MHB Why is the voltage in an ideal battery equal to that in an open circuit?
  • Thread starter Thread starter Mango12
    Batteries
The voltage in an ideal battery remains constant regardless of the load, which is a key characteristic of its design. In an open circuit, there is no current flow, so the battery's voltage is not affected by any resistance. This means that the voltage measured across the terminals of an ideal battery is equal to its open-circuit voltage. Real batteries, however, experience voltage drops under load, but they behave like ideal batteries when no load is present. Thus, the equality of voltage in an ideal battery and an open circuit is a fundamental principle of its operation.
Mango12
question: referencing ohm's law, why is the voltage in an ideal battery equal to that in an open circuit?
I know ohm's law, and I know that an ideal battery has the same voltage no matter what it's connected to, but what does that have to do with an open circuit?
Mathematics news on Phys.org
Hi Mango12! ;)
A real battery loses some of its voltage in a closed circuit.
Putting a load on real battery has its effect.
However, even a real battery behaves like an ideal battery if there's no load on it - that is, if we have an open circuit.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
