Why is the speed of light the same for all observers?
In summary, the speed of light is the same for all observers, regardless of their motion relative to the source of light. This is because special relativity predicts that the speed of light is the same for all observers. To measure the speed of light, you would have to start a timer when the light reached you, then put a mirror in front of you some measured distance away and stop the timer when the reflection got back to you. The speed of light would be the double distance divided by the reading on the timer.
  • #36
phyti said:
ghwellsjr said:
The Coordinate Length is the Proper Length divided by gamma and the Coordinate Time is the Proper Time multiplied by gamma.
Yes in the U frame, not in the A frame, which represents all other frames.
If we are talking about inertial observers that pass through the origins of both frames where their clocks are synchronized to zero, then my statement is true in all frames, even in the rest frame of a particular observer. In that case, the speed is zero and gamma is 1 so the Coordinate Length is equal to the Proper Length and the Coordinate Time is equal to the Proper Time. If you think my statement is not true in the A frame (the rest frame of the observer) then what is true?
Also, I have no idea what you mean by the A frame represents all other frames. It sounds like you are giving preference to the rest frame of an observer.
phyti said:
If light speed is measured in the U frame once as c, it won't be any different the next time.
Whenever any inertial observer measures the speed of light from any source (with a single clock, a single ruler, and a single mirror) they don't have to consider any reference frame. They don't have to be aware of any theory such as Special Relativity. So although I agree with your statement, it concerns me that you put stipulations on it. I would just say "if light speed is measured once as c, it won't be any different the next time" or even more simply, "light speed will always be measured as c". Again, since we are talking about a measurement, it has to be a round-trip.
phyti said:
Thus I show from the perspective of A that it is c also regardless of his speed.
I thought that when you say "the perspective of A" you mean the "rest frame of A" in which case his speed is zero so I don't know what you mean by "regardless of his speed". Help me with my confusion.
phyti said:
Overlaying the A view eliminates a 2nd drawing and gives a direct visual comparison.
If by "A view" you mean the "rest frame of A" or the "A frame" then I see no purpose in overlaying it on another frame. Doesn't that discredit all the other frames? Doesn't that promote the preference of a rest frame?
phyti said:
ghwellsjr said:
I don't disagree with any of this but since the OP asked about measuring the value of the speed of light (a round-trip) I didn't bother to mention that the propagation of light is defined to be c (one-way) in any Inertial Reference Frame.
I see the convention as defining equal path lengths since light speed is already declared constant. This should be obvious in Minkowski plots and the MMX, where the question is path length, not light speed. It's also the reason why LENGTH contraction solves the problem.
I am confused. You just said that you believe the path lengths are equal and then you said LENGTH contraction solves the problem.
As I have stated over and over again, in a frame where a moving observer is measuring the speed of light the path length of the light is longer than in his rest frame, not equal and not contracted. I explained it all in great detail in post #26.
  • #37
phyti said:
ghwellsjr;
You stated you didn't understand one of my recent drawings, so here is one of yours to show how easy it is to add the moving observers description of events in the same drawing. The sequence of details (red) is: the arc centered on the origin, the vertical from the detection event to the arc, the horizontal to the time axis, a light path to the initial light path, and a vertical to the x axis. With coordinate axes, calculations are not usually needed, and um is not relevant as long as they match, year:light yr, sec:light sec, and in your method, nanosecond:light ns.
Once you have the coordinates, the construction lines can be erased to eliminate clutter.
Wow, I'm impressed. Did you come up with this construction technique on your own or did you learn about it somewhere?
I can see how a graphical technique could be useful a hundred years ago when there were no computers to draw diagrams or even calculators to help and I will admit that the application I wrote took a very long time to develop but now that I have it, I let the computer do all those pesky calculations and it works for any in-line scenario, not just the simple ones where the observers are inertial and pass through the origins. Can you use your technique for every in-line scenario? Can I give you a more complicated scenario and see how you do it?
However, my diagram that you started with shows everything that the moving observer measures. There's no reason or advantage to add any other lines or to overlay his rest frame. If you count the dots between when he started his stopwatch (at the origin) up to where he detected the reflection, you will see that he measured 12 nanoseconds, just like in his rest frame. Nothing else matters. As I stated in post #26, he is unaware that it took 15 nanoseconds in this frame. He is also unaware that the distance to the mirror is contracted or that the light takes longer to make the round trip.
The OP was asking how Relativity supports the observer's measurement when he is moving and that's what I showed. It seems that you don't want to show it in a frame in which the observer is moving but rather you keep reverting back to the observer's rest frame to assert that the measurement is the same. What is significant in all frames is that all observations and measurements are the same, it's just that the coordinates are different.
  • #38
phyti said:
In the following the A perception is overlaid onto the U perception using the same time axis, and providing a visual comparison.
Overlaying A's rest frame on all the frames in which A is moving implies that those frames do not contain enough information when in fact, every frame that is created through the Lorentz Transformation process contains exactly the same information as any other such frame and it detracts from the importance and significance of the Lorentz Transformation and I think for that reason should be discouraged. Even a traditional Minkowski plot affirms the Lorentz Transformation process but what you are doing seems to bypass the Lorentz Transformation and diminish its importance and significance.
If anyone wants a visual comparison, they can print each one of my diagrams and look at them side by side.
  • #39
A study of geometry and algebra enables you to understand the relations between different forms, such as the hyperbola and its inverse the circle.
I use a CAD system and also let the software do the calculations. Give me a problem to try.
I still feel you have to show from the moving observers frame/perspective that regardless of his speed and his different coordinates, he still measures light speed as c, the same as the rest frame.
I'll respond to your other posts later, but wanted to finish this with the math answer to the original question with the attached doc.
https://www.physicsforums.com/attachments/65136
  • #40
I'll have to wait til after the New Year when I get back to work to read your document. The readers I have produce garbage. After that I'll start a new thread to give you a challenge problem because it is off topic for this thread.
However, what is not off topic is the implication that your graphical approach does something different than what I have done. All your technique does is provide a graphical means to determine the Proper Time interval of the observer's measurement between the two light signals, the one leaving the observer on the way to the mirror and the one reflected back from the mirror. I am also doing that using the Lorentz Transformation. We're just taking the coordinates of the end point (since the starting point is at the origin) and transforming them to the rest frame or we could do it using the Spacetime Interval:
t=15, x=9
Proper Time interval = √(t2-x2) = √(152-92) = √(225-81) = √144 = 12
There's lots of ways to do it. But that only shows how the observer makes the same measurement with his clock no matter what his speed is in any particular frame.
Since he previously measured the distance to the mirror with his ruler as 6 feet, he assumes that the round trip distance the light had to take was 12 feet and since it did it in 12 nanoseconds, he measures the speed of light to be 1 foot per nanosecond, just like in he does in any frame.
When you draw the light path down at the 45-degree angle and intersect with the light path coming up at the 45-degree angle from the origin, you are also assuming that the light path is 12 feet.
So we agree that the transformation process (or any other equivalent process) works in both directions from the rest frame to a frame in which the observer is moving and vice versa, but what I still cannot get you to focus on is that the combined round-trip light path in a frame in which the observer is moving takes longer than it does in the rest frame (although you did draw some pictures in which you show this). I'm still focused on your comment:
phyti said:
The moving frame is a scaled version of the 'rest' frame, therefore
the expressions involving x and t are equivalent (including light speed). This requires x and t to change by the same proportion (γ).
Can't you acknowledge, especially after you made two drawings that show it, that the light has to travel a longer round-trip distance in the frame in which the observer is moving than in his rest frame?
  • #41
I agree with you but that is according to U (the rest frame). A (the moving observer) does not measure this or is aware of it, and the task is to show why, mathematically or geometrically. That's why the overlay and the extra drawing (made from the overlay) as seen from the A perspective. The alternate method just avoids using the x & t transforms.
I also agree, either method shows the same info.
I also encourage you to keep emphasizing the difference between doppler effect and time dilation.
  • #42
This thread has turned into a discussion but where's the OP?
  • #43
Thanks, we are in complete agreement.
