completely valid), you could also translate directly from exponential to logarithmic notation, and write:
\(\displaystyle x=\log_2(1)=0\) :D
We can also say, in terms of 2^x = 1, that anything to the zero power is 1.
So, 2^x = 1 means (number)^0 = 1.
We say x = 0.
We say x = 0.
Yes, any non-zero value raised to the power of zero is 1, as evidenced by using a rule for exponents:
\(\displaystyle 1=\frac{a^b}{a^b}=a^{b-b}=a^0\)
Very cool.
FAQ: Why is the right side of the equation incorrect in 3^(2x) = 18x?
What is the equation "Find x: 3^(2x) = 18x" trying to solve?
The equation is trying to solve for the value of x that satisfies the equation 3^(2x) = 18x.
What is the process for solving this equation?
The process for solving this equation involves using logarithms to isolate the x variable on one side of the equation and simplifying the other side. Then, using algebraic techniques to solve for x.
What are the possible solutions for this equation?
The equation may have multiple solutions, but the most common solution is x = 2.
What are some alternative ways to write this equation?
The equation can also be written as 3^(2x) - 18x = 0 or as log3(18x) = 2x.
What are some real-life applications of this equation?
This equation can be used to solve for the growth rate in compound interest problems or to model exponential growth in biological and environmental systems.
