Why is the tension different in two systems with the same downward force?
  • Thread starter Cursed
  • Tags
    Conceptual
In summary, the question is asking why the tension in a rope in system A is not equal to 100 lbs while the tension in a rope in system B is 100 lbs. The answer is that in system A, the tension is not given and therefore cannot be assumed to be 100 lbs, while in system B, the tension is explicitly stated to be 100 lbs. Additionally, the mass being accelerated in system A is larger than in system B, leading to a different tension in the rope. It is important to note that units of force, such as pound force, should be used instead of units of mass, such as pounds, in equations.
Cursed
39
I just want to know why the tension in the rope in system A is not equal to 100 lbs, while the tension in the rope in system B IS 100 lbs.
[PLAIN]http://img823.imageshack.us/img823/9462/conceptualquestion.png
In system A, a 100-lb mass is hanging. In system B, there is a 100-lb downward force.
The question asks: Find the acceleration of the 200-lb block.
None.
For system B,
T - mg = -ma
(100 lb) - (200 lb) = - (200 lb/ 32.2ft/s) a, a = 16.1 ft/s^2
In system B the question tells you that the tension is 100lb whereas for system A you are not told what the tension is.Let the tension=T
For the 200 lb weight.... 200-T=200a
For the 100 lb weight.... T-100=100a
Let me tell this to you another way:
Let us assume that tension is 100lbs. Then the blue box will have no acceleration. but red box will have acceleration and hence blue block should also have acceleration. Hence contradiction.
In the other case I do not think that they have mentioned that tension is 100 lbs. Let us concentrate on the particle on which the force 100 lbs is acting. We are taking rope to be of negligible mass.Hence the particle is of negligible mass. Hence any finite force in any direction on the particle would create infinite acceleration. Hence for acceleration to be finite, negligible force should be acting on it. Due to this tension in the rope is equal to 100 lbs
A and B are equivalent, the tension is the same.
No, they are not. Read the above 2 posts for your understanding and then reply.
I have read them thank you, the first post is fine a simultaneous equation. And from it T = 133lb, I now see that they are not equivalent as the mass being accelerated is larger in the first example
I couldn't really understand your post. Especially as the string is a means to transfer force therefore its mass is of not consideration. Perhaps I am being slightly confused by american units especially the use of a unit of mass (lb) to describe a force. You seemed to say the the tension was not 100lb but then deduce that it was??
I'm having the same problem with the units as you Mr Gibson.(Anyone looking at the equations should take into account that the weights should be expressed in units of pound force as distinct from the masses which are in pounds.Is that right?)
My Thursday rant:
Why do some people still use these old fashioned and confusing units?Rant over.
ashishsingal I think it is implicit in the question that for B the tension is 100lb but I agree that it is not stated to be so.Perhaps the OP will report back and clarify the question.If you wish to consider a particle of negligible mass on the rope remember that there are two forces acting on it.
Yeah, that is what my point is. The first force is the 100lb one, the other is tension. They act in opposite direction. Since they need to make net force on the particle zero, they need to cancel out each other. due to this tension is 100lbs
Yes I agree.Nicely analysed as a good first approximation.:biggrin:
Thank you.
FAQ: Why is the tension different in two systems with the same downward force?
What is a simple conceptual question?
A simple conceptual question is a question that aims to understand a basic concept or idea in a particular subject or field.
How do you approach answering a simple conceptual question?
The best approach to answering a simple conceptual question is to break down the concept into smaller, more manageable parts and explain each part in a clear and concise manner.
Can you give an example of a simple conceptual question?
Sure, an example of a simple conceptual question could be "What is the difference between a hypothesis and a theory?"
Why are simple conceptual questions important in science?
Simple conceptual questions are important in science because they help establish a strong foundation of understanding for more complex ideas and theories. They also encourage critical thinking and problem-solving skills.
How can simple conceptual questions benefit scientific research?
Simple conceptual questions can benefit scientific research by helping scientists identify areas of misunderstanding or confusion in a particular concept, which can lead to further exploration and discovery.
